![Image](https://i.imgur.com/0PVhaDk.jpg)
![Image](https://i.imgur.com/6eBpkd2.jpg)
so... powertrain (old IC CAN lines)
Tuesday,04,August,2020,23:00:39:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000 License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BC HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0002
Revision: --------
Coding: 210228E3217100B5842514E484D700401300
Shop #: WSC 00788 648 00255
VCID: 00085B4297984341E9-8054
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 060161479
Coding: 3CB02BB808E1240093380E916CEB0FD9DAC0672F608D30D0200000030000
Shop #: WSC 02737 534 00190
VCID: 68D863E29BE89B0141-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 080515 03 37 0059
Coding: 028877
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU004011200011991
Coding: 18BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 008 1611
Serial number: KU0KU005011200017885
Coding: 08BC30
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU010011200012406
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU009011200013136
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 20231629400567
Coding: 108001
Shop #: WSC 12345 123 12345
ROD: EV_EPHVA18VW250GPCS.rod
VCID: 3B72ECAEB2FEE099FC-806E
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX011W0JJ
Coding: 003232
ASAM Dataset: EV_AirbaVW10BAPVW250 A01001
ROD: N/A
VCID: 4A9CB96AED24491177-801E
Subsystem 1 - Serial number: 3575HRB4059124B2F99H
Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW10BAPVW250" (VW25)
Part No SW: 6R0 920 871 A HW: 6R0 920 871 A
Component: KOMBI H03 0505
Coding: 140E00
ASAM Dataset: EV_Komb_iUDS_VDD_RM09 A04113
ROD: N/A
VCID: 3460C7929FA02FE13D-8060
No ASAM data for: "EV_Komb_iUDS_VDD_RM09" (VW36 *)
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 108097 km
Time Indication: 0
Date: 2014.12.26
Time: 22:57:23
Component: IMMO H03 0505
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADC19EA8DE4A91157-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0110000001000000
ASAM Dataset: EV_HeadlReuglVWLWRPt 001004
ROD: N/A
VCID: 77FA309ECE5604F9D8-8022
No ASAM data for: "EV_HeadlReuglVWLWRPt" (VW25)
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:20)--------------------------
Franciswat wrote: ↑Tue Aug 04, 2020 10:11 pm
Everything works fine except for Coming Home; when I close the car the lowbeams don't light up.
VCDS settings seem OK. Leaving Home works correctly.
Have I always to manually flash before to get out of the car or it should work even without?
Thanks in advance.
Thank you for the coding, Fernando.BCM
New coding:
Enable Byte23 Bit 0.
RLS
New coding:
0228DD
Because of what mate?
Thank you for explanation Michael.RLS coding 028877 -> 0228DD --> 77 to DD is the correction index for your windshield.
BCM byte 23 bit 0 will activate the output of T73b/4 for terminal 58 (wire to your dimmer) IIRC for your BCM 7E0
In this case the very nice conversion of your windshield to RLS/dimming mirror mount.
The wire that feeds 12V to your dimmer (T6aa/3) needs to receive its power from the BCM. That's what T73b/4 does (or T73a/4, can't remember 100%).Thank you for explanation Michael.RLS coding 028877 -> 0228DD --> 77 to DD is the correction index for your windshield.
In simpler words for a inexperienced what does T73b/4 output activation lead? Thanks.
Thank you very much Michael! That was possible only thanks to many informations you and ciclo provided on this forum.In this case the very nice conversion of your windshield to RLS/dimming mirror mount.
Thanks now it's more clear for me!The wire that feeds 12V to your dimmer (T6aa/3) needs to receive its power from the BCM. (...) It's the click you hear when the low beam engages.
