ciclo wrote: Fri Feb 21, 2020 3:04 am
It's possible.
Check the windshield washer fluid level.
If I understood you correctly, the windshield washer system only works with the lights off, is that correct?
Were the new stalks you installed brand new?
Good morning my friend , the fluid level was max . Yes windshield washer system works perfect with lights on and of as always .
Stalks brand new. The problem is in headlights wisher system . They used to work only with lights on . Now with lights on works only windshield washer system .
Tell me is it possible to have differences between bcm high and bcm max in pin positions for headlight wisher system?
The matter that head light wisher system did not work, is something that I have not noticed until now .
Best regards
Vasilis
