ABS Coding after upgrading brakes
jackb57
Drives: 6R 1.2 TSI R-line 130hp
Post by jackb57 »
Hi I’ve just changed my front brakes on my r line from 256 to 288
This is my code:
23DD2885492333C9091A10700059C41492CC90080005CB098F00
I’ve tried changing byte 2 to 48 and byte 10 to 12 but that coding wasn’t accepted?
Re: ABS Coding after upgrading brakes
Can you please show a bit more information like a full autoscan?
Never mind, I got it. Your car is a 6C. Please change the coding to:
23DD4885492333C9091A10700059C41292CC90080005CB098F00
jackb57
Post by jackb57 »
Apologies for lack of info I’ll post a full scan when I try the coding you suggested
Polo R-line 6c 2016 model 1.2 TSI CJZC 90hp
jackb57
Post by jackb57 »
Hello i tried your code and it was accepted!
i will be doing the upgrade to 312 brakes once these have run their course, whilte i have your attention could i bother you for that code too?
Let's see by then.
jackb57
Post by jackb57 »
Thank you! :D
Brakes feel much better can’t wait to get my 312’s on
jackb57
Post by jackb57 »
Finally got these 312 on and struggling again to find the code I need
I had 288/230 on now 312/230
23DD4885492333C9091A10700059C41292CC90080005DB098F00
I’ve tried changing byte 2 to 68 and byte 15 to 16 but no luck
jackb57
Post by jackb57 »
Also tried changing byte 2 to 68 and byte 10 to 16 to no avail.
Reading other posts this could be a problem...
with a 2016 Polo 1.2 TSI R-Line is it even possible to code the ABS Module for this combination of brakes?
If this turns out to be true might I be better off upgrading rears to 270mm to keep the braking balance?
I think it's only available with the correct engine power class (GTI).
jackb57
Post by jackb57 »
Could well possibly be...
However I didn’t enter any security access maybe I’m being stupid and that’s the problem
jackb57
Post by jackb57 »
That wasn’t the problem either, hopefully I can find a solution
These look so good want them to work good too!
perhaps if you take off the audi sticker, it will work ;)
jackb57
Post by jackb57 »
Maybe sticking a VW sticker over the top they would want to work? :lol:
Worth a shot, isn't it?
