Hi all,
I’m toying with the idea of a intake on my stock 2015 polo GTI and have come across some issues identifying the correct name for the factory turbo.
Here’s what I’m after ( as per golf 7 )
1 - a larger turbo elbow and silicone hose
2 - a enclosed air filter
3 - turbo muffler delete
I’ve been looking at the revo and racing line stuff, I’ve contacted a couple of companies who all quote me the same guff listed online which is ‘ it fits a IS20 and IS38 turbo’
Can anyone tell me what turbo the polo has from factory? I see IHI cast into the housing ?
Am I right in thinking the IS38 is for Golf R and the IS20 is for golf GTI ? Is the polo GTI turbo an IS12 ?
Thanks in advance.
Performance intake ?
CarbonChaos
Dink
- Platinum Member
- Drives: 2015 GTI
Re: Performance intake ?
Hi
I've fitted the racingline intake on my 2015 gti but wasn't happy with small elbow fitted stock.
So looking into it i found that all the turbos have exactly the same dimensions for attaching everything.
So a racing line elbow fits no problem but you need the breather hose off a golf R as it attaches to the underside of the elbow rather than the top side.
This also goes for muffler delete fitting any turbo is12,20,38
CarbonChaos
Thanks dink,
That’s pretty much the answer I was looking for, so just to be completely clear I can order a polo specific air intake and golf mk7 specific elbow and turbo muffler delete ?
How do you find the racingline intake noise wise ? Good, bad or ?
Many thanks again.
Many thanks again.
Dink
- Platinum Member
- Drives: 2015 GTI
no if you get a polo specific intake it will probably only fit the smaller elbow
racing line do a kit that comes on top of the intake but imho it's pointless as you are left with a useless silicone hose
that is why i fitted my own silicone hose to the racing line elbow
you will need the breather unless you find a larger elbow specific for the polo
I didn't get it for noise so can't comment plus i wouldn't hear it over the milltek
CarbonChaos
Thanks yeah you’re right about the air filter to elbow pipe.
I am aware that i will be buying a pipe that will not fit and never be used.
By chance do you know the part number for the golf breather hose required?
Dink
- Platinum Member
- Drives: 2015 GTI
https://clptuning.co.uk/product/genuine ... ther-hose/
This is the pipe but if you buy the racingline upgrade i believe it comes with it.
Dink
- Platinum Member
- Drives: 2015 GTI
https://www.ebay.co.uk/itm/392545109712 you can use the code PAID20 to get best part of £70 offCarbonChaos wrote: Wed Feb 26, 2020 12:19 pm Thanks yeah you’re right about the air filter to elbow pipe.
CarbonChaos
Thanks you’re a gent
