Polo 6R 09 1.4 85KM
Re: Polo 6R 09 1.4 85KM
Good find. Hopefully you can enjoy your lights soon
- ag69
- Drives: 1.2TSi 77Kw 7DSG
very nice !!!!
dcgumis
- Drives: polo 1.4 85KM CGGB/GOLF 7.5
I finished making the AFS cable bundle
T26 / 2 -T73B/19 CAN drive High bus
T26 / 3 - T73B/18 CAN drive Low bus
T26 / 7 - T4 / 1 sensor
T26 / 10 -T4 / 3 sensor
T26 / 11 - T4 / 4 sensor
T26 / 15 - right lamp T14 / 1
T26 / 16 - left lamp T14 / 3
T26 / 17 - left lamp T14 / 1
T26 / 18 - left lamp T14 / 4
T26 / 19 - left lamp T14 / 2
T26 / 20- right lamp T14 / 4
T26 / 21 - right lamp T14 / 2
T26 / 22 - right lamp T14 / 3
T26 / 23 - power, terminal 15, with fuse SB11
T26 / 24 - ground, terminal 31
Recently, I was thinking about adding a cornering light in the fog light How to make Is it possible without ESP ?
Thank you !:)
Recommendation
Now that you are going to make new electrical installations you can wire the new slip ring with G85 sensor so that the Static Cornering lights work with your new BCM Max.
It will work properly even if your brake unit is for ABS and nor for ESP.
Thank you !:)
It's really easy, you just have to wire your current slip ring correctly. (G85 --> 6R0 959 564)
They are 5 wires:
+15, +30, Ground, CAN H, CAN L.
Use the following images as reference (from other user - govindsharma - read here pg 2 & 3 ):
T41 ---> 6,5,4,3,2
CAN lines (powertrain ---> in your case, for example ---> OLD/ORIGINAL IC CAN lines)
In this way the BCM will know the steering wheel angle to automatically activate the SCLs on each side (once the BCM has been coded for SCLs).
Note:
-It is likely that with your VCDS cable Address 04 is not visible in your future autoscans, however Address 04 must be activated in the Gateway installation list.
They are 5 wires:
T41 ---> 6,5,4,3,2
Note:
dcgumis
thank you fernando
I will try to do as you wrote
I solved the problems with the lights that I described earlier
I have replaced the module corresponding to the lamp 7PP941571AE(Z01)
I also installed the front and rear parking sensors
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231602503915
Coding: 100001
Shop #: WSC 35759 001 104857
ASAM Dataset: EV_VW75XParkAsiss8K 001003
ROD: N/A
VCID: 3B72AFC3B27607E648-806E
No ASAM data for: "EV_VW75XParkAsiss8K" (VW25)
No fault code found
I would also like to solve the problem of a burned bulb after replacing BCM and
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Shop #: WSC 02737 022 00190
VCID: 68D8208F9B607C7EF5-803C
1 Fault Found:
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 172782 km
Time Indication: 0
Date: 2007.14.26
Time: 11:02:37
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 014162029
Coding: 3DB02BB828F3240092380010BC2B1DD01BC0670F608530C1200000030000
1 Fault Found:
01134 - Alarm Horn (H12)
000 - -
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 172782 km
Time Indication: 0
Date: 2007.14.26
Time: 11:02:39
Dzięki za pomoc
Coding: 100001
ROD: N/A
No fault code found
Revision: B9080001
Coding: 002200
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 172782 km
Time Indication: 0
Date: 2007.14.26
Time: 11:02:37
1 Fault Found:
000 - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 249
Mileage: 172782 km
Time Indication: 0
Date: 2007.14.26
Time: 11:02:39
Dzięki za pomoc
Try 042200 as CAN gateway coding
dcgumis
Revision: B9080001
Coding: 042200
VCID: 68DF0DA79B73D20F0F-803C
Yes, it worked, thank you
I also solved the burnt light bulb control,I have disabled bit 7 in byte 21
Excellent, good job!
dcgumis
Thank you
I did AFS installations, but I received errors, I have to flash the module
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0F44020001000000
Shop #: WSC 02757 790 50316
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A7CAAC7BD4C3EEE53-806E
3 Faults Found:
13705473 - Databus
U1121 00 [137] - Missing Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:31
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Fault Priority: 1
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:32
13705474 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:31
An error appears during lamp calibration
Does anyone have parameterization for ABS?
Thank you for your help
3 Faults Found:
13705473 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:31
5275220 - Headlight
Fault Priority: 1
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:32
13705474 - Databus
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 172816 km
Date: 2020.04.23
Time: 08:40:31
dcgumis
Hi
, with the help of Firegrafik we have done the TinyQ paramatrization and AFS works
Thank You
Coding: 0D49000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_HeadlReguvLWLWRCC 002006
ROD: N/A
No ASAM data for: "EV_HeadlReguvLWLWRCC" (VW25)
ROD: N/A
Sorry for missing out.
For flashing with VCP/ODIS in C module:
https://drive.google.com/open?id=1TX0-n ... giQjr9W7xt
dcgumis
I did it like thatiichel wrote: Wed Apr 29, 2020 5:45 pm Sorry for missing out.
Ignore SB54. It is obsolete if you make new cornering lights.
SB54 installation:
+75 contact --> light switch T17/2 (in) T17/8 (out) --> SB54a/b --> fog lights.
So SB54 can be removed and the wires can be left (or better, removed and isolated).
You see, no BCM interference.
Your new installation will be different.
Remove the wire that is now in T17/8 and isolate.
Make a new wire from T17/8 to BCM T73a/7 (1.5mm2), if possible, yellow
There goes a wire from SB57 to T73b/11 (this wire is already in place/needed for your LED headlights)
One wire goes from T73b/9 to the left fog light/static cornering light
One wire goes from T73b/10 to the right fog light/static cornering light
Now you can cheat a little bit. SB54b goes to both fog lights (SB54b is close to the middle).
You can use this to wire T73b/10 to the right fog light and save 5 meters of wire.
So connect T73b/10 to SB54b (cut off connector from the yellow/white wire). You can check if it's the good one with your multimeter. It should NOT be connected to the light switch T17/8.
It is important to remove and isolate the wire to the left fog light at the connector of the fog light. Here you'll place the new wire (T73b/9 to T2/1).
VCDS BCM:
Byte 12 bit 6 on
Byte 19 bit 1 on
Byte 21 bit 2+7 on
SB54 installation:
VCDS BCM:
Byte 12 bit 6 on
Byte 19 bit 1 on
Byte 21 bit 2+7 on
dcgumis
thank you, I meant the Ciclo installationiichel wrote: Wed May 06, 2020 1:13 pm Ignore SB54. It is obsolete if you make new cornering lights.
SB54 installation:
VCDS BCM:
Byte 12 bit 6 on
Byte 19 bit 1 on
Byte 21 bit 2+7 on
T41 ---> 6,5,4,3,2
but I don't know which fuse to connect to t41 / 6
