Polo 6R ABS CODING
starostkadk
Drives: 6R 1.6 TDI
Re: Polo 6R ABS CODING
Post by starostkadk »
iichel wrote: Mon Mar 11, 2019 10:09 pm try:
210228E3436F00B5842A14EAC2D600421700
It got accepted and removed one of the errors. Start/stop still not working.
                Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP82.clb
Control Module Part Number: 6R0 907 379 AK    HW: 6R0 907 379 AF
  Component and/or Version: ESP8.2i front H05 0001
           Software Coding: 210228E3436F00B5842A14EAC2D600421700
            Work Shop Code: WSC 00788 648 00255
                      VCID: 871DFD9E328DB926559-80D2
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 248
                    Mileage: 187183 km
                    Time Indication: 0
                    Date: 2021.14.02
                    Time: 08:12:06
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x1201
                    Hex Value: 0x37A5
                    Hex Value: 0x007C
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Post by exantas »
Does anyone know how to check with vcds, if indirect tpms is actived?
Is this setting under abs long coding? Or adaptation?
I collect information on this and try to figure out if its possible to activate in own car.
It's in the long coding. What is your coding?
exantas
Post by exantas »
I haven't scanned the car yet.
I got a cable but I will get access to the car in two weeks. I will post the coding then.
I am asking so I know where to start looking .
That's ok. You can also see if there is a tpms reset button in the glove box. If the car doesn't have tpms, there won't be a button
exantas
Post by exantas »
There is no TPMS reset button. And in that way there is no TPMS installed.
But I am wondering if I could "enable it" as indirect TPMS, without the use/existence of a button
massimo23
Drives: Polo Beats 2017
Post by massimo23 »
I have indirect tpms but no reset button. The reset function is present in the settings of the composition media unit.
massimo23
Post by massimo23 »
You would need to change a byte in the abs long coding and also enable the tpms menu in 5F multimedia unit and enable tpms option in dashboard long coding.
Here is the menu:
exantas
Post by exantas »
I scanned my car today with VCDS.
Long coding didn't give me any documented option for my ABS module. I found the option for TPMS in instrument cluster long coding (disabled), but if I can't enable it on ABS, I don't think that would be any practical use.
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 400100DB007500BB022C00E200D200000000
   Shop #: WSC 39901 003 1048576
   VCID: 4E9357C81D4EEF3A17-801A
drewdoom
Drives: Polo 6R
Post by drewdoom »
Hi Guys a newb here.I need some help with coding abs in polo 6r here is full scan:
Tuesday,28,January,2020,19:59:29:10074
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCY154535
Address 01: Engine (J623-CGPB) Labels: None
Part No SW: 03E 906 019 M HW: 03E 906 019 B
Component: SIMOS11.1 H03 9487
Revision: --H03--- Serial number:
Coding: 00110016000400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MPI02103E906019M 001008
ROD: EV_ECM12MPI02103E906019M.rod
VCID: 2E570A8BC2D7
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 800B0433A8C3
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Priority: 0
Fault Frequency: 2
Reset counter: 174
Mileage: 124029 km
Time Indication: 0
Date: 2023.14.21
Time: 07:39:40
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1213
Hex Value: 0x14A4
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 2
Reset counter: 174
Mileage: 124029 km
Time Indication: 0
Date: 2023.14.21
Time: 07:39:40
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x1251
Hex Value: 0x1BA4
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 2
Reset counter: 174
Mileage: 124029 km
Time Indication: 0
Date: 2023.14.21
Time: 07:39:40
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x12E1
Hex Value: 0x20A4
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 5
Reset counter: 214
Mileage: 124029 km
Time Indication: 0
Date: 2023.14.21
Time: 07:40:26
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x12E7
Hex Value: 0x25A3
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7EF8
Address 08: Auto HVAC (J301) Labels: 6R0-820-045.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397D29D70B99
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 174
Mileage: 124029 km
Time Indication: 0
Date: 2023.14.21
Time: 07:20:21
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 K HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0254
Revision: BF046001 Serial number: 0434 328110275
Coding: 24B02BBF08A10000013008006D2B0FD00040412F60860000200000000000
Shop #: WSC 124697 483 00190
VCID: 458555277761
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 241111 05 54 0403
Coding: 03302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
Component: J386__TSG_FT 008 1611
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
Component: J387__TSG_BT 008 1611
Coding: 08BC30
Subsystem 4 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Coding: 08BC32
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Coding: 08BC32
Component: VW10Airbag01M H09 0020
Revision: -------- Serial number: 003GX010A85X
Coding: 00314D
VCID: 4A9F661B5E7F
Driver's Airbag Crash Sensor:
Serial number: 3575HRB405R0UJCIBHOR
Passenger Side Airbag Crash Sensor:
Serial number: 3585HRB405R0UJCI39J7
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB404R0UFQ0EOGO
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB404T0UFQ0EGRU
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Coding: 140E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 397D29D70B99
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 H46 0254
Revision: BF046001
Coding: 002200
VCID: F0EB54F39863
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EADF469BBEBF
Give this a try please and report back:
210224E3217200B6842A24E584D600401700
exantas wrote: Mon Aug 26, 2019 9:57 am I scanned my car today with VCDS.
   Revision: --------
400100DB007500BB022C00E200D200000200
I believe this might be the coding for TPMS
drewdoom
Drives: Polo 6R
Post by drewdoom »
Your coding worked perfectly.Thank You very much.BR
joergleimbach
Drives: 6J
Post by joergleimbach »
Hello from germany, my Ibiza 6j lost the longcoding, is it possible that someone provides the right code? just tell me what is needed.
Dienstag,19,Mai,2020,10:51:12:00009
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
VCDS Version: PCI 19.6.2.1
Datenstand: 20191020 DS308.0
www.VCDSpro.de
Fahrzeug-Ident.-Nr.: VSSZZZ6JZ9R117625 KFZ-Kennzeichen:
Kilometerstand: 113370km Reparaturauftrag:
Fahrzeugtyp: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44
Fahrzeug-Ident.-Nr.: VSSZZZ6JZ9R117625 Kilometerstand: 113370km
01-Motorelektronik -- Status: i.O. 0000
03-Bremsenelektronik -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
Adresse 01: Motorelektronik (XXX) Labeldatei: DRV\03E-906-033-AZQ.lbl
Teilenummer SW: 03E 906 023 M HW: 03E 906 023 M
Bauteil: SIMOS91 1.2l 4VG 2602
Revision: --H04--- Seriennummer:
Codierung: 0000071
Betriebsnr.: WSC 06402 785 00200
VCID: 295948A383F92B07D1-5178
Kein(e) Fehlercode(s) gefunden.
Readiness: Nicht Verfügbar
Adresse 03: Bremsenelektronik (J104) Labeldatei:. DRV\6R0-907-37x-ESP82.clb
Teilenummer SW: 6R0 907 379 H HW: 6R0 907 379 H
Bauteil: ESP8.2i front H04 0005
Revision: --------
Codierung: 000000000000000000000000000000000000
Betriebsnr.: WSC 04941 000 00000
VCID: 4385FA0BC695D157FB-8016
3 Fehlercodes gefunden:
01042 - Steuergerät nicht codiert
000 - -
Umgebungsbedingungen:
Fehlerstatus: 01100000
Fehlerpriorität: 0
Fehlerhäufigkeit: 7
Verlernzähler: 219
Kilometerstand: 113361 km
Zeitangabe: 0
Datum: 2014.10.10
Zeit: 00:08:58
Hex Wert: 0x0007
Hex Wert: 0x0002
Hex Wert: 0x3213
Hex Wert: 0x14B6
Hex Wert: 0x007F
Hex Wert: 0x7F7F
Hex Wert: 0x7E00
Hex Wert: 0x0000
00778 - Geber für Lenkwinkel (G85)
005 - keine oder falsche Grundeinstellung/Adaption
Fehlerstatus: 01100101
Fehlerpriorität: 0
Fehlerhäufigkeit: 7
Verlernzähler: 219
Zeitangabe: 0
Datum: 2014.10.10
Zeit: 00:08:58
Hex Wert: 0x0007
Hex Wert: 0x0002
Hex Wert: 0x3251
Hex Wert: 0x1BB6
Hex Wert: 0x007F
Hex Wert: 0x7F7F
Hex Wert: 0x7E00
Hex Wert: 0x0000
00493 - ESP-Sensoreinheit (G419)
Fehlerpriorität: 0
Fehlerhäufigkeit: 7
Verlernzähler: 219
Zeitangabe: 0
Datum: 2014.10.10
Zeit: 00:08:58
Hex Wert: 0x0007
Hex Wert: 0x0002
Hex Wert: 0x32E1
Hex Wert: 0x20B6
Hex Wert: 0x007F
Hex Wert: 0x7F7F
Hex Wert: 0x7E00
Hex Wert: 0x0000
Adresse 08: Klima-/Heizungsel. Labeldatei: 6J0-820-045.clb
Teilenummer SW: 6J0 820 045 HW: 6J0 820 045
Bauteil: J301 Klimaanlage 0280
Revision: 00 23 08 Seriennummer: 0000000097372-
Betriebsnr.: WSC 00000 000 00000
VCID: 63C51A8BA255B157DB-8036
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\6R0-937-08x-09.clb
Teilenummer SW: 6R0 937 087 K HW: 6R0 937 087
Bauteil: BCM PQ25 H+4 H46 0254
Revision: BF046001 Seriennummer: 0434 157120841
Codierung: 3C882968A8210100002006606C2B8CC800C042EF608E0000200000010000
Betriebsnr.: WSC 80093 222 69422
VCID: 4581E413CCA1EF67D5-8010
Subsystem 1 - Teilenummer SW: 6R0 959 801 HW: 6R0 959 801 Labeldatei: 6R0-959-801.CLB
Bauteil: J386__TSG_FT 001 0247
Seriennummer: --------------------
Codierung: 020000
Subsystem 2 - Teilenummer SW: 6R0 959 802 AR HW: 6R0 959 802 AR Labeldatei: 6R0-959-802.CLB
Bauteil: J387__TSG_BT 007 5110
Seriennummer: 13202562150421043610
Codierung: 020000
1 Fehler gefunden:
00920 - beheizbare Außenspiegel (Z4/Z5)
011 - Unterbrechung
Fehlerstatus: 01101011
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 218
Kilometerstand: 140877 km
Zeitangabe: 0
Datum: 2010.11.05
Zeit: 01:33:46
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 6R0 959 655 C HW: 6R0 959 655 C
Bauteil: VW10AirbagA01 H08 0018
Revision: -------- Seriennummer: 003000000000
Codierung: 003031
Betriebsnr.: WSC 06401 785 00200
ASAM Datensatz: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428BFF0FD58FD85FF0-8016
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3492ERB401P8CLJAOC4
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3502ERB402N85LSJ6RPF
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 6J0 920 800 K HW: 6J0 920 800 K
Bauteil: KOMBI 017 0018
Seriennummer: 00000000000000
Codierung: 110A00
Betriebsnr.: WSC 00011 888 96745
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 2E53BBBF71174C3F04-807A
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\6N0-909-901-6R.clb
Teilenummer SW: 6N0 909 901 HW: 6R0 937 087
Bauteil: GW-K-CAN TP20 H46 0254
Revision: BF046001
Codierung: 022000
VCID: 70EF65C7A3A31ACF56-8024
Adresse 25: Wegfahrsperre (J334) Labeldatei:. DRV\5K0-920-xxx-25.clb
Bauteil: IMMO 017 0018
Seriennummer:
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
Adresse 44: Lenkhilfe Labeldatei: DRV\6Q0-423-156.clb
Teilenummer: 6R0 423 156
Bauteil: LenkhilfeTRW V272
Codierung: 10131
VCID: 6DD17CB32091F7277D-8038
Ende----------------------------(Dauer: 02:08)-----------------------------
Kannst Du bitte diese Kodierung probieren?
100228DB016E00B9082B14E480D600000000
