Radio Removal Polo GTI 2016 (6C) adding a amp, cam
TrebleTA
- Drives: 2021-22 GTI+
Re: Radio Removal Polo GTI 2016 (6C) adding a amp, cam
This is what I got.
It's the 8 speakers wires and the black yellow and blue
TrebleTA
Sorry
I see it now written on the cables it's self, just the blue cable am unsure, i guess its for the Ariel, one I will test if it's powered constantly when radio is on for the amp on switch
Dink
- Platinum Member
- Drives: 2015 GTI
Looks like the blue wire has nothing coming from the radio so i doubt that will do anything.
TrebleTA
Not got round to the radio yet, but from fitting the dash cam I am now getting poor DAB radio signal was not before. I am guessing its the rear camera or I have knocked something.
I've had a look on the web and some are saying some magnets at both end if its the rear camera, anyone got any ideas?
Dink
- Platinum Member
- Drives: 2015 GTI
Think they might mean a ferrite core clipped over the cable.
One way to check is disconnect the cam and see if the signal returns to normal.
TrebleTA
Ferrite core clipped, Yes that's what I've seen. I will disable the rear camera to test first but anyone got a idea on what type of Ferrite core clip I would want, when i look online its hard to tell the size and I want them as sleek as possible as they will need to be hidden?
Also is the DAB Ariel on the roof or is it part of the back window?
TrebleTA
Anyone know were the DAB Ariel is loacted?
Dink
- Platinum Member
- Drives: 2015 GTI
Pretty sure it part of the roof aerial.
TrebleTA
I have sorted the radio losing signal with these clips.
https://www.ebay.co.uk/itm/TDK-CLIP-ON- ... SwOcpcG7nn
I got 4 of them put on the power cable and rear camera, it sorted it right out
Now on to fitting this amp.
I will check with vw about thr roof Ariel to make sure it not just for am-fm radio I was thinking of changing to a shark fin stickover booster.
TrebleTA
When I remove the glove box i am wondering do I remove the radio unite before or once the glove box is removed, lose?
TrebleTA
Ok ive part done the amp install. once I removed the glove box i was able to drop the glove box door and slide the radio part out, I was then able to remove the bulk cable but not the others, I could not see how to disconnect them. I modified the t harness see below with phono leads and run up the car, not sure on the fuse to use for the power, as i want it so power is there as lone as the keys are in the barrel - ignition.
Apart from the radio unit being a squeeze in the glove box the rest was easy enough
TrebleTA
I finally got all me bits and finished installing my amp speaker. Got some pictures
I forgot to take a picture of it connected in the boot so will add in time. I've also added a switch in the glove box to turn the amp on when needed.
On another note.. when I was taking the side panel bits of the car dash a clip dropped as a removed, not sure were this was from pictures below.
TrebleTA
None with any clues on the clip?
Dink
- Platinum Member
- Drives: 2015 GTI
It came from under the cover at the side of the dashboard.
TrebleTA
it just fellout so im not sure how to put back?
