Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
benzinkopf wrote: Tue May 26, 2020 4:54 pm ACC please!
The preparation for the mod can already be seen. No hardware in this picture is to be changed.
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Post by firegrafik »
Are you going to retrofit automatic transmition? I don't have another reason seeing the shift pads on the steering wheel.
CNK
Drives: 6R
Post by CNK »
New mileage, great :mrgreen:
Seeing the image, I remembered that I have to put the OBD2 socket back in its original place for the MOT (ITV).
I'm intrigued, I like this.👍 :)
Some news from the spare parts department...
Changed Aliexpress pre-interior filter after one year
MUCH better
Had a small accident with a hole in the road...
+ my tire now has an aneurysm...
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
iichel wrote: Fri Sep 21, 2018 9:04 am Image
[/quote]
Do you happen to know what type of bulb is used behind the cigarette lighter socket on the red filter? As mine has never worked and would like to buy an led version if possible.
Thanks!
Believe it or not, that's the only factory bulb in there ;)
Aquavalver
iichel wrote: Wed May 27, 2020 12:00 pm Believe it or not, that's the only factory bulb in there ;)
Ha ha! Only way I can think of being able to change it to white would be if you could get the red filter 3D printed in a clear/opaque material if there is such a thing?
I'd just get the golf 7 socket
Factory intercooler
Of course you don't want to be seen with this...
Darkside intercooler :-)
I did a mod!
OEM brake pad indicator!
Wiring:
Tacho T32/15 to the brake pad. Connect the other wire of the brake pad to GND.
I only did the front axle by the way.
Coding:
You need to read the EEPROM of your instrument cluster and change offset 02D3 (line 02D0 byte 3) and take bit 0 and change to 1.
In my case, I changed HEX 46 to 47.
Then you can code byte 1 bit 0 of the instrument cluster. 140E01 to 140F01
Now if the brake pad is worn, the contact will break and the instrument cluster will tell me.
Secretly my car wants to be a pirate :lol:
Ok, without right headlight. ...or do you mean something else?
However, I think our 6Rs are authentic pirates a long time ago (not just shock absorbers, big wheels, painted flames... :lol:).
Clearly, you really enjoy your 6R. 8)
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
iichel wrote: Tue Jun 02, 2020 8:59 pm I did a mod!
very nice !!!
ciclo wrote: Wed Jun 03, 2020 4:16 am Ok, without right headlight. ...or do you mean something else?
Yes haha. I removed the entire front of the car, including supporting frames. It was needed to place back the headlight for alignment of the bumper and headlights.
Afterwards I remove the left headlight (right on the picture) to continue work on the DSG wiring (DSG connector and starter inhibitor relay).
I am absolutely still enjoying my 6R(s), in two weeks the Rosa-Line will have its 9th birthday.
It's funny we still call it the Rosa-Line, even though we broke up almost two years ago.
There is always more potential to unlock in a car and there is always more things to learn.
