Hi guys,
Just bought a 2016 BlueGT and I've noticed behind the cupholders under the Aircon unit there is a small cubby hole, I assume it's supposed to be there for a phone to be put in, but I was wondering if anyone knows of a bespoke rubber mat that's been made for it anything like that? Since when I put my phone in there it's just plastic and my phone rattles around a bit more than I like.
Phone space behind cupholders
Re: Phone space behind cupholders
You could always buy some cheap rubber sheeting and make your own by cutting the sheeting to size;
https://www.ebay.co.uk/itm/372772265481 ... gIP-_D_BwE
Alternatively, put a car duster or microfibre cloth in there to lay your phone on.
peter_dk25
- Drives: Blue GT
OEM part: 6C0864113FLV
What is this part number for, I've done some searching but can't seem to find anything with that part number?
peter_dk25
- Drives: Blue GT
Nr 17: Mounting for CellphoneBenblueGt wrote: Mon Mar 01, 2021 7:34 pmWhat is this part number for, I've done some searching but can't seem to find anything with that part number?
https://www.ilcats.ru/vw/?function=getP ... anguage=en
https://www.oemvwshop.com/6c0864113-flv ... r-p968788/
- mirceaculita
- Drives: 6R 1.2TDI 75hp
is this a straight slap it in install or are there modifications to be made? Also is it compatible with the 6r/6c or both?peter_dk25 wrote: Tue Mar 02, 2021 6:34 am Nr 17: Mounting for Cellphone
peter_dk25
- Drives: Blue GT
Plug and Play, so to say - fit's both 6R and 6C
- mirceaculita
may be worth looking into it. I think it should be pretty easy to hook up a wireless charger to the back of it and have your phone be charged while in that clip.
Has anyone got one in their car? Curious to see how it works/looks properlypeter_dk25 wrote: Tue Mar 02, 2021 6:34 amNr 17: Mounting for CellphoneBenblueGt wrote: Mon Mar 01, 2021 7:34 pmWhat is this part number for, I've done some searching but can't seem to find anything with that part number?
@ Op you could look into rubber slot mats for your car
I can remember seeing a picture on the forum quite a while ago of one fitted. The forum member who posted the picture was querying what the wireless icon was that is printed on it. It’s pretty unobtrusive when it’s in situ as it fits flush up against the back of the cubby, with the small dimpled rubber mat in the bottom of the cubby.Damon wrote: Wed Mar 03, 2021 6:55 pm
A bit of creative searching via the forum search facility and you might be lucky to find the picture.
To the OP; a rubber mat would be much cheaper though, especially if you buy a sample size from one of the many sellers on eBay and you cut the sample to fit. If it’s not a perfect fit, it’s in a location where it won’t be readily seen.
