mfsw on polo 6r
Re: mfsw on polo 6r
Hi guys, I have this BCM 6r0937087P which kind of MFSW is better adattable?
Re: mfsw on polo 6r
you can fit any mfsw you like
but on the MQB wheels (5Q0... 6C0...) the button illumination will not work.
Re: mfsw on polo 6r
Thank you so much.I hope in your answer. Which steering wheel is better Compatibile in my car? (with also the lights) can you send me the codes or the images of the model? Thanks
Re: mfsw on polo 6r
You can use the 6r wheel with the buttons only left. Or the golf Mk6 steering wheels with buttons on both sides.
- mirceaculita
- Drives: 6R 1.2TDI 75hp
Re: mfsw on polo 6r
Would the mk6 mfsw retrofit still require new wires to be added for a car without mfsw from the factory?iichel wrote: Wed Dec 30, 2020 10:20 pm You can use the 6r wheel with the buttons only left. Or the golf Mk6 steering wheels with buttons on both sides.
Re: mfsw on polo 6r
yes, it always does if your car does not have a factory mfsw
Re: mfsw on polo 6r
Hi, I would like to install a steering wheel of Scirocco with the paddles of gears, but My car hasn't the automatic gear. CAN I install it? Thanks a lot.
Re: mfsw on polo 6r
Yes no probleem
Re: mfsw on polo 6r
Hi guys, finally I found the MFSW for mi polo 6r. It is the normal steering wheel of the polo 6c. Could you please help me to fit it? An other answer: this MFSW was from a vw Passat, can it be fixed on polo? Thanks
- IMG-20210205-WA0011.jpeg (1.4 MiB) Viewed 4435 times
Re: mfsw on polo 6r
Hi guys. Finally I found the MFSW for my polo 6r, I have some answer to ask. The MFSW was installed on a vw Passat. Is It the same of the polo 6c? How can I install it without any problem? I have also the cruise control and I would like to put it on the botton of the WHEEL. I will send also the pictures of it and of my bcm. Thanks to everyone, hopefully that you answer me.
- received_400428854599793.jpeg (212.4 KiB) Viewed 4435 times
Re: mfsw on polo 6r
No it's not the same wheel, I think it might have white lights and not red lights like on Polo 6C.
- SimonPoole
Re: mfsw on polo 6r
My Polo 6R has the radio controls on the LHS of the steering wheel.
If I fitted an MFSW wheel from a Golf 6 would there be any extra wiring required, or would it be plug and play?
The car currently has MFA controls on the right hand stalk.
Re: mfsw on polo 6r
plug and play, but I'd recommend to disconnect the TRIP wires in the back of the cluster to avoid conflict between MFSW and TRIP input.
- SimonPoole
Re: mfsw on polo 6r
Great, thanks.iichel wrote: Sat Feb 06, 2021 6:46 pm plug and play, but I'd recommend to disconnect the TRIP wires in the back of the cluster to avoid conflict between MFSW and TRIP input.
Do you know if the airbag will be the same for both wheels?
Re: mfsw on polo 6r
Looks like it is not
