Radio upgrade
Chowarddd
Drives: 6r
Radio upgrade
Post by Chowarddd »
Hello all
I’m new to polos and I’ve just got a 2011 Polo, 6c I believe, for my first car and the one thing I instantly want to upgrade is the radio, I believe the one i have atm is 5M0035156C and I want to get the rcd330 and was wondering if it’s just plug and play, or do I need some adapters?
All helps appreciated
Re: Radio upgrade
Plug play
Chowarddd
Drives: 6r
Re: Radio upgrade
Post by Chowarddd »
Awesome thank you 🙏
Is there any coding involved to remove component protection and get car play activated?
mirceaculita
Drives: 6R 1.2TDI 75hp
Re: Radio upgrade
Post by mirceaculita »
I don't really know the technical terms for all the parts, but doesn't it require to install another box/computer thingy inside the glove box? (Coming from rcd210/310)
Re: Radio upgrade
You will just need the Code, get it decoded your is rcd 210
Dishwasher
Drives: 2010 6R S
Re: Radio upgrade
Post by Dishwasher »
I did the exact same thing as you, got a basic 6R as a first car and ripped the radio out first thing. RCD310 is a super easy swap, it's a direct plug and play. Only thing you'll need is a security code thing, you can get them on ebay for like a fiver. RCD330 i'm not sure on, think there's a bit more work involved.
-Dishwasher
Re: Radio upgrade
Sorry, i miss read 310 instead of 330. I think you will need an adapter for 330
Matchpolo2009
Drives: 2009 match
Re: Radio upgrade
Post by Matchpolo2009 »
Hi, sorry to jump on post but similar question…I’ve just bought my daughter a 2009 polo match with a very basic original radio, I was looking at replacing with an RCD 330, could anyone advise if this is an easy swap? Thanks I’m advance 😊
Damon
Drives: 2010 Polo Moda 64
Re: Radio upgrade
Post by Damon »
Matchpolo2009 wrote: Tue Jul 06, 2021 10:37 am Hi, sorry to jump on post but similar question…I’ve just bought my daughter a 2009 polo match with a very basic original radio, I was looking at replacing with an RCD 330, could anyone advise if this is an easy swap? Thanks I’m advance 😊
I have a 2010 Polo and swapped mine for RCD330.
Straight swap no issue :)
You’re good to go.
15 minute job tops!
