VW T5.1 Caravelle BCM Upgrade and Cruise Control on Steering Wheel...SOLVED
Re: VW T5.1 Caravelle BCM Upgrade
🤦‍♂️... T10 is the new light switch connector (which replaces the old T17), is the one that I am supposed to send you included with the wiring looms that you requested me.
You will never touch or modify the wires from this T10 connector, any modification will be on the wires starting from the red connector.
In the diagram, focus your attention where I told you ... to install my wiring looms there will be images with instructions.
... another question of this level and I do not manufacture your wiring looms ...
Limalex
Drives: Touareg R-line
Post by Limalex »
ciclo wrote: Sun Jan 17, 2021 3:19 pm ... another question of this level and I do not manufacture your wiring looms ...
No More questions :oops: :lol: ......... PM me with the details about the looms
I will try to make your wiring looms as soon as possible, it will not take me long to make them, but I already warn you that this week I think it will be difficult for me to find the right time to make them.
Once your wiring looms are made, I will show them here and give you the details for payment (nothing to worry about).
Limalex
Post by Limalex »
No problem no rush here :D
I have to wait for the terminals anyway. They are out of stock, Cannot really do anything until end of next week
Hi Limalex, today I have some time to make your wiring looms, please take a couple of photos of the interior fuse boxes (SB and SC) and post them here, thank you.
... I need to do some checks.
asap ... please 🤐 :oops:
Limalex
Post by Limalex »
Just got home. Hope I am not late.
[attachment=1]IMG_0823[1043].jpg[/attachment
Thank you very much for the images! 8)
Don't worry, I had to do other mandatory tasks anyway and I really wouldn't have had time to even start making them.
Now your wiring looms are my priority (in space and time).
Everything OK with the fuse boxes.👍
After taking a look in erWin I have modified the diagram that I posted here previously, being as follows:
I will provide you with all the wires represented in this diagram plus the ones that come out from the red connector where it says "new installation", ---> to BCM.
Your T5 is model year 'C' so you do not have to install the wire that runs to the instrument cluster (T32/14).
Limalex
Post by Limalex »
I was thinking to ask a question about that wire,
But I was not brave enough :) :)
hahaha ... please ask what you want.
Your wiring looms are made at 70%.
.. now it's time to rest until tomorrow ...
Super wiring looms 💎 according to diagram, 100% made. 🌀®... 😁
They are unique, exclusive, ...with a master lesson. 🙈🙉🙊
Based on these lengths:
Fuse box - BCM ~ 225cm
Fuse box - Light switch ~ 220cm
BCM - Light switch ~ 75cm
BCM - T41 ~ 183cm
BCM - T32 ~145cm
BCM - T10o ~376cm
They were provided by 'Adam87' some time ago.😎
Preparing installation instructions with pictures... more information coming soon.⏳
Hi Limalex, after completing steps 1 and 2 :arrow: viewtopic.php?p=528735#p528735 (except the high beam signal, in your case), proceed to perform step 3 as follows:
Your wiring looms.
:arrow: viewtopic.php?p=579518#p579518
Installation
The original wires T17/ 1, 3 and 4 must be isolated.
High beam wires.
Remove and isolate the original wires T41/ 38, 39, 41.
SB
SC
Maybe you want to replace or need at some other time the three SC fuses that were once changed.
You don't need to change them, I'm just sending them to you as a precaution ... 🙂
More images to burn the mouse scroll. :lol:
What you think? It's easy, right?
Are you okay?
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Well ciclo, the question is not for me.
But excuse me to stick my nose here ....
it has to be more than OK.
I am always more than happy to see these images and your attention to details about all things (wiring and connectors and fuses and what not)
Thanks ag69, you can stick your nose where you see fit :wink:, I'm just try to make things as understandable as possible.
Actually I ask about Limalex's state of health, just that, we had some pleasant conversations every day and suddenly there is no answer.
I suppose something must have happened to him, I hope everything is OK for him.
