definitely MFSWParide89 wrote: Fri Oct 18, 2019 1:22 pm
Thank you MaDwArLoCk Best way to use the mfa+ is the mfsw or the stalk?
Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
MaDwArLoCk
- Drives: Cross Polo 2010 TSI
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Sorry for being off topic, a quick question, do you know if the Golf 6 mfsw fits in the polo 6r?MaDwArLoCk wrote: Fri Oct 18, 2019 3:15 pmdefinitely MFSWParide89 wrote: Fri Oct 18, 2019 1:22 pm
Hi guys, I've got a amarok cluster 2h0920871b for retrofitting in my 6r. It have a 1009 sw and i cannot set immo data on it, so I want to downgrade with 0729 sw. Could someone explain me how to do that with odis e? Thank you
Yes it doesParide89 wrote: Fri Oct 18, 2019 3:42 pmSorry for being off topic, a quick question, do you know if the Golf 6 mfsw fits in the polo 6r?MaDwArLoCk wrote: Fri Oct 18, 2019 3:15 pmdefinitely MFSWParide89 wrote: Fri Oct 18, 2019 1:22 pm
smg_shardul
- Drives: Polo 6R
What problem you are facing to set immo data ?gelotus wrote: Wed Nov 18, 2020 11:03 pm Hi guys, I've got a amarok cluster 2h0920871b for retrofitting in my 6r. It have a 1009 sw and i cannot set immo data on it, so I want to downgrade with 0729 sw. Could someone explain me how to do that with odis e? Thank you
I have 1009 FW and successfully installed in 6R.
1009 is latest firmware, people are upgrading to 1009 and you are downgrading...
With my tools I cannot set immo on that version, only until 07xx.
So my question is always valid
smg_shardul
- Drives: Polo 6R
Why don't you try to install it on oddis?gelotus wrote: Thu Nov 19, 2020 9:07 pm With my tools I cannot set immo on that version, only until 07xx.
Did I say that your question is invalid ?
Tried on bench with odis e and with FFed immo block in eeprom, with frf says no valid session with VWVIN and VN81X, with odx extracted with BV_DashBoardUDS added in LAYER-REF the flash starts and immediately halted with unknown error, both with VWVIN and VN81X.
Hi, man, is it possible to share your 1009 sw file?smg_shardul wrote: Thu Nov 19, 2020 7:30 pmWhat problem you are facing to set immo data ?gelotus wrote: Wed Nov 18, 2020 11:03 pm Hi guys, I've got a amarok cluster 2h0920871b for retrofitting in my 6r. It have a 1009 sw and i cannot set immo data on it, so I want to downgrade with 0729 sw. Could someone explain me how to do that with odis e? Thank you
1009 is latest firmware, people are upgrading to 1009 and you are downgrading...![]()
If you mean the eeprom dump I'll could share it, no problems.
smg_shardul
- Drives: Polo 6R
- SimonPoole
I am looking at fitting a Toledo cluster into a Polo 6R.
What physical modifications are required to do this please?
I don't want to go for the 6C look, so do I just need to change the plastic trim at the front for the one from the Polo 6R?
If I do this, do I still need to move the LEDs for the indicators?
Thanks.
Thanks.
- til3tsio
- Drives: Seat Toledo KG
I have a toledo and my cluster is 6JA920840E with 0711 firmware , I am going to retrofit blind spot assit.
does anyone know witch bits to change on eeprom to activate menu and indicators
It seems that the rear part is the same physicaly so it could work without modifications.SimonPoole wrote: Thu Dec 10, 2020 9:26 pm I am looking at fitting a Toledo cluster into a Polo 6R.
Thanks.
mahesh_parmar
- Drives: Polo 6R
Polo 6R 1.2 TDI
I buy Amarok cluste
I want to install in polo can you help me for editing Brake fluid , speed signal , boot lid , fuel tank , low fuel warning , picture
Sw/ 1009
Hw/ h04
help me
I buy Amarok cluste
Sw/ 1009
Hw/ h04
help me
nithishsabapathi
- Drives: Ameo TDI (polo 6r compact sedan!)
Hello Everyone,
I know I am late to the party but still asking, I have a seat toledo cluster which I am looking to fit in my polo 6R, It has an old firmware 06xx, Where can I find/buy new firmware files and can it be updated over ODIS or need any special tools for the upgrade>
