Polo 6R BCM Swap for LED headlights
RonaldSl
- Drives: 6R 1.2 TSI
Hello,
I am retrofitting LED headlights with AFS on my 6R 1.2 TSI Comfort edition 2013. For this I made a BCM swap after reading forum. I went from my original BCM 7H0937090 to 7E0937090C. When purchasing BCM, I did not pay attention to whether they are suitable for LED headlights. I would like to know if that is not the case what needs to be changed to make it suitable. I have read that something needs to be changed in the EEPROM. Can someone tell me what exactly needs to be changed?
For the rest, the BCM swap had gone well. Only took over the codes and learn my keys. Not having to pull any wire. Original BCM does have a little more pins.
I must wait on materials like connectors etc. for AFS and putting the headlights in the car.
I have VCDS and ODIS-S and E.
Autolights I installed many years ago and RLS is installed from factory.
Re: Polo 6R BCM Swap for LED headlights
PWM Value with POS/TFL lights and activited Pos-lights
PWM Value with POS/TFL lights and activited DRL-lights
Read here
https://www.drive2.ru/l/489696641561919499/
I think I remember that the AFS unit needs the parameterization for LED headlights.
In the Russian forum there is a custom file. Look for the CNK LED headlights and that thread will find a link to the file with the parameters.
I also think I remember that the pinout between the AFS unit and the LED headlight connectors is different than for bi-xenon headlights.
Read here
Does your car now have bi-xenon or H7 headlights?
RonaldSl
I have checked website, thanks for information. It looks like I need VCP but firtst I gonna try with ODIS E. I think that AFS module is alright because the partnumber is 6R0907357. What I have seen so far is that AFS wiring is the same as with bi xenon only the adapter from 10p halogeen to 14p led connector is different than bi xenon.
Now I have H7 headlights.
RonaldSl
With ODIS E it can't be done. I ordered VCP for change parameters.
RonaldSl
Today I finally received all parts for installing the headlights.
AFS: left headlight is working, right headlight motor moves but headlight doesn't go up or down (I think internally loose).
LED Headlights:
First, I tryed without wires from headlight pin 10, 12 and 14.
I changed the coding to this: 3CB02FF868E32400B3380FB8FCAA0ED1DBC073BF608670D1A00000030000
What happened:
-DRL/parking lights working but flickering
-Low beam working with lamp diagnose off and with lamp diagnose on it was flickering. When driving low beam goes off after about 5 sec maybe longer and when I turned the switch off and on again the lights go on
-High beam worked but when I turned high beam on than the right headlight low beam goes off till high beam was off.
After all wires connected with list below:
LED connector left.
1 - AFS
2 - AFS
3 - AFS
4 - AFS
5 - Massa - Halogen connector pin 5
6 - Low beam - Halogen connector pin 6
7 - Massa - Halogen connector pin 5
8 - 12V - Halogen connector pin 1 (also try with directly 12V)
9 - Turnlight - Halogen connector pin 9
10 - LED module - T73b/5 LED pulse
11 - High beam - Halogen connector pin 8
12 - LED module - T73b/3 TFL
13 - Empty
14 - LED module - T73b/28
LED connector right
1 - AFS
2 - AFS
3 - AFS
4 - AFS
8 - 12V - Halogeen pin 1 (also try with directly 12V)
10 - LED module - T73b/6
12 - LED module - T73a/5
13 - empty
14 - LED module - T73b/56
The following happenes:
-DRL/parking lights stayes off
-Low beam works without flickering only with ignition on, when car starts the lights go out after about 3 sec and don't go on again so long car still running
-High beam works
When I change byte 18 to 67 (Xenon) than low beam is working all the time, high beam works, and DRL/parking lights are still off.
What is wrong? I checked and don't changed the following parameters with original VCP:
-PWM Value with POS/TFL lights and activated Pos-Lights 28
-PWM Value with POS/TFL lights and activated DRL-Lights 100
-PWM frequency for the activation of the LED driver of one combined LED TFL/PO light module 100
Hopefully someone nows the answer.
LED Headlights:
What happened:
LED connector left.
1 - AFS
2 - AFS
3 - AFS
4 - AFS
13 - Empty
LED connector right
1 - AFS
2 - AFS
3 - AFS
4 - AFS
13 - empty
-High beam works
RonaldSl
Wednesday,17,February,2021,21:59:07:16365
VCDS -- Windows Based VAG/VAS Emulator Running
VCDS autoscan
VCDS autoscan
Chassis Type: 6R-VW25 (XXX)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 55 56 61 69
VIN: WVWZZZ6RZDYXXXXXX Mileage: 73450km-45639miles
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 FJ HW: 03F 907 309 K
Component: SIMOS10.23AH10 5465
Revision: --H10--- Serial number: 00000000000000
Coding: 00110096202401080000
Shop #: WSC 57498 002 1048576
ASAM Dataset: EV_ECM12TFS02103F906070FJ 004008
ROD: EV_ECM12TFS02103F906070FD_004.rod
VCID: 6FBBD3A1171EF2A3BB9-803A
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H01 0002
Serial number: --------------
Coding: 21DD2885212700C9841C1472845900500905
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7BB32177DE92A3DB9-805A
Component: LENKW.SENSOR H06 0060
Serial number: 01121204651656
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2B20F-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0812
Revision: V0000000
VCID: 382928FD2250751BAA3-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 194170093
Coding: 3CB02FF868E32400B3380FB8FEAB0ED10BC073BF608670D1A00000030000
Shop #: WSC 02739 534 20609
VCID: 2B0307B1E306CE83D71-807E
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 241012 05 54 0403
Coding: 07302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
Component: J386__TSG_FT 008 1611
Serial number: KU0KU023101200015329
Coding: 58BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
Component: J387__TSG_BT 008 1611
Serial number: KU0KU025101200015139
Coding: 58BC30
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Serial number: 0159509
Coding: 820000
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU018101200012269
Coding: 58BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU019101200016976
Coding: 58BC32
6 Faults Found
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:13:20
02746 - Bulb for Daytime Running Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:13:20
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 210
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:10:09
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 2
Reset counter: 210
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:10:09
02898 - Control Circuit for LED Module for DRL and Parking Light; Right
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:09:26
02896 - Control Circuit for LED Module for DRL and Parking Light; Left
Fault Priority: 3
Fault Frequency: 1
Reset counter: 170
Mileage: 73458 km
Time Indication: 0
Date: 2015.07.11
Time: 03:09:26
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 7E0 919 475 L HW: 56D 919 475
Component: PARKHILFE 8K H02 0106
Revision: -------- Serial number: 35841522901332
Coding: 120001
Shop #: WSC 01681 002 104857
VCID: 3B2337F113E65E03471-806E
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01GR2W1
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD62354C3CF78BCC7-801E
Serial number: 3575HRB401C4UNBCEGD0
Serial number: 3585HRB401G4UNBCA1T2
Serial number: 3515RRB400G4UOFEKP9P
Serial number: 3525RRB400E4UO888HH%
Part No SW: 6R0 920 860 K HW: 6R0 920 860 K
Component: KOMBI H05 0605
Coding: 140E01
Shop #: WSC 00788 648 00255
VCID: 3C2134ED16E8593B4EB-8068
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002200
VCID: 6889B8BD3270259BFA3-803C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Component: IMMO H05 0605
Serial number:
Coding: 000002
Shop #: WSC 12345 123 12345
VCID: 6A8DC2B52CFC178BEC7-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7663867702
Coding: 020100
VCID: 2A0D02B5ECFCD78B2C7-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 A HW: 3C8 035 279 A
Component: RNS315-EU H59 0319
Serial number: VWZAZ2M5552147
Coding: 040004110200010000000308
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 290FFDB9E97ADC9325D-807C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V12 0078
Address 44: Steering Assist
Cannot be reached
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0192000001000000
VCID: 77ABEBC16F4EBA63639-8022
1 Fault Found
5277205 - Positioning Motor for Headlight Range Right
C1086 15 [009] - Open or Short to Plus
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 210
Mileage: 73458 km
Date: 2021.02.17
Time: 03:13:53
Address 61: Battery Regul. (J840) Labels: None
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 032B7A64
Shop #: WSC 02739 790 12345
Subsystem 1 - Part No SW: 6R0 915 181 E HW: 6R0 915 181 E
Component: J367-BDM H08 0181
Serial number: 00000000004970301739
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Towbar module H09 0100
Revision: 3A001001 Serial number: ÀÁ006789406032
Coding: 010D000100000000
VCID: 303910DDCA20AD5BE23-8064
End----------(Elapsed Time: 02:15, VBatt start/end: 12.5V/12.4V)-----------
I updated your status to 'registered user' so you can post all you want now.
RonaldSl
Okay, thanks. You now also a answer for my problem?iichel wrote: Thu Feb 18, 2021 8:30 am I updated your status to 'registered user' so you can post all you want now.
well, yes and no. i probably wrote the guide you're using and I did it myself, so on a technical level, yes.
but right now i'm just too busy to really go deep into this, i'm sorry.
RonaldSl
Okay np. I used indeed your great guide.iichel wrote: Thu Feb 18, 2021 10:20 am well, yes and no. i probably wrote the guide you're using and I did it myself, so on a technical level, yes.
I take a deep look in the wiring diagrams and hopefully I find it but I think it's something different.
You can first verify all the wiring. Then next step is coding.
RonaldSl
Headlights working now. I saw in the electrical drawings that there must be a yw/bk wire from SB11 to T73a/44. There was a bn/bk wire in it. I take that out and isolate the terminal and take a new wire for it.
I can't find the bn/bk wire in schematic. Someone now what it is originally? The low beam stayed on now (also with byte 18 to 73).
After this the parking light/DRL still not working. Pin 8 from LED headlight connector, I connected this back to T10/1 from halogen headlight connector.
I didn't realise that this problem has something to do with coding.
I find coding topic for OEM Xenon from Iichel and change the following:
No flickering etc. all is working now. I'm verry happy with this.
Maybe someone coud explane me for learning what the following bits meaning:
- Byte 11 to D1
- Byte 21 bit 0 set to 1
- Byte 22 bit 4 set to 1
- Byte 23 to 41
- Byte 11 bit 0
- Byte 11 bit 5
- Byte 21 bit 0
- Byte 22 bit 4
- Byte 24 bit 1
- Byte 24 bit 7
RonaldSl
I have still one problem with the headlights. While driving both headlights on low beam, both headlights goes out with low beam after a short time.
When take the foot from gas pedal the low beam lights go out.
RonaldSl
I saw original xenon headlights has a 2.5mm2 wire for low beam and h7 headlights 1mm2 from T73a/2 and T73b/2 too pin 6 headlight connector.
I replace wire with 2.5mm2 but there was no difference.
I discovered the battery in the car was the wrong one.
I changed in Battery Management EFB battery too wet battery and also in adaption channel 4 68aH too 45aH.
So far so good. I made a little test drive and the lights stayed on. Now I gonna order the right battery.
Edit: low beam still go off but not so often. Now I turned byte 16 bit 0 (low beam via PWM) off and the low beam lights stayed on finally. In the past with aftermarket xenon I had same problem. I think this is also solution for aftermarket xenon in H7 headlights.
