Polo 6R ABS CODING
Drives: Polo 6R 1.2 TDI
Re: Polo 6R ABS CODING
I see. It should not matter if you did not enter security code or not. You can perhaps try engine on/engine off.
drewdoom
Drives: Polo 6R
Post by drewdoom »
Hi.Can I ask another time for help with coding abs in Polo?
Monday,08,June,2020,11:53:25:10074
Data version: 20111008
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZBU002603
08-Auto HVAC -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (CGP) Labels: Redir Fail!
Part No SW: 03E 906 023 L HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4489
Revision: --H05--- Serial number:
Coding: 0000071
Shop #: WSC 31414 790 31414
VCID: 285BFC93E033
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 009 - Open or Short to Ground
RPM: 0 /min
Temperature: 15.0°C
Temperature: 22.5°C
Speed: 0.0 km/h
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
VCID: 8607122B8AE7
6 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 214
Mileage: 45959 km
Time Indication: 0
Date: 2103.14.13
Time: 00:13:33
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3213
Hex Value: 0x14BB
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 12
Reset counter: 214
Mileage: 45959 km
Time Indication: 0
Date: 2103.14.13
Time: 00:13:33
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x32B2
Hex Value: 0x08BB
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 12
Reset counter: 214
Mileage: 45959 km
Time Indication: 0
Date: 2103.14.13
Time: 00:13:33
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3251
Hex Value: 0x1BBB
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 12
Reset counter: 214
Mileage: 45959 km
Time Indication: 0
Date: 2103.14.13
Time: 00:13:33
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x32E1
Hex Value: 0x20BB
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
014 - Defective - Intermittent
Fault Priority: 0
Fault Frequency: 12
Reset counter: 214
Mileage: 45959 km
Time Indication: 0
Date: 2103.14.13
Time: 00:13:33
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3251
Hex Value: 0x1BBB
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 214
Mileage: 77985 km
Time Indication: 0
Date: 2106.14.31
Time: 00:00:19
Hex Value: 0x0003
Hex Value: 0x0002
Hex Value: 0x3211
Hex Value: 0x259C
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7FF9
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 086 K HW: 6R0 937 086
Component: BCM PQ25 M++4 H46 0256
Revision: BD046001 Serial number: 0343 175100810
Coding: 24B02BBF08A10000003008003D2B0CD00040410F60060000200000000000
Shop #: WSC 12345 123 12345
VCID: 448348237C5B
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R
Component: J386__TSG_FT 006 0903
Coding: 18BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T
Component: J387__TSG_BT 006 0902
Coding: 08BC30
3 Faults Found:
01334 - Door Control Module; Rear Right (J389)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 77985 km
Time Indication: 0
Date: 2106.14.31
Time: 00:06:44
01333 - Door Control Module; Rear Left (J388)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 77985 km
Time Indication: 0
Date: 2106.14.31
Time: 00:06:44
00936 - Electric Window Switch in Front Passenger Door (E107).
014 - Defective
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 77985 km
Time Indication: 0
Date: 2106.14.31
Time: 00:06:44
Component: VW10Airbag00K H09 0020
Revision: -------- Serial number: 003GX0040GN9
Coding: 00304B
VCID: 4A9F661B5E7F
Driver's Airbag Crash Sensor:
Serial number: 3572SRB40000B75CD96L
Passenger Side Airbag Crash Sensor:
Serial number: 3582SRB40000B714610W
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB400850KR89H49
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB405D6T8MGD0AY
1 Fault Found:
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 77985 km
Date: 2106.14.31
Time: 00:06:42
Part No SW: 6R0 920 860 E HW: 6R0 920 860 E
Component: KOMBI H04 0304
Coding: 140200
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 366722EB3A87
1 Fault Found:
9453074 - Fuel Level Sensor 1
B103E 1B [009] - Short to Plus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 77985 km
Date: 2106.14.31
Time: 00:06:38
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 086
Component: GW-K-CAN TP20 H46 0256
Revision: BD046001
Coding: 002200
VCID: F0EB54F39863
1 Fault Found:
01320 - Control Module for Climatronic (J255)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 214
Mileage: 77985 km
Time Indication: 0
Date: 2106.14.31
Time: 00:06:40
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EADF469BBEBF
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 31414
VCID: 2F69178FC5DD
1 Fault Found:
49-00 - No Communications
Address 56: Radio (J503) Labels: None
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio H52 0107
Revision: R0000000 Serial number: VWZAZ1N6313284
Coding: 0000020002
Shop #: WSC 00788 648 00255
VCID: 2A5F069BFE3F
What is your VCDS version?
What model
What engine
Brake size front, brake size rear are they drums
Do you have TPMS button in glovebox
Sent from my Nokia 6.1 Plus using Tapatalk
This is a 1.2 litre 60/70hp 3-cylinder engine with front 256 and rear 200mm drums and 5-speed manual transmission. Polo 6R LHD. TPMS not installed.
CBZB
210224C2216D00B4842B24E284D400400100
210224C2216D00B4842B24E284D400400500
CBZA
I'm guessing 210224DB216D00B4842B24E284D400401100
drewdoom
Drives: Polo 6R
Post by drewdoom »
Thanks Guys but coding is rejected.Car has a tpms button in glove box and rear drums also engine cose is CGPB I gues.I'm sorry about lack of info.BR
210224DB216D00B4842B24E284D400400700
drewdoom
Drives: Polo 6R
Post by drewdoom »
Thanks but still rejected.Honestly
i don't know how You calculate those numbers,my respect.
210224C2216D00B4842B24E284D400400300
210244C2216D00B4842B22E284D400400700
drewdoom
Drives: Polo 6R
Post by drewdoom »
Still the same not fit. I don't know why.Car was disasembled a bit.Immo was transferred but with old dash is the same not accepting coding.I'em very gratefull for Your help Guys.I can Try another attempts BR.
Can you show me the advanced ID of the immobiliser and the engine please?
drewdoom
Drives: Polo 6R
Post by drewdoom »
I will do tomorowm,but vcds shows that kind of data?
Yes it will :-)
