center vents removal - help
kfirg
Drives: polo gti
Post by kfirg »
hello
i have polo gti 2013 (6R)
Could anyone give me some advice on how to remove center vents please?
is there any pictures / manual installation ?
thanks .
just remove the panel + 4 screws and pull out the radio ?
https://www.youtube.com/watch?v=fyqaXV2eXwE
Re: center vents removal - help
Audi vents have small holes drilled into each frame, and the plan is to use an "L" shaped tool to pull them out - the holes, if VW also provide this method of extraction are located quite far back into the housings.
You have to remove the radio, and remove the plastic bravket that goes over the whole thing because the vent is behind it.
kfirg
Drives: polo gti
Post by kfirg »
in the video he removed the panel (trim) and 4 screwes .
thats all ?
No!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
HI,
This would be helpful.
https://youtu.be/zwQ7kO_IlfQ
kfirg
Drives: polo gti
Post by kfirg »
It does not look as simple as it seems..
ag69
Post by ag69 »
Yes.
Well i had removed mine center vents to replace dummy buttons. It was quite work.
Removing trim, screw and radio is not difficult.
I don't recollect but cage is quite hard to move.
