Good. Have a look here as well, for some more info regarding coding of your ABS/ESP unit.
viewtopic.php?f=56&t=74520
Brake upgrade
Re: Brake upgrade
Ok i can see the brakes control unit no idea where to look advanced identification? Long coding ? Adaptation ? Basic setting ????
Sent from my SM-G935F using Tapatalk
Re: Brake upgrade
long coding please
Re: Brake upgrade
Control unit: 03 Brakes
System description: ESP9.0i front
Software number: 6R0907379AS
Software version: 0003
Hardware number: 6R0907379AS
Hardware version: H03
Serial number: --------------
ODX name: EV_Brake1ESP90iBOSCH
ODX version: 003020
Backup name:
Long coding:
21DD2885412400C284141469825200520905
Adaptations:
Hill-start assistant:
normal
XCP calibration protocol:
Not activated
Straight ahead brake stabilization:
activated
Roller test bench mode:
activated
Overboost in brake system:
120BAR
Hydraulic brake assistant:
normal
Expanded electronic differential lock:
medium
Rear axle hard braking:
activated
Tire pressure monitoring display:
2
Tire pressure monitoring display, tire selection:
0
Engine drag torque control:
activated
Activating and deactivating all development messages:
VW Messages:
Not activated
BOSCH Messages:
Not activated
Dynamic Messages 1:
Not activated
Dynamic Messages 2:
Not activated
Dynamic Messages 3:
Not activated
Advanced identification:
Number of programming attempts:
Bootloader:
1
Application:
0
Maximum number of possible update programming:
Bootloader:
1
Application:
90
Date of last coding:
Year:
0
Month:
0
Day:
0
FAZIT-identification:
Manufacture location index:
BPA-085
Day of manufacture:
24.09.13
Manufacturer- test stand number:
0060
Running manufacturer number:
1423
Diagnostic mode:
VW - diagnostic mode
VW/Audi part number:
6R0907379AS
SoftwareVersion:
0003
Serial number:
Hardware part number:
6R0907379AS
System description:
ESP9.0i front
Adaptation workshop code:
Device number:
0
Importer number:
0
Dealership number:
0
Date of last adaptation:
Year:
0
Month:
0
Day:
0
ASAM/ODX file identification:
ASAM/ODX file version:
003020
HardwareVersion:
H03
Coding workshop code:
Device number:
8
Importer number:
769
Dealership number:
1281
System abbreviation:
J104
Versions of software module:
Number of possible access authorizations:
Number Of Logins:
10
Programmability status:
Programmability:
programmable
Program consistency:
Program present
ODX version: 003020
Backup name:
Long coding:
Adaptations:
normal
Not activated
activated
activated
120BAR
normal
medium
activated
2
0
activated
VW Messages:
Not activated
BOSCH Messages:
Not activated
Dynamic Messages 1:
Not activated
Dynamic Messages 2:
Not activated
Dynamic Messages 3:
Not activated
Bootloader:
1
Application:
0
Bootloader:
1
Application:
90
Year:
0
Month:
0
Day:
0
BPA-085
Day of manufacture:
24.09.13
0060
1423
Diagnostic mode:
6R0907379AS
SoftwareVersion:
0003
Serial number:
6R0907379AS
System description:
ESP9.0i front
Device number:
0
Importer number:
0
Dealership number:
0
Year:
0
Month:
0
Day:
0
003020
HardwareVersion:
H03
Device number:
8
Importer number:
769
Dealership number:
1281
J104
Number Of Logins:
10
Programmability:
programmable
Program present
Re: Brake upgrade
This is your old coding: 21DD2885412400C284141469825200520905
Coding for 288 front, 232 rear: 21DD4485412400C284142269825200520905
Option 2: 21DD4C85412400C284143269825200520905
Re: Brake upgrade
Thank you very much, what would be the difference between option 1 and option 2 ???
Re: Brake upgrade
It depends on the exact parameterization of your ABS module. The effect is the same.
Re: Brake upgrade
does VCDS provide an explanation for each of those Byte/Bits ? because i see on my OBD11 there is no description what so ever...
Im trying to figure out how to only change the byte 2 and im failing to do so.
And by the way i saw from the XLS that byte 2 44 is for 200mm rear drums so its wrong, i have 232mm discs so it must be changed to (48 - 288mm front discs and 232mm rear discs)
Re: Brake upgrade
No VCDS does no explanation either. It is up to the enthousiasts to find the pattern.
Yes you found my easter egg, well done. Please try 48 for byte 2 and 12 for byte 10.
21DD4885412400C284141269825200520905
Re: Brake upgrade
lol easter egg, imagine i would be on some guys roof if i tried to brake with that coding....
Re: Brake upgrade
No not really
