Airbag Problem after RVC Emblem retrofit
lroldaoj
Drives: Polo AW 2019
Post by lroldaoj »
Hello guys..!!
Today I retrofitted the reverse flip camera logo. It gave a lot of work... But it is pretty cool.
I wanted to ask about something. When I was installing the camera I removed one of the side trim panels of the dashboard (from the passenger side), which has an airbag connector, you can see the piece in one of the images. I passed the ignition with this panel disconnected and I saw an alert on the dash screen saying that there is a problem with the airbag. I didn't worry because I assumed it should be because this panel was disconnected.
However, after connecting and fitting all trim plastic panels again, I still have this alert on the dash screen. Any advice? I don't know how to remove it.. It's weird that it keeps showing the error and I checked the connector was correctly fitted.
This is the plastic panel I removed and fit back again:
20201116_122758 (1).jpg (2.89 MiB) Viewed 1915 times
This is the alert on the dash screen:
20201116_213333 (1).jpg (3.04 MiB) Viewed 1915 times
I thought the alert would disappear after connecting back the trim plastic piece. But it is not the case.
Thanks guys. You are an awesome community. Best regards from France.
ho8882000
Drives: 2019 (AW)
Re: Airbag Problem after RVC Emblem retrofit
Post by ho8882000 »
I think once the Airbag Control Module logged a fault, it will need something like VCDS to access the Airbag Control Module and clear the fault code.
vc-10
Post by vc-10 »
Yup- once logged, it needs to be cleared properly to get rid of the warning. Not sure if you need a proper VW scan tool or if any regular scan tool can do it though.
lroldaoj
Post by lroldaoj »
Thanks @vc-10, @ho8882000. I have to do the 30k km service soon, I will ask people from VW to remove it then.
lroldaoj
Post by lroldaoj »
I think for the future, always remove the battery +VE lead and switch on the ignition for 5 minutes, then switch the ignition off (to drain any stored charge) before working on any part of the Airbag system.
lroldaoj
Post by lroldaoj »
Yes, I should have done that haha.. Thanks for the advice :D
penguinemit
Drives: Polo Aw
Post by penguinemit »
I did the same when fitting a RVC. Cleared the fault code in VCDS and all good. Didn't need to log into any modules.
