Polo mk5 2010 6R standard stereo to KENWOOD DMX7017DABS 2DIN
Can any one help me adapting the wiring for this upgrade please?
marco_polo
- Drives: Polo GTI 6C 2016
Re: Polo mk5 2010 6R standard stereo to KENWOOD DMX7017DABS 2DIN
You shouldn’t need any extra wiring as long as you’ve got the loom that came in the box you’ll be good to go. I believe if you have a MFSW there’s an extra loom which normally comes in the box too.
I would recommend doing the handbrake bypass - cut one of the cables on the loom and earth back to your Kenwood unit, I believe it’s the green one but it’s worth checking online.
Cool cheers mate but followed a guide that told me to connect the red cable to a fuse spur on ignition switched fuse, all works well but when I turn the lights on or indicators the stereo turns off!! Also a epc light is showing on the dash when key is first stuck in the ignition!! Can you help at all? What have I done wrong?
