Address 01: Engine Labels: 03L-906-022-CAA.clb
Control Module Part Number: 03L 906 019 GF HW: 03L 907 309 M
Component and/or Version: R4 2,0L EDC H44 3312
Software Coding: 01114012232400080000
Work Shop Code: WSC 02736 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019GF 003002 (VN75)
ROD: EV_ECM20TDI01103L906019FG_003.rod
VCID: 75E154D3D4C13F2E28-8020
2 Faults Found:
4481 - Cruise Control Switch (E45)
P0568 00 [039] - Implausible Signal
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 32 °C
Intake air temperature: 33 °C
Ambient air pressure: 920 mbar
Voltage terminal 30: 12.320 V
Cruise Control System (CCS): switch position-Bits 0-7: 192
Cruise Control System (CCS): status-Bits 0-7: 8
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Engine control module reset status-Bits 0-7: 59
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [039] - -
Fault Priority: 2
Fault Frequency: 5
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 30: 12.340 V
Readiness: 0 0 0 0 0
VW Transporter T5.1 CC retrofit
- Shadow109
- Drives: Vw t5.1 2013
Hello, I have installed a cruise control system to my transport 2013, I connected all the wires, then activated cruise control system throw VCDS, but I get 2 errors
Re: VW Transporter T5.1 CC retrofit
Please post a full scan and describe precisely how you wired the system
- Shadow109
1. I have connected 6 wires to the steering connector
2. 4 wires to the white bcm connector
3. 1 wire to the relay as described
4. 2 wires to the fuse box
Then I put a 5 amp fuse there
5. The final wire was to the E-box under the battery
I will post a full scan later
- 370B4F5E-E0F6-4F5E-96CD-44EDE201D56E.jpeg (728.98 KiB) Viewed 7961 times
I think I found the mistake. 28 and 29 are switched
- Shadow109
I have noticed this after I wired, then switched them back
I am not sure about the wire in the e-box
Yes it is indeed possible the wire to the e-box is wrong
- Shadow109
Friday,18,September,2020,19:23:25:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544 License Plate:
Mileage: 188780km-117302mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: WV1ZZZ7HZDH036544 Mileage: 188780km-117302miles
10-Park/Steer Assist -- Status: Sporadic communication error 1000
56-Radio -- Status: Not registered 0011
Address 01: Engine (J623-CAAA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GF HW: 03L 907 309 M
Component: R4 2,0L EDC H44 3312
Revision: 26H44--- Serial number: 00000000000000
Shop #: WSC 02736 790 50316
2 Faults Found:
P0568 00 [047] - Implausible Signal
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
U1112 00 [047] - -
Fault Priority: 2
Fault Frequency: 7
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A70A9B24A79175696210
Shop #: WSC 02736 790 49152
VCID: 3A7B87EFB55F905605-806E
6 Faults Found:
01164 - ESP Operation
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 187772 km
Time Indication: 0
Date: 2015.02.03
Time: 03:41:22
Count: 17664
Count: 4097
Count: 301
Count: 508
01542 - Yaw Rate Sensor (G202)
012 - Electrical Fault in Circuit - Intermittent
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Mileage: 187935 km
Time Indication: 0
Date: 2015.02.03
Time: 10:46:34
Count: 21248
Count: 257
Count: 257
Count: 766
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
Fault Status: 00100011
Fault Priority: 2
Fault Frequency: 11
Reset counter: 178
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:12:38
Count: 16512
Count: 4353
Count: 300
Count: 512
014 - Defective
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 3
Reset counter: 131
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:29:26
Count: 16384
Count: 4353
Count: 292
Count: 764
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 2
Reset counter: 131
Mileage: 187772 km
Time Indication: 0
Date: 2015.02.03
Time: 03:41:26
Count: 17920
Count: 257
Count: 293
Count: 766
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:29:26
Count: 16384
Count: 4353
Count: 8215
Count: 764
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BM HW: 7E5 907 047 BM
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 7BF542EBF2E5695E5E-802E
2 Faults Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Mileage: 186991 km
Date: 2020.09.07
Time: 10:20:19
13701440 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 187415 km
Date: 2020.09.11
Time: 00:01:16
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0254
Revision: BO047001 Serial number: 0429 014120346
Coding: A8A0393A0E212012002008102C2B8CD40000430F60040000320000000000
Shop #: WSC 02756 790 12345
VCID: 397998E3B0599B4E0C-806C
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
2 Faults Found:
01758 - Bulbs for Brake Lamps
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 254
Reset counter: 141
Mileage: 187771 km
Time Indication: 0
Date: 2015.02.03
Time: 02:41:50
01179 - Incorrect Key Programming
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 187771 km
Time Indication: 0
Date: 2015.02.03
Time: 02:42:41
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261631000160
Coding: 108009
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71E960C3A0A9130EF4-8024
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00DDD0.
Coding: 000000000000000000000000000000003033
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356194D394417F2EE8-8060
3 Faults Found:
9437211 - Igniter for Driver's Airbag
B1000 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 188001 km
Date: 2020.09.12
Time: 22:29:27
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2020.09.18
Time: 00:08:23
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2020.09.18
Time: 00:08:23
Part No SW: 7E0 920 860 G HW: 7E0 920 860 G
Component: KOMBI H06 0605
Coding: 160201
VCID: 2C57B1B7470B3EE687-8078
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0254
Revision: BO047001
Coding: 042200
VCID: 70EF65C7A3A31A06FB-8024
2 Faults Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 115
Reset counter: 255
Mileage: 187415 km
Time Indication: 0
Date: 2015.02.02
Time: 00:32:28
03075 - Parallel Parking Assistance Control Module (J791)
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 33
Reset counter: 181
Mileage: 187526 km
Time Indication: 0
Date: 2015.02.02
Time: 16:25:35
Component: IMMO H06 0605
Serial number:
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 03:08)--------------------------
www.Ross-Tech.com
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
U1112 00 [047] - -
Fault Priority: 2
Fault Frequency: 7
Mileage: 188789 km
Date: 2000.00.00
Time: 00:00:00
Revision: 00H43001
6 Faults Found:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 187772 km
Time Indication: 0
Date: 2015.02.03
Time: 03:41:22
Count: 17664
Count: 4097
Count: 301
Count: 508
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Mileage: 187935 km
Time Indication: 0
Date: 2015.02.03
Time: 10:46:34
Count: 21248
Count: 257
Count: 257
Count: 766
Fault Priority: 2
Fault Frequency: 11
Reset counter: 178
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:12:38
Count: 16512
Count: 4353
Count: 300
Count: 512
014 - Defective
Fault Priority: 2
Fault Frequency: 3
Reset counter: 131
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:29:26
Count: 16384
Count: 4353
Count: 292
Count: 764
Fault Priority: 2
Fault Frequency: 2
Reset counter: 131
Mileage: 187772 km
Time Indication: 0
Date: 2015.02.03
Time: 03:41:26
Count: 17920
Count: 257
Count: 293
Count: 766
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 188001 km
Time Indication: 0
Date: 2015.02.03
Time: 22:29:26
Count: 16384
Count: 4353
Count: 8215
Count: 764
Revision: 00001010
Coding: 0000000002
2 Faults Found:
U1113 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 6
Mileage: 186991 km
Date: 2020.09.07
Time: 10:20:19
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 187415 km
Date: 2020.09.11
Time: 00:01:16
2 Faults Found:
011 - Open Circuit
Fault Priority: 2
Reset counter: 141
Mileage: 187771 km
Time Indication: 0
Date: 2015.02.03
Time: 02:41:50
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 187771 km
Time Indication: 0
Date: 2015.02.03
Time: 02:42:41
Coding: 108009
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 188001 km
Date: 2020.09.12
Time: 22:29:27
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2020.09.18
Time: 00:08:23
Fault Priority: 2
Fault Frequency: 1
Mileage: 188789 km
Date: 2020.09.18
Time: 00:08:23
Coding: 160201
Revision: BO047001
Coding: 042200
2 Faults Found:
000 - -
Fault Priority: 2
Reset counter: 255
Mileage: 187415 km
Time Indication: 0
Date: 2015.02.02
Time: 00:32:28
Fault Priority: 2
Fault Frequency: 33
Reset counter: 181
Mileage: 187526 km
Time Indication: 0
Date: 2015.02.02
Time: 16:25:35
Serial number:
Address 56: Radio
Cannot be reached
- Shadow109
I forgem to mention I have broke this part
Tomorrow I will replace it
I would recommend to check the wiring to the ECU/E-Box.
- Shadow109
Thanks iichel, all the wiring was good, 1 issue was fixed by vsdc, and the other has disappeared when I disconnect and reconnect the stalk connector
Just did the install, got this error.
- E374583F-891F-4D32-96E1-EAFF36D904B7.jpeg (5.11 MiB) Viewed 6235 times
- 1B3FA874-DBD4-49BC-9291-1EBC77349E3F.jpeg (2.55 MiB) Viewed 6235 times
- Shadow109
What coding did you make ?
Can you post an autoscan
Bcm byte 17 bit 7
Engine byte 5 bit 5
Thats all i have done.
Will try to post a scan tomorrow, comp is at work.
Engine byte 5 bit 5
- A20A0296-E0F4-4B9F-BDDD-B9EF71129AE2.jpeg (6.1 MiB) Viewed 6178 times
polos4
- Drives: VW t5.1, seat leon mk2
Hi, did you manage to fix this error?
- Shadow109
I think it was coding, post an autocsan so we could help you
