Mocro wrote: Sun Jan 10, 2021 4:33 pm
I measured the cable with multi meter and the cable is ok, I also do not see other fault codes except the camera.
I plugged an other camera this also doenst work, with an other plug cable (blue).
Do you guys have some ideas??
This says that you are doing something wrong. Did you follow my suggestions? Please post the full vcds scan. Also kindly show us your wiring connections.
Thanks.
Mocro wrote: Sun Jan 10, 2021 9:51 pm
I had a fuse tap but also with fuse tap it doenst work, i did this totday because with fuse tap the fuse wont get fully in the fusebox.
The reason why it sais it have 11.1 V is because the car wasn’t started. When i start the car it wil go to 12v.
Iknow that the way i do is risky but it was for the test.
I think it it something with the rvc cable to the MIB2. Is it possible that the pins in the MIB2 are broken inside or something?
The weirdest thing is that everything worked fine but after a few km it doesnt work
I highly suspect your blue T12 connector of quadlock. The T12/12 black wire is partially out of its place, inspect it. And also provide clean +30 power to RVC for your tests.
I hope your boot is closed when you are making tests.
I doubt the MIB2 pins are broken, they are strong and hard. Anyway inspect.
Do complete thorough examination of your wiring.
Kindly post the requested full VCDS auto scan for clarity and to avoid confusions.
Thanks.
That is my microphone I replace other t12 connector of the quadlock now everything is on its place. I inspect everything, the fuse is +30.
The black and yellow cable is for RVC, T12/7 Black and T12/1White is for Microphone. You see that T12/7 is little bit out of his space. But T12/12 and T12/6 is good.
1556 - Regelapparaat defect
B2000 87 [009] - Geen boodschap
This fault code is because i enable carplay by a friend, but the camera was always working with this fault code
Here is the full scan, but is in dutch.
Ok Mocro, thanks for the autoscan. It would have been better if scan was in English, anyway it's ok.
If wiring is checked and everything is proper, then please check output at T12/6& T12/12 blue connector using multimeter. And also in address 10 adaptations, try setting reverse camera as display for park assist. Also I would suggest to connect can lines directly to MIB2 can wires rather than using converter supplied by the seller.
I've installed similar camera as yours, works well for me on MIB2. But my wiring connection is slightly different. I tapped +30 power from MIB2 power with inline fuse and ground from +31( MIB2 ground) and canlines directly connected as I mentioned above.
Please also do check your boot lock switch wiring for any short circuit.
patil wrote: Wed Jan 13, 2021 1:21 pm
Thank you, How can I connect the the can lines directly?
It has 2 wires, do i have to solder it or something else?
I also testes the camera without the canbus converter from the seller and using the OEM cable of the canbus, but also it didn't work.
I think the +30 and the ground is'nt the problem, i always had a camera never was a problem until i changed for a new camera with can lines.
I will check this week the blue connector t12/6 and t12/12.
Mocro wrote: Wed Jan 13, 2021 10:57 pm
Hello Macro,
As far as I know, it's the canbus which regulates the power input, video output and dynamic lines of such cameras. I don't know exactly what type of canbus feeds your MIB2 on 6C VW 26. The electricals of 6C is different from 6R. Take help from experts on 6C about canbus.
You can connect to canbus wires of MIB2 by splicing the wires or using the Scotchlok connectors. Before doing that, do output tests on T12/ 6 and 12. I would recommend you to use quadlock extension connector and splice the wires of extension connector for canbus connection. This way you can avoid splicing factory wires.
Please do post adaptation map of your 5F and address 10 in English, I will have a look.
Don't loose heart, I am confident that you can solve the problem
Everybody thanks for the input, but I am going to remove the camera and going to OEM golf 7 flip camera. I checked the camera @ vw specalist and they told me the camera is dead.
For the OEM camera i need to have + wire in the fusebox for 6c it is SC46. But from where can i pull the wire from +30 to the fusebox my SC46 is empty.
Diagram is from golf 7
Mocro wrote: Sat Jan 23, 2021 12:01 am
The usual suspect, that's why I was telling you to test the output of T12/6 &12 to check if camera is working.
Anyway, thanks for informing us.
To find the +30 signal in fuse box, visually inspect the fuse box for presence of terminal inside any of empty fuse slots. If you find any then use multimeter or 12v tester to find out the type of signal present.
