BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
everything make sense now, I have switched the mfsw feed wire from +30 to +15
and I have checked the RLS feed and is was +15, I have switched it to +30
now CH/LH is working
mfsw won't illuminate when the ignition off
new scan :-
Wednesday,13,January,2021,19:14:28:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 56 5F 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 204820km-127269miles
08-Auto HVAC -- Status: Not registered 0001
56-Radio -- Status: OK 0000
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F2E28-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175696210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905605-806E
   Serial number: 10082013470288
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695E5E-802E
   Revision: B9080001    Serial number: 0771 351150194
   Coding: A8A0393E4E21201201280ED02EEB8ED4F08063FF60042040320000020800
   Shop #: WSC 54707 002 104857
   VCID: 68DF0DA79B73D2C6A3-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 204820 km
                    Time Indication: 0
                    Date: 2021.01.13
                    Time: 19:08:51
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 308001
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356194D394417F2EE8-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 204820 km
                    Time Indication: 0
                    Date: 2021.01.13
                    Time: 19:08:51
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37C1137EE90-8078
   Component: IMMO          H04 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
Address 56: Radio
Cannot be reached
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541449324E10FAE58-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
3 Faults Found:
          U1101 00 [009] - Active
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 204820 km
                    Date: 2021.01.13
                    Time: 19:08:50
                    Voltage terminal 30: 11.8 V
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 204820 km
                    Date: 2021.01.13
                    Time: 19:08:53
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 204820 km
                    Date: 2021.01.13
                    Time: 19:08:50
                    Voltage terminal 30: 11.7 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:07)--------------------------
I don't think we well get the RLS flat again, I will check tomorrow
Remaining issues: Rain sensor & HBA, any ideas what to check ?
The HBA should work, please explain the process of how you are testing it. Works from 40 km/h.
The rain sensor can be totally disabled if the windshield glass has been damaged, the glass should be as close to perfect as possible so as not to interfere with the operation of the light emitting and receiving diodes when it rains.
Shadow109
Post by Shadow109 »
You’re 100% right, HBA is working, I will fix the glass for the RLS later when I get a new gel pad
Thanks a lot
Great! 8)
A link on how the HBA works:
https://drive.google.com/file/d/0B2nv91 ... B0MTg/view
the speeds indicated in the link are for an old VW model, now others apply (can be seen in the adaptation channels of the 20 unit).
Do not modify them, they are perfect as they are. :wink:
Good luck with the windshield glass, and the gel pad, this area must be immaculate for the rain sensor to work properly.
Shadow109
Post by Shadow109 »
Finally I found some time to deal with the doom lights ...
It looks great, the only issue I couldn't solve was that the lights don't turn on when I open a door
I swapped back to the old doom light and the issue was gone
So the puzzle is clear (and it is very easy to solve having a multimeter handy).
Either the pinning of the adapter wiring is not correct, or the electrical/electronic circuit of the dome lights is damaged.
Run the dome lights with a battery on the table and find out what the problem is. (with a 9V battery and two cables is enough... :lol:)
To check on the table you must place the main switch in its central position.
Shadow109
Post by Shadow109 »
ciclo wrote: Sun Jan 24, 2021 5:12 am looking for a new menu ...
Convenience and/or Lights and Vision (CH/LH)
Another example :arrow: https://uk-mkivs.net/topic/20240-highli ... ntry761427
According to the information I have available, by activating the adaptation channel "Car menu source" and configuring it to "Version 1", the mentioned menus are activated in MFD.
This happens in the instrument clusters for PQ25 that are sold in South America, ... Gol, Fox, Suran, etc ...
The source from which this information comes is from the BCM or a unit that I think is called VW i-system for PQ25. (depends on the date of manufacture)
I have dumped the eeprom data, by blocks / sectors, from a 5Z0 920 865 A H07 0010 instrument cluster (which has the mentioned menus activated and whose data structure is similar) in the eeprom of my BlueGT IC (except IMMO data, logically).
In each block/sector I have been checking with VCDS if this adaptation channel changed to available, ...without success.
Not available.🙈
hello ciclo, do you know if this adaptation is available on T6 Clusters ?
I don't know.
Related to this, Madwarlock was experimenting with the Jetta instrument cluster software and other models, he managed to make the CH/LH configurable through the MFD but there were some parts that were not compatible.
He is the one who can best inform you of all this. :wink:
BTW, did you solve the W8 dome lights issue?
Shadow109
Post by Shadow109 »
Unfortunately not, I am so lazy in the winter, today I had a free time, But I preferred to retrofit the Fog lights loom, I will post a scan later
ok
Front Fog lights. (SCLs)
- BCM Supply (+30).
SA2 Batt ---> 35-12 Fuse 15-20A --->T73b/11
- Activation signal.
T10/5 (T17/8) ---> T73a/7
- BCM - Fog lamps.
Left, T73b/9 ---> T2/2
Right, T73b/10 ---> T2/2
+ BCM coding.
Shadow109
Post by Shadow109 »
Wiring : Done
Coding: Done
New Scan:-
Friday,12,February,2021,08:27:25:00009
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   Mileage: 209960km-130463miles
   Revision: 00H43001
   Serial number: 11031913470358
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Coding: A8A0393E4E21201201280ED06EEB9ED5F08063FF60842040320000020800
   Coding: 0228EE
1 Fault Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 209967 km
                    Time Indication: 0
                    Date: 2021.02.12
                    Time: 18:22:47
   Coding: 308001
   Coding: 160A00
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 209967 km
                    Time Indication: 0
                    Date: 2021.02.12
                    Time: 18:21:47
   Revision: AA001001
   Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
   Data medium:
3 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 209967 km
                    Date: 2021.02.12
                    Time: 18:21:46
                    Voltage terminal 30: 12.3 V
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 209967 km
                    Date: 2021.02.12
                    Time: 18:21:49
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 209967 km
                    Date: 2021.02.12
                    Time: 18:21:47
Cannot be reached
End-------------------------(Elapsed Time: 03:04)--------------------------
Bonus Job :-
Footwell lights:
+ve T73a/65
-ve T73a/4
as you mentioned
Is was a nice sunny weekend :D
Great, well done!
Nice access lights/footwell lights on your T5. 8)
If you want, activate Byte21 Bit3 on the BCM, this will turn on the SCLs/Foglights when reversing, ... very useful for maneuvering in tight parking lots.
I assume you haven't installed the wire for the license plate lights yet ...
Shadow109
Post by Shadow109 »
Thanks Fernando, thants a cool mod
No I didn’t, I will install it soon
I have ordered parts for direct TPMS, hope to get it soon 8)
Ok. :wink:
