6R Headlight mounting
POLOZ
Post by POLOZ »
Hi Guys,
I am currently building a CAT N 2012 Polo Match. It has a light Wing damage (Fender bender :P ) So I have a replaced it with a after market wing that came pre painted.
I installed the new wing yesterday and somehow my headlight is not sitting right :(
I am not sure if the mounting bracket is to blame?
Is there a way to adjust the bracket? As I can't see anything that can adjust it?
Re: 6R Headlight mounting
the arch that runs below the headlight (the black plastic one) has two holders in them. you can use them to adjust the height of the headlights
POLOZ
Post by POLOZ »
iichel wrote: Mon Aug 16, 2021 4:10 pm the arch that runs below the headlight (the black plastic one) has two holders in them. you can use them to adjust the height of the headlights
Thanks iichel do you mean this? Mounting bracket
Yes exactly this one.
You can remove fog light trim, to access them from underneath
POLOZ
Post by POLOZ »
Thanks Guys for the help.
Unfortunately the bracket on Polo's are non adjusting. The screw only tightens the mounting bracket.
However, it turned out that the wing bracket was also bent :( So after a few hammer and alot of adjusting I got the gap sorted. There is still a very tiny gap but I don't have patience to fiddle with it anymore.
It matches the driver side so I am happy with it :)
I finish very late in evening so will post pictures in the morning.
on each bracket for the headlight you will have these two kind of brackets.
Image The headlight clips into them.
They are held in by one bolt, the bolt head is visible from underneath. If we are thinking on the same thing.
POLOZ
Post by POLOZ »
amer6R wrote: Tue Aug 17, 2021 8:12 am on each bracket for the headlight you will have these two kind of brackets.
Yep exact brackets, however they can't be adjust as the bolts only tighten it into place. I couldn't find any way to raise or lower it with the bolt
POLOZ
Post by POLOZ »
Far better now
POLOZ
Post by POLOZ »
Guys anybody here know best way to adjust a wing on a polo?
I fitted the new wing and I can't seem to get the gap right at the door :(
Try bolting it but not to tight so you can move it, but not to loose it doesnt want to hold the position. Then push it until you like the gap?
POLOZ
Post by POLOZ »
amer6R wrote: Thu Aug 19, 2021 2:59 pm Try bolting it but not to tight so you can move it, but not to loose it doesnt want to hold the position. Then push it until you like the gap?
Thanks Amer6R for the suggestion. Gonna have a play on weekend to get it perfect :)
POLOZ
Post by POLOZ »
The thing is I bought a branch new pre-painted wing from ebay and the quality of it turned out to be shocking :( :evil:
I am quite sure it will prevent me from getting a perfect fitment :cry:
The paint doesn't even match, the seller is suggesting my paint has faded
You can give a polish with a wool pad even on a drill. If you have a DA sander that will also work much better and some cutting paste. Yeah, replacement parts aren't really 100 % true to the original.
POLOZ
Post by POLOZ »
Do you mean polish the replacement panel? The new panel has a blueish tint :(
