Ok, thank you.
mfsw on polo 6r
- SimonPoole
Re: mfsw on polo 6r
- SimonPoole
Re: mfsw on polo 6r
I've found some steering wheels like mine on eBay with the buttons on the left hand side. It appears that the connector is already in the wheel to plug the right hand buttons into, so this might be a cheaper way forward, unless anyone knows different?
Re: mfsw on polo 6r
Ichel, thank you for the answer. I don't care about the lights. I would like to know how can I disconnect the wiring of TRIP on my car to avoid the conflict with the MFSW buttons? Do you have a wiring diagram of the connector?
Re: mfsw on polo 6r
An other answer, I haven't the airbag cable, do you know the oem code to fit the new steering wheel? (my polo 6r hasn't MFSW so the old airbag cable don't fit certainly)
Re: mfsw on polo 6r
@iichel could you contact me privately?
Re: mfsw on polo 6r
I prefer not to, it's a public forum
Re: mfsw on polo 6r
7E0 971 584 C I think should be the correct wiring loom.Cagnolo96 wrote: Thu Feb 11, 2021 2:09 pm An other answer, I haven't the airbag cable, do you know the oem code to fit the new steering wheel? (my polo 6r hasn't MFSW so the old airbag cable don't fit certainly)
Re: mfsw on polo 6r
Thanks. OK, we can speak on this thread. Could you please explain HOW all the MFSW controls work (the 6c MFSW on 6R) without changing bcm? Specifically I would like to know how can I transfer the signals of cruise control and the TRIP buttons on the MFSW controls. I saw this in other cars but I don't know which wiring I have to change to make it . Could you see it on Elsa win and explain also to the other users that want to do this retrofit? Because exist a guide but is only explained how to fit a MFSW 6r r line on a polo 6r. Instead I would like to know the retrofit from 6c to 6r. Thanks
Re: mfsw on polo 6r
@iichel
Re: mfsw on polo 6r
The MFSW signals are sent via LIN bus (low speed databus, 1 wire). but the engine controllers of the 6R cannot understand the signals from the LIN/MFSW for cruise control. You'll need to find some kind of emulator for the MFSW with CC to translate these to normal signals from the stalks.
It's not like this solution is plug and play in any way.
Sid_polo
- Drives: Polo 6c 1.0L mt comfortline
Re: mfsw on polo 6r
Can anyone tell if mfsw installation procedure is same for 6r and 6c? I have a polo 6c comfortline tsi edition 1.0L with climate control ! Is it possible to add mfsw ?
Car did not come with any buttons from factory !
Re: mfsw on polo 6r
No, it is very different and you need to make sure your BCM is part number 6C0 937 089 or higher.
vento2013
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: mfsw on polo 6r
VW never introduced 6C Polo in India. Your Polo looks like 6C. But from inside it's 6R. So MFSW can be installed on your Polo.Sid_polo wrote: Sun Mar 14, 2021 11:05 am Can anyone tell if mfsw installation procedure is same for 6r and 6c? I have a polo 6c comfortline tsi edition 1.0L with climate control ! Is it possible to add mfsw ?
vento2013
Re: mfsw on polo 6r
@iichel I guess he has 6R0 937 087S BCM.iichel wrote: Sun Mar 14, 2021 11:32 am No, it is very different and you need to make sure your BCM is part number 6C0 937 089 or higher.
If he shares scan report it will be clear.
Re: mfsw on polo 6r
I see, in theory every Polo 6R0 bcm will support the MFSW
