Hi All,
Strange one this I think. Car has been running fine. This week-end I put a set of new headlights on it. Just driven now and she doesnt start aswell, lack of power on hills. Engine Management light is on and seems to 'judder' when I turn off the ignition.
Could I have disturbed anything when removing the front bumper etc? Or is it total coincidence?
Thanks for any help.
Power Problems
littlepolo
Re: Power Problems
You need to check for any codes.
Not much to disturb if you've carefully removed and replaced only the front bumper and headlights.
Re: Power Problems
The only thing I seemed may have disturbed is the Air Intake Temperature Sensor, that was attached to the bumper. If this is faulty would that cause these problems?
Re: Power Problems
I think that that air temperature probe only supplies the AC system, and obviously the temperature readout for the outside temperature.
Re: Power Problems
Got some codes now.
Main one I think is P0243 VAG : Turbo Wastegate Solenoid 1
Thats what i felt like when driving it, no Turbo kicking in.
