BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
A new toy had arrived
Where can I find the needed flash file?
Nice! 8)
Look at your inbox.
Shadow109
Post by Shadow109 »
I have successfully flashed the new firmware
a have made a parameter file, but I did susseed to load it
Generate the parameter/data file again. You must select which diagnostic tool you are going to use - VCP - and the unit - 3AA907273F - in which the dataset will be loaded.
The two parameter editors shown here worked perfectly for me (no mystery at all), for both VCP and ODIS.
viewtopic.php?p=525012#p525012
Once the new parameters are loaded, you should take the van for a short ride until the TPMS unit receives the signals from the wheel sensors.
For me it worked once I had traveled about 100 m, but there are people who say that they had to do a few km.
Then each day, or each new ride, you have to wait to go a certain distance for the tire pressures to update on the MFD. Tire pressures are highly dependent on the temperature of the tires.
I can no longer live without this invention. :lol:
Shadow109
Post by Shadow109 »
Yesterday I have tried the RDKS editor, But VCP didn't accept the file (wrong format) as seen in the pic
today I have tried the github, VCP had accepted the file, but another error had came when writing the file
You have to check the box where it says 'EraseFullMemory' before clicking on 'Upload selected data',
and everything will work like a charm. 🧙‍♂️
example
by cicl😁
GitHub
Shadow109
Post by Shadow109 »
Thanks Fernando, I have added the parameters, but still no numbers on each tire, when the pressure is low, A warning shows up
Shadow109 wrote: Tue Apr 13, 2021 11:35 pm Thanks Fernando, I have added the parameters, but still no numbers on each tire, when the pressure is low, A warning shows up
Please could you explain it another way, I don't understand what you mean, it seems contradictory.
If there is a warning on the MFD due to low pressures it means the system works ...
What do you mean 'still no numbers on each tire'? In what conditions? Do you have a picture of what you want to say?
If you have the 'Vehicle Status' menu selected in the MFD, the first image you see (always) when you turn the key in the ignition switch is with the wheel pressures in this "---" state.
Until you start to move with the van, the numbers-pressures will not be displayed. The control unit has to receive the signals from the sensors (orange) you installed on the wheels, and this only happens when the wheels are in motion.
Shadow109
Post by Shadow109 »
ciclo wrote: Wed Apr 14, 2021 4:14 am
I have traveled with my car three days, but the number pressures never came up, I have tried to re-flash the TPMS unit, reload the zdc file with the parameters, but still the same
According to VSDS all sensors are working probably
Wednesday,14,April,2021,14:59:52:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 5F 65 6D 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 219430km-136347miles
61-Battery Regul. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F2E28-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175796210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905605-806E
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695E5E-802E
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 295170714
   Coding: A8A0393E4E21201201280ED06EAB9ED4F08063FF608C2040320000020800
   Shop #: WSC 31414 790 00001
   VCID: 2B55B2AB4A0539DE8E-807E
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 108001
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356194D394417F2EE8-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A01
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 68DF0DA79B73D2C6A3-803C
2 Faults Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 219434 km
                    Time Indication: 0
                    Date: 2021.04.14
                    Time: 00:54:27
00317 - Rear Lid Control Module (J605)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 219434 km
                    Time Indication: 0
                    Date: 2021.04.14
                    Time: 00:57:04
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37C1137EE90-8078
   Component: IMMO          H04 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541449324E10FAE58-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
3 Faults Found:
          U1101 00 [009] - Active
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 219434 km
                    Date: 2021.04.14
                    Time: 00:54:25
                    Voltage terminal 30: 12.7 V
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 219434 km
                    Date: 2021.04.14
                    Time: 00:54:28
                    Voltage terminal 30: 12.6 V
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 50
                    Mileage: 219434 km
                    Date: 2021.04.14
                    Time: 00:54:25
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
   VCID: 377D9EDB8E4D8D3EFA-8062
Address 6D: Trunk Elect.
Cannot be reached
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:07)--------------------------
patil
Post by patil »
Hello shadow109
From the information you've provided, it looks like the tpms module is unable to determine the wheel position in which sensors is present.
Where have you placed the tpms module?
In advanced measuring values of address 65, the sensor location should be displayed, see mine below.
Thank you very much for the more than clear explanation.👌
Robert, a great guy and also a user of this forum, developed a thread on the T6 forum about installing direct TPMS on T5/T6.
Due to the same symptoms you are having, some users found that the placement of the TPMS unit (for vans) is very important so that it can receive the signals from the wheel sensors properly. They determined that it should be in an external and centered place.
You already have the correct TPMS unit and sensors for your van (instrument cluster), read the last pages of Robert's thread, or the entire thread if necessary.
:arrow: https://www.t6forum.com/threads/direct- ... ost-222702 maybe here is the solution 4U.
Shadow109
Post by Shadow109 »
patil wrote: Thu Apr 15, 2021 3:51 am Hello shadow109
Thanks so much for the info
I guess I will try different place for the sensor
TheKeymeister
Drives: Caravelle T5.1
Post by TheKeymeister »
Hope it's OK to post this here...
I finally fitted my Direct TPMS module at the weekend based on the wiring diagram above, I wasn't able to see it with VCDS at first, it turns out I had crossed the Can High and Low where I joined it at the BCM :oops: Not the first time crossed wires have caused me a problem this week, but the other one was on an 11,000V cable at work so this was a much easier fix :D
I re-made the connection tonight, and I can now see it with VCDS. However, nothing is displayed in my instrument cluster - no selection for tyre pressure under units either. From what I've read no further coding is required after enabling address 65. The sensors aren't yet installed in the wheels, I would imagine this wouldn't stop it showing in the cluster though?
I have the colour 3D cluster so I believe it should work - unless maybe the software on it needs updating. I do have VCP now for uploading the tyre pressure file, so presumably could update the cluster with VCP if required.
Latest autoscan is here - https://pastebin.com/97AwHbyN
Video of cluster operation here - https://www.youtube.com/watch?v=Qapwft5 ... amKeyworth
No menu will be displayed until you load the wheel pressure parameters into the TPMS unit (VCP or ODIS).
It could be for another reason, but this reason is the usual ...
TheKeymeister
That would make sense, as I haven't done that bit yet :lol:
I'll try again tomorrow and report back! It's also in the garage next week for a new rear tyre and the sensors to be fitted as well
