Help fitting Reverse Camera with RCD330 - Canbus
Mocro
Drives: Polo 6C 1.4TDI 105HP
Re: Help fitting Reverse Camera with RCD330 - Canbus
Post by Mocro »
patil wrote: Mon Jan 04, 2021 3:24 pm Hello Damon/ Macro..
Can you post the pictures and wiring kit of the reverse camera you people are trying to install. I can't see the camera picture posted earlier.
Thanks.
Mocro
Post by Mocro »
@ iichel
I coded that I have Rear view camera, when i turn off byte 19 bit 4 then I will see the OPS.
This is the fault code.
1 Fault Found:
6720 - Rear View Camera
B1102 31 [009] - No Signal
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 100
Mileage: 64470 km
Date: 2021.01.03
Time: 12:11:45
Voltage terminal 30: 11.1 V
i guess you'll have to figure out why the radio isn't receiving a signal from the rvc
Mocro
Post by Mocro »
Damon wrote: Sun Dec 27, 2020 5:42 pm Okay got it working at front of car.
However I’ve put the bracket with the camera in the registration light but how do feed the cable off the camera into the boot from the bracket?
I push the cable through but can’t seee where it’s coming out?
Remove this
You will see a round rubber thing with wiring remove the rubber
Put a cable in the license plate light holder
You will see the cable is coming to the rubber whole, its little bit difficult but the cable is coming to the rubber whole
patil
Post by patil »
Thanks for the picture👍
Please do as I suggest and tell me the results.
1. Please feed the camera power with +30
2. Ground connect wherever you want, but I suggest you to connect ground in front eg.. steering column ground point.
3. Connect can high and can low to your quadlock can wires as iichel suggested.
4. Coding is not required for such type of cameras.
5. In address 10, select automatic in ops display.
This should set everything right.
Good luck👍
Mocro
Post by Mocro »
iichel wrote: Mon Jan 04, 2021 4:51 pm i guess you'll have to figure out why the radio isn't receiving a signal from the rvc
Yes iknow, I measured the cable up to the plug of the camera. There is coming power.
it is possible that i am not getting video through canbus cable?
Mocro
Post by Mocro »
patil wrote: Mon Jan 04, 2021 5:09 pm Thanks for the picture👍
Good luck👍
But I have a 6C when i dont coded byte19 bit 4 i dont see anything only the ops
Where in address 10 can I find the option automatic OPS?
I will do it tommorow, thank you
I will let you know the result.
Video is not transmitted through the canbus. It needs the canbus for the dynamic lines. The video is transmitted to the blue block of the quadlock.
patil
Post by patil »
Mocro wrote: Mon Jan 04, 2021 5:25 pm
Good luck👍
Slight correction to my suggestion.
I completely overlooked that you have rcd330 installed. After completing the wiring part, the camera must be coded.
Go to address 56, and enable byte3, bit6
Also remember, the power supply to camera must be +30 and not +15.
My sincere apologies for my suggestion number 4 :oops:
Patil, he has a Discover Media MQB in his Polo 6C, not an RCD330.
Mocro
Post by Mocro »
I put the ACC to fuse 19
patil
Post by patil »
iichel wrote: Mon Jan 04, 2021 5:46 pm Patil, he has a Discover Media MQB in his Polo 6C, not an RCD330.
Oh I got confused iichel. Thanks for pointing it out :mrgreen:
So here is the coding for both Damon & Mocro
For RCD 330: address 56, byte3, bit6 should be enabled.
For MIB2 Discover media: address 5F: byte19, bit4 should be enabled.
Wiring part applies same for both. :)
patil
Post by patil »
Look in adaptation channels of address 10.
After complete installation of wiring, enable byte19, bit4
patil
Post by patil »
Hope this helps. :wink:
Mocro
Post by Mocro »
I measured the cable with multi meter and the cable is ok, I also do not see other fault codes except the camera.
I plugged an other camera this also doenst work, with an other plug cable (blue).
Do you guys have some ideas??
