Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by MaDwArLoCk »
Paride89 wrote: Fri Oct 18, 2019 1:22 pm
Thank you MaDwArLoCk Best way to use the mfa+ is the mfsw or the stalk?
definitely MFSW
Paride89
Drives: Polo 6r 1.6tdi cl
Post by Paride89 »
MaDwArLoCk wrote: Fri Oct 18, 2019 3:15 pm
definitely MFSW
Sorry for being off topic, a quick question, do you know if the Golf 6 mfsw fits in the polo 6r?
gelotus
Drives: 6r 1.6 TDI Highline
Post by gelotus »
Hi guys, I've got a amarok cluster 2h0920871b for retrofitting in my 6r. It have a 1009 sw and i cannot set immo data on it, so I want to downgrade with 0729 sw. Could someone explain me how to do that with odis e? Thank you
Paride89 wrote: Fri Oct 18, 2019 3:42 pm
definitely MFSW
Yes it does
smg_shardul
Drives: Polo 6R
Post by smg_shardul »
gelotus wrote: Wed Nov 18, 2020 11:03 pm Hi guys, I've got a amarok cluster 2h0920871b for retrofitting in my 6r. It have a 1009 sw and i cannot set immo data on it, so I want to downgrade with 0729 sw. Could someone explain me how to do that with odis e? Thank you
What problem you are facing to set immo data ?
I have 1009 FW and successfully installed in 6R.
1009 is latest firmware, people are upgrading to 1009 and you are downgrading...😀
gelotus
Post by gelotus »
With my tools I cannot set immo on that version, only until 07xx.
So my question is always valid
smg_shardul
Drives: Polo 6R
gelotus wrote: Thu Nov 19, 2020 9:07 pm With my tools I cannot set immo on that version, only until 07xx.
Why don't you try to install it on oddis?
Did I say that your question is invalid ?
gelotus
Post by gelotus »
Tried on bench with odis e and with FFed immo block in eeprom, with frf says no valid session with VWVIN and VN81X, with odx extracted with BV_DashBoardUDS added in LAYER-REF the flash starts and immediately halted with unknown error, both with VWVIN and VN81X.
blue_ming
Drives: 6R
Post by blue_ming »
smg_shardul wrote: Thu Nov 19, 2020 7:30 pm
Hi, man, is it possible to share your 1009 sw file?
gelotus
Post by gelotus »
blue_ming wrote: Thu Nov 26, 2020 6:33 am Hi, man, is it possible to share your 1009 sw file?
If you mean the eeprom dump I'll could share it, no problems.
smg_shardul
Drives: Polo 6R
gelotus wrote: Sun Nov 29, 2020 12:03 pm
I have swapped its FW to 6R0
You can contact Madwarlock for the same only eeprom dump won't work.
SimonPoole
Post by SimonPoole »
I am looking at fitting a Toledo cluster into a Polo 6R.
What physical modifications are required to do this please?
I don't want to go for the 6C look, so do I just need to change the plastic trim at the front for the one from the Polo 6R?
If I do this, do I still need to move the LEDs for the indicators?
Thanks.
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
I have a toledo and my cluster is 6JA920840E with 0711 firmware , I am going to retrofit blind spot assit.
does anyone know witch bits to change on eeprom to activate menu and indicators
SimonPoole wrote: Thu Dec 10, 2020 9:26 pm I am looking at fitting a Toledo cluster into a Polo 6R.
Thanks.
It seems that the rear part is the same physicaly so it could work without modifications.
mahesh_parmar
Drives: Polo 6R
Post by mahesh_parmar »
Polo 6R 1.2 TDI
I buy Amarok cluste
I want to install in polo can you help me for editing Brake fluid , speed signal , boot lid , fuel tank , low fuel warning , picture
Sw/ 1009
Hw/ h04
help me
nithishsabapathi
Drives: Ameo TDI (polo 6r compact sedan!)
Post by nithishsabapathi »
Hello Everyone,
I know I am late to the party but still asking, I have a seat toledo cluster which I am looking to fit in my polo 6R, It has an old firmware 06xx, Where can I find/buy new firmware files and can it be updated over ODIS or need any special tools for the upgrade>
