Hello
New to the group
Not long brought polo gti 6c 2017
Head lights where busted so brought a new set from vland
But wasnt aware that the plugs where different from a gti to other models
Is there any sort of wiring harness or plug adaptors that can get to joing the two?
Thanks for any help
Headlights
Headlights
- This is the headlight plug
- 254EFD3E-98B5-43A4-8404-F6EC72818100.jpeg (581.25 KiB) Viewed 1231 times
- This is plug on my car
- 346336EA-3C5E-47A9-B113-30E247E64002.jpeg (2.3 MiB) Viewed 1231 times
Re: Headlights
Looks like you bought a headlight with halogeen bulbs while your gti has led headlights
Re: Headlights
The new head light has led to
Nothing i csn do to sort it?
Re: Headlights
Any chance you could post a picture of the new headlight with some kind of part number?
Re: Headlights
This is head light i brought
- 191599E2-7138-4BF7-B882-97885FF1CC65.jpeg (283.3 KiB) Viewed 1196 times
Re: Headlights
Theres no part number on the site or headlight
Re: Headlights
So there is your problem, I guess. You bought a pair of aftermarket headlights with different connectors than the original LED headlights. That's not going to fit I'm afraid. Perhaps you can get away with just an adapter to convert from 14 to 10 pin, otherwise you might also need to re-code your BCM.
Re: Headlights
Ok cheers
Thanks for ya help mate! Much appreciated
