Polo 6R ABS CODING
Re: Polo 6R ABS CODING
I don't know, sorry.
Heyy lichel In this way, error happens. Do you know what does it mean? Multimedya 5F
- IMG_20200921_170910.jpg (1.12 MiB) Viewed 3185 times
Without an extended view, it's very difficult to say what exactly is happening.
Does this error dissappear after you put back your ABS coding? Perhaps you can share a full scan of the vehicle?
When I encode it for multimedia esc menu, I get this error. Maybe something has opened defixient, can you please help me?
don't think it's a mistake to do with Abs coding.
5F I found these ref to the brake:
Car_Function_Adaptations_Gen2:
menu_display_Brake_Function: activated
menu_display_Brake_Function_clamp_15_off: Not activated
menu_display_Brake_Function_over_threshold_high: activated
menu_display_Brake_Function_standstill: Not activated
menu_display_Brake_Function_after_disclaimer: Not activated
Car_Function_List_BAP_Gen2:
Brake_0x26: activated
Brake_0x26_msg_bus: Databus drivetrain
Perhaps check this one in your ABS unit:
MAS00120-Anti-slip regulation (ASR) activated 1
This is from a polo 6c with ESP off via 5F:
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated 60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated 60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated 60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated 60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated 60
Source:
https://forums.ross-tech.com/index.php? ... ost-106160
Source:
Not active multimedya Low probability of vesion I guessI guess
thx For everything
legendaryzz
- Drives: 6r
Update : When to the vw dealer. But they also couldnt change it. To bad.iichel wrote: Sun Sep 20, 2020 4:44 pmThis is indeed unusual.legendaryzz wrote: Sun Sep 20, 2020 4:41 pmBoth ways it gives error 22. Conditions not correct or request sequence error.iichel wrote: Sun Sep 20, 2020 1:36 pm Strange. I believe your updated coding should be:Perhaps type it manually or only change byte 2 & 10?Code: Select all
210248E3216F00B3842712E984D100401300
I also tried with 02 instead of 00 (for gti model)
Only the 28 byte 2 / 14 byte 10 is accepted. Very strange.
yeah I think the 6R 1.2 TSI engines with 105hp and 90hp have the same ABS coding in terms of engine type etc. Oh well, one of those things.... sorry it didn't work out.
Salut, je besoin codage abs pour polo sedan indian d'un moteur 1.4 essence année 2013
Vin:WVWZZZET083814
6R0907379AQ
ABS 9.0 front
Merci d'avance
Vin:WVWZZZET083814
6R0907379AQ
ABS 9.0 front
Merci d'avance
I'm going to need you to communicate in English please and I'm going to need more information:
LHD/RHD
Engine
Gearbox
ESP
TPMS
VIN
Why is the coding lost?
LHD/RHD
Engine
Gearbox
ESP
TPMS
VIN
Polo berline
made in india
Gearbox manuelle
made in india
Gearbox manuelle
- IMG_20201022_130144.jpg (2.59 MiB) Viewed 2997 times
- IMG_20201022_130222.jpg (2.02 MiB) Viewed 2997 times
Why was the coding lost?
Change ecu + instrument
LHD/RHD --> ???
Engine --> CLPA
Gearbox --> Manual
ESP --> No
TPMS --> ???
VIN --> WVWZZZ60ZET083814
Why is the coding lost? --> new instrument and cluster
I need to know LHD/RHD and TPMS
LHD/RHD --> ???
Engine --> CLPA
Gearbox --> Manual
ESP --> No
TPMS --> ???
