OBDeleven
proalves
Drives: Polo GTI AW1 2019
OBDeleven
Post by proalves »
I recently got OBDeleven and the idea was to compile all possible changes/modifications with this tool in one place, my previous experience was with VCDS but the version I have doesn't communicate with my Polo GTI 2019+ so I decided to buy OBDeleven.
I think it would benefit everyone here if we took all the necessary steps for the changes, because the little information I gathered rarely applies to our VW Polo, but I believe it is the same and across the VW group.
For now I just changed these parameters ...
Show Blower speed even in Auto
-Select Control unit: 08 Air Conditioning
-Select Long Coding
-Select Blower display in auto operation
-Change from Not activated to activated
Display amount of Fuel left
-Select Control unit: 17 Dash Board
-Select Long Coding
-Select Volume to be replenished:
-Change from No to Yes
Turn off Soundaktor
-Select Control unit: A9 Actuator for Structure Borne Sound
-Adaption
-Change to whatever value you want
Mine changed to 0
CarbonChaos
Re: OBDeleven
Post by CarbonChaos »
The coding for new polo should be the same or similar to mk7 golf and Passat B8,
as it’s on the MBQ AO platform.
proalves
Re: OBDeleven
Post by proalves »
CarbonChaos wrote: Wed Dec 18, 2019 8:09 pm The coding for new polo should be the same or similar to mk7 golf and Passat B8,
That's exactly what I said it should look like the same.
By the way does anyone know the steps by OBDeleven to make this change...
https://imgur.com/a/hvgY2lO
I don't know if I'm committing an infraction by placing the link here but I'm not able to send photos through the forum... :oops:
proalves
Re: OBDeleven
Post by proalves »
Here is the solution to my previous post, it was by trial and error, but I got the solution because I didn't find it on the internet.
Change speedometer appearance in Active Info Display
-Adaptation
-look for "tachometer end value"
-Change from 1 to 5
I hope I have somehow helped those like me who wanted to change the look of the speedometer.
ryanponti
Re: OBDeleven
Post by ryanponti »
what are the other Speedometer versions? I really like the version 5 i prefer to have more increments on the speed.
proalves
Re: OBDeleven
Post by proalves »
Here they are...
https://imgur.com/a/OMDNLAM
I currently have option 5 but possibly change it to 4...
You can also change the color of the speedometer.
CP_Vaughny
Drives: R-Line 2019
Re: OBDeleven
Post by CP_Vaughny »
What colours?
silverhairs
Drives: 2018 Polo SEL
Re: OBDeleven
Post by silverhairs »
I think you'll find it's the OBD(2) the (II) are roman numerals for 2. Not trying to be pedantic :oops: .
l3rady
Drives: Polo GTI+ 2019
Re: OBDeleven
Post by l3rady »
silverhairs wrote: Sun Jan 05, 2020 2:44 pm I think you'll find it's the OBD(2) the (II) are roman numerals for 2. Not trying to be pedantic :oops: .
true, but there are referring to the product called ODBEleven (https://obdeleven.com/en/). The company thought they were clever seeing that the II looks like the number eleven
proalves
Re: OBDeleven
Post by proalves »
Activation Of Rear DRL Tailight
- Select Control unit: 09
- Access authorisation: 31347
- Adaptation
- Außenlicht_Front
- Tagfahrlicht-Dauerfahrlicht_aktiviert_zuaetzlich_Standlicht "active"
Activation Of Rear DRL Tailight.jpg (87.66 KiB) Viewed 12134 times
The image is not mine ...
GTI Polo Fin
Drives: Polo GTI 2019
Re: OBDeleven
Post by GTI Polo Fin »
Any luck on deactivating start/stop-system on 2019 Polo GTI?
I have tried to change voltage level to 12V with OBDEleven, but that does not work, since battery voltage is all the time >12.6V.
Any other software solutions?
proalves
Re: OBDeleven
Post by proalves »
GTI Polo Fin wrote: Tue Feb 04, 2020 4:59 pm Any luck on deactivating start/stop-system on 2019 Polo GTI?
This is the only method I know and have seen on the internet.
I hadn't applied and tested it because 99% of the time I turn on the ignition and immediately turn off the Start/Stop.
It's practical since my car is equipped with Keyless and I have already acquired the muscle memory for this purpose...
john M
Drives: AW12BVA
Re: OBDeleven
Post by john M »
You should increase the threshold voltage, not decrease it, to disable the stop start, suggest 16V or so.
Re: OBDeleven
john M wrote: Fri Feb 14, 2020 8:55 am You should increase the threshold voltage, not decrease it, to disable the stop start, suggest 16V or so.
Exactly!
Re: OBDeleven
Exactly, you need the battery voltage requirement at a level that the car can't achieve.
