Polo mk5 2010 6R standard stereo to KENWOOD DMX7017DABS 2DIN
Sharman07
Drives: Mk5 polo 2010
Post by Sharman07 »
Can any one help me adapting the wiring for this upgrade please?
marco_polo
Drives: Polo GTI 6C 2016
Re: Polo mk5 2010 6R standard stereo to KENWOOD DMX7017DABS 2DIN
Post by marco_polo »
You shouldn’t need any extra wiring as long as you’ve got the loom that came in the box you’ll be good to go. I believe if you have a MFSW there’s an extra loom which normally comes in the box too.
I would recommend doing the handbrake bypass - cut one of the cables on the loom and earth back to your Kenwood unit, I believe it’s the green one but it’s worth checking online.
Sharman07
Post by Sharman07 »
Cool cheers mate but followed a guide that told me to connect the red cable to a fuse spur on ignition switched fuse, all works well but when I turn the lights on or indicators the stereo turns off!! Also a epc light is showing on the dash when key is first stuck in the ignition!! Can you help at all? What have I done wrong?
