What wires do I need to retrofit stalks with TRIP/OK
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
I don't know how to google the type of wires. I know there are 3 wires that need to be installed, but what kind of wires?
Re: What wires do I need to retrofit stalks with TRIP/OK
0.3 mm- 0.5mm is fine
mirceaculita
ok, but aren't there multiple types of connectors? This would be my first wiring work so I know absolutely nothing about the type of wires and connectors used.
When doing a google search this part number kept showing up : 000979132E, is it correct?
the connectors are all micro quadlock system
mirceaculita
Ok, thanks, pretty sure I found the right wires
mirceaculita
Do you know if the stalks can be bought separately? What I mean is, can the stalks be separated and let me just buy the wiper stalk with the buttons and install it in place of my basic one?
well you can tear pretty much everything apart but I wouldn't recommend it.
mirceaculita
Makes sense.
Also, is the slip ring from a basic polo compatible with the mfd stalks? I wouldn't pay extra for it if it wasn't necessary.
yes it is, you can swap them over.
mirceaculita
Ok, great, thank you. I think I have the information I need :D
mirceaculita
Would these connectors be good for the job? While waiting for the wires I ordered to come I thought of pulling these from a broken plug I had laying around.
No you need the micro quadlock system
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
This is what you need :
https://a.aliexpress.com/_vcsMur
mirceaculita
yeah I know, the downside is the really long waiting period. I've asked a friend that works at Skoda if he can source some wires for me.
