Aditya's Polo 6R GT TSI 1.2
adityagttsi
- Drives: Polo GT 1.2 TSI
Re: Polo 6R GT TSI 1.2 BCM Max + Auto Headlight + HBA
Hey Ciclo, have given firegrafik the confirmation for BCM Max and Auto Headlight Switch.
Apparently the RLS issue is common as per few car owners, the problem only occurs when you try to use VCDS to do changes. SheetalKumar solution worked like a charm, as per him if you disconnect the negative terminal on the battery for 5mins, then clear the DTCs it resolves the issue.
Have sourced parts like Dimmer Switch + Headlight Regulator, BCM Max and Auto Headlight Switch. In Search for IC with MFA+, will give a confirmation about that in a day or two.
Tuesday will do the payments for the wiring BCM Max Adaptations + Auto Headlights
Guys, have a doubt i have tried enabling rear comfort wipe (Rear wiper turns when engaged reverse gear and front wipers are on) through adaptations and long coding. Does not seem to work. Long Coding accepts the code but the next time its back to its stock code.
Any suggestions
Ciclo, if possible please send LED Number plate lights with the wiring.
Any suggestions
govindsharma
- Drives: polo 1.2 petrol HighLine
Hello as in my polo it work not in engaging reverse gear.It works when I use front wiper and then engage reverse gear.For example when there is rain first front wiper starts and here when we engage reverse gear rear wiper starts working.But second opinion must be from Expert Ciclo Ji. You should buy IC from ciclo ji link provided if seller is willing supply it. Second for coding IC go to VW service center they will code it for you.
Thank you.
Thank you.
Aditya, I sent you an answer by email before reading your last post.
Don't try to code new features with your old BCM, it doesn't make sense until you install the new BCM Max, which is where you'll get all the new features.
govindsharma has perfectly explained how things are with the rear window wiper, ... and your NEW Instrument cluster.
My life goes fast and you go too slow for me. In an email I told you if you needed anything else from me once your wiring was finished. At that time I could have requested a dimmer from my dealer, now it is too late because of the long process it takes for the Dimmer to reach me from Germany (at the current COVID-times). Try to get it from eBay or India, maybe govindsharma can help you in this matter.
You must bear in mind that without the wiring that I have manufactured for you as a great favor, nothing makes sense, that is, the wiring (and me
) is your priority, the rest of the parts, etc, are secondary because they can be obtained in any time and place.
govindsharma
Dear Adiya , Ciclo ji is very much right go step by step first choose wiring second install wiring then go for functions like these.You get not only wiper function but more.So go step by step and do all the things as per ciclo ji instruction .You will get your new polo after this.
adityagttsi
Hey Guys,
Sorry for the late post as was busy with office work and had gone a trip. Done with the installation of BCM Max with Auto Headlights with CH/LH, MFSW with paddle shifters, Maxi Dot Cluster, Dimmer with Headlight Level Switch, Aftermarket Headlights and Led License Plate Lights.
Thanks to all the people for clarifying my doubts. Specially Ciclo for the wiring kit and support, firegrafik for sourcing the BCM Max and Auto Headlight Switch.
Aftermarket GTI 2020 Style Headlights for Polo My Polo GT TSI 1.2L Wiring Kit by Ciclo BCM Max Auto Headlight Switch Maxi Dot Cluster MFSW with Paddle Shifters Low Beam Cut Off of Aftermarket Lights
Thanks to all for this. I must say the above mods gives extra premium feel to the car. Specially the convenience of having Auto Lights during road trips and Paddle Shifters for those unplanned overtakes on single lane highways.
It looks really nice with those LED headlights (AW1 style).
Aditya, I don't remember our email conversations because I can't remember the sheer amount of conversations with everyone, but if you need to code something, please let me know. Thanks.
In any case please post a fresh Autoscan here for 'instant' help or for future projects.
- Platinum Member
Those headlights really suit the car. Was the car ever involved in accident, sorry to ask but im obsessed with fender to hood alignment. Or its factory messup on 6r, i see on 6C is much better
adityagttsi
Hi guys
About the rest of the mods
1. Did the wiring for heated ovrm the OEM way. Waiting for the mirrors to come. Once the full installation is done will post pics.
2. This week got my engine tuned from etuners. The claimed power figures are 140bhp/225nm over stock 110bhp/175nm
Observations after tune are.
It doesn't downshift as frequently it used to. Every gear has enough power to pull
The car used to feel strained when fully loaded(4 passenger, 1 driver and luggage). Now that has reduced
Previously it used to redline at 5500-5700rpm, now it redlines at 6000-6100rpm
D mode kind of feels like S mode.
If you drive sedately it will give some where between 16-18kmpl on highway
They had TCU tune also. According to them once you do the TCU tune the DSG related jerks while downshift from 3rd to 2nd or 2nd to 1st are reduced. As of now you can't launch the car but after this TCU tune they will you give launch control.
Regards
No it was never involved in an accident. It was messed up a little front the factory. And the rest because of the gas struts as I am only using one. Planning to add the second one also. Thanksamer6R wrote: Fri Mar 05, 2021 6:33 am Those headlights really suit the car. Was the car ever involved in accident, sorry to ask but im obsessed with fender to hood alignment. Or its factory messup on 6r, i see on 6C is much better
Thanks ciclo. Recently I changed my bulb from led types to xenon/hid with d2s apater. After the change the bulb flickers when the engine is running. It works properly when the engine is off. Don't know why. It would be great if you can help meciclo wrote: Fri Mar 05, 2021 3:10 am It looks really nice with those LED headlights (AW1 style).![]()
In any case please post a fresh Autoscan here for 'instant' help or for future projects.![]()
Regards
Reinstall LED bulbs with drive units, but this time buy high-quality LED bulbs.
Discard any type of xenon kit (balasts, external wires).
adityagttsi
Hey guys needed your help again as i still dont know alot of vag cars.
Was planning on installing the Direct TPMS on my car.
I am getting this kit from russia for reasonable amount. Will this kit fit my car. Here's the link, https://m.vk.com/product-82401118_4983709
Would need help with flashing and filling the parameters, wiring,etc
Let me know guys if I should i proceed with this kit?
Regards,
Aditya
Regards,
Aditya
Autoscan with current units installed.
Ask for the correct kit, with 3AA unit (or flashed) I'm sure they can provide it for you.
The wheel sensors must also be 3AA ...
Here you have the info: viewtopic.php?p=525012#p525012
adityagttsi
Hi ciclo, hope you doing well.
Ask the seller whether he can flash it for pq25. He agreed to it that he will flash 5Q0 block so that it works with pq 25 platform.
What do you suggest? Regarding this?
Please help me with this if you can.
Regarding the Autoscan Haven't installed anything after I had installed your auto headlights And BCM max. Will post the scan in few days as my car is with service centre for yearly maintenance.
Everything is fine for me if we don't go into small unimportant details
, I hope everything is fine for you too.
Okay, I have checked my emails to check the last Autoscan you sent me (with BCM Max installed), I just needed to see the SW of your instrument cluster.
If you had published the Autoscan here I would not have to look for it in my emails (my time is the most precious value for me).
If he or they send you the TPMS unit already flashed for PQ25 it is perfect!
Wheel sensors should also be the right ones (3AA or aftermarket coded to 3AA values), ask them.
In any case you are going to need someone to edit your tire pressure values and enter them in your TPMS unit. Edit them yourself with the editors and send them (generated zdc file) to the seller to insert them in your unit.
This way, you will only have to install the system in your 6R.
My help is fully guaranteed for you, post your queries or progress here.
adityagttsi
Hey Ciclo,
So i did speak to the vendor again. He says that he will have to Flash 2H6 firmware on the 5Q0 block for it to work on pq25 platforms.
The 5Q0 sensors will work with 2H6 Antenna perfectly, this is what he says.
Btw I have the autoscan which i was able to get from my laptop.
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: MEXJ19604LT057986 License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: MEXJ19604LT057986 Mileage: 21270km-13216miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6DD17CB3BC91F72742-8038
Readiness: 0010 0001
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266575
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B55B2AB8A0539171C-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422803C7461D24714257C0800908
VCID: 000F35079B030A4F99-8054
Serial number: 07071913470686
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77CBFEB-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F003D889C347D6-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 320180219
Coding: 38B82BFF48B30400013806D07CEF9E90F2C067FF608C2101220000030000
Shop #: WSC 12345 123 12345
VCID: 2C57B1B74F0B3E2F15-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 180619 05 50 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848190716085938
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849190711213513
Coding: 040000
Subsystem 4 - Part No SW: 31G 959 442 HW: 31G 959 442
Serial number: 0401812433500024CX3J
Coding: 250000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728190711175909
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729190711052611
Address 15: Airbags (J234) Labels:. 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZAAYABLK
Coding: 880000000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 4189F003D089C347D6-8014
No ASAM data for: "EV_AirbaVW12TS6VW25X" (VW25)
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140A00
VCID: 479DEE1BFEADFD7718-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002300
VCID: 68DF0DA79B73D20F31-803C
Component: IMMO H05 0805
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB77AF8D7FE01F27-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014.rod
Part No SW: 6RF 035 187 C HW: 6RF 035 187 C
Component: Radio 557 5532
Revision: -------- Serial number: VWZ7Z2T8105070
Coding: 0E00044000000F
VCID: 4999E823E0B90B070E-801C
One more thing the vendors says he is 3AA sensors and antenna are tough to find(next to impossible)
Ciclo, let me know what do you think and should i purchase the antenna with sensors?
Regards.
www.Ross-Tech.com
Coding: 0000020
Coding: 01
Revision: V0000000
Coding: 066800
Coding: 350000
Coding: 040000
Coding: 250000
Coding: 140A00
Revision: B9082001
Coding: 002300
Regards.
I'm afraid your Instrument Cluster SW (same as my 6R's) is not compatible with the 2H6 antenna and therefore the 5Q0 wheel sensors.
You need 3AA. Yes or yes.
I prefer you buy from Russian seller due to technical reasons, but if it is not possible, you can buy it all from Ali.
You can also do a shopping mix and buy the 3AA flashed unit from the Russian seller and the wheel sensors from Ali.
Hmm... contact Patil, I think he is the best one to help you with this matter. His experience can help you.
