hello
i have polo gti 2013 (6R)
Could anyone give me some advice on how to remove center vents please?
is there any pictures / manual installation ?
thanks .
just remove the panel + 4 screws and pull out the radio ?
https://www.youtube.com/watch?v=fyqaXV2eXwE
center vents removal - help
Re: center vents removal - help
Audi vents have small holes drilled into each frame, and the plan is to use an "L" shaped tool to pull them out - the holes, if VW also provide this method of extraction are located quite far back into the housings.
- Platinum Member
You have to remove the radio, and remove the plastic bravket that goes over the whole thing because the vent is behind it.
in the video he removed the panel (trim) and 4 screwes .
thats all ?
thats all ?
It does not look as simple as it seems..
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Yes.
Well i had removed mine center vents to replace dummy buttons. It was quite work.
Removing trim, screw and radio is not difficult.
I don't recollect but cage is quite hard to move.
