Try this: A0F2793A0A61341393288F716CABAFD51290672F7E857840320003020800
If it were my T5 this would be my new BCM coding:miku73 wrote: Wed Sep 01, 2021 12:45 pm Hi Ciclo, the cable is on the place. Could you be so kind and help me with coding? thank you many times.
A0F2793A0A61341393288F716CEB9FD50290662F7E8D78C0320003020800
New functions:
- Automatic lights.
- CH/LH. (via Bixenon)
- Cornering lights ON when reverse.
- DRL, winking with turn signal.
- Tear Wiping active. To try to get the RLS as clean as possible after using the windshield wiper.
I finally got a new switch with an automatic function. Everything works like charm. Thanks again for the help Ciclo, iichel!
Thanks for confirming.
A much easier task than the one indicated in this thread for other T5s with different PR codes, your T5 already had a nice factory equipment.
Enjoy it!!!!
Some links in case someone needs more info about adaptations and codings (what I have already posted on other occasions).
VCDS:
http://www.uk-polos.net/viewtopic.php?f ... 05#p474349
http://www.uk-polos.net/viewtopic.php?f ... 95#p477710
http://www.uk-polos.net/viewtopic.php?f ... 65#p491539
http://www.uk-polos.net/viewtopic.php?f ... 65#p491577
http://www.uk-polos.net/viewtopic.php?f ... 30#p504328
http://www.uk-polos.net/viewtopic.php?f ... 82#p517482
http://www.uk-polos.net/viewtopic.php?f ... 15#p517604
http://www.uk-polos.net/viewtopic.php?f ... 20#p518296
http://www.uk-polos.net/viewtopic.php?f ... 20#p518219
http://www.uk-polos.net/viewtopic.php?f ... 80#p520980
viewtopic.php?f=56&t=58703&start=4020#p529332
Note: Not everything shown in the previous links will work with all BCMs Max. From 7E0 937 090 B everything will work.
Enjoy it!!!!
VCDS:
mfourc
- Drives: Transporter T5.1 and Polo GL
Hi @cicio,
are you still making these looms? I've got a T5.1 2013 year with the big plug light switch. I'd like to retrofit auto lights etc and have the mirror and sensor but not the right switch etc. which of the posts is the best one to read to get a clear understanding fo how to fit this as theres 34 pages of goodness here
Hi mfourc, welcome.
I don't do these wiring looms anymore, sorry.
These teaching and learning processes on wiring looms on the vw PQ25 platform ended up scattered throughout the forum.
I recommend reading this thread as a starting point, but currently, for T5, it is best to follow the electrical installation that was made in the Limalex thread.
(everything evolves, but the above is also good)
In order to give the OK to deal with these electrical installations, I recommend posting an Autoscan here before starting with them.
I will always be here, to give the OK and to help with the final coding, but not for assistance in the physical installation of the wires (read the threads for this).
Viperslider
- Drives: Seat Leon 5F Cupra ST 290
Hiya All,
Loads of great information in this thread.
I have a question of curiosity: with fitting a T6 7E0 090 BCM, why has the option of wiring the van exactly as the OEM diagram not been used instead of fitting relays and alike?
Can the BCM not handle all the light functions on a T5.1 but can on a T6?
Or is it a matter of parameters not being on the BCM?
Kind regards
Kind regards
Very summarized:
- There are two types of "OEM" electrical installations for the management of automatic lights on the PQ25 platform, and they depend on the model/year of BCM "MAX".
- The BCM MAX 7E0 can manage both types of electrical installations. It add Light Assist function.
- The previous BCM MAX to 7E0 (7H0 with D exception), can only manage the automatic lights through a Relay, and depending on the original electrical installation of the VW PQ25 model it is necessary to add another relay for the front fog lights.
The original electrical installation, the model/year of BCM that the owner of the VW PQ25 vehicle wants to install and what he wants to achieve, requires one electrical installation or the other.
In this forum all kinds of possible electrical installations have been made for the management of automatic lights for the entire PQ25... and many other related inventions. A complete success. 100% OEM.
Viperslider
Hi Ciclo,ciclo wrote: Thu Feb 17, 2022 7:25 pm Very summarized:
Thank you for taking the time to reply.
So from my understanding, an "E" year T5.1, with a 17 pin light switch, could in theory have a 7E0937090 BCM MAX fitted and then the wiring changed to match the OEM diagrams exactly and have full functionality? Without the need for relays or joins between the old T17 plug and new T10 plug?
I ask as that is what I would like to do. Replace my BCM with the one mentioned above (specifically that one so I can code in my keys), add in the additional 2.5mm inputs to the BCM, add the 1.5mm outputs to the lights, replace the stalks with the momentary type from a T6 (plus the wiring changes to T41/38-41) and add Auto lights. All this with the T10 wired directly to the BCM as per OEM diagrams.
Would this have any unusual issues? I am competent with making the looms and running them correctly but I have a lack of coding information, such as Byte 18.
I imagine the coding would be the trickiest part. I have VCDS, VCP and ODIS-S, all genuine.
Kind regards
You can do it without any type of problem, you will not have any type of failure detected in the Autoscan or malfunction if you do the electrical installation correctly.
Follow Limalex's thread. Link in a previous post.
BCM coding is no problem, I'll code it for you.
Post a full VCDS Autoscan here after finishing the electrical installation, I will receive a notification in my email.
(no problem if the Autoscan has faults detected in other units)
VCDS is fine for this enhancement.
Everything will work perfectly!!!
Viperslider
Hi Ciclo,ciclo wrote: Thu Feb 17, 2022 9:14 pm You can do it without any type of problem, you will not have any type of failure detected in the Autoscan or malfunction if you do the electrical installation correctly.
Fantastic, Thank you.
I will get the changes done tomorrow and post the scan.
I already have the 090 BCM fitted (For MFSW and T6 tailgate)
There are many changes, some subtle, some not so subtle! but this will be the biggest change to impact the BCM, I am grateful for your help.
Thanks for sharing the pictures.
They help when we take a look at the autoscan.
Cris-87
- Drives: vw golf 6 and vw t5 2014
Hello everyone,
my name is Cristian and I have a 2014 t5.
In this forum i found a lot of valuable info for the modification i'm doing on my t5 even if i think i've done something wrong.
I went from BCM 7H0 937 087 M to 7E0 937 090 B, I powered it as indicated by Ciclo, which I thank, and I followed the guide by fitting the wiring for the modified bi-xenon and the car lights wiring.
I purchased the lights control 3C8 941 431A and the dimmer 6Q0 941 334.
After having installed everything I see that the dimmer does not work and with the light switch in the positions the ignition is turned on without having the keys inserted. In addition, now I also have an error on the control unit 8
the bi-xenon are still on their way and will arrive soon.
hope you can help me solve my problem
I had installed the photochromic mirror and the rain light sensor in the past.
t5 with standard h7 headlights.
below some photos and scan of t5
Friday,18,February,2022,10:43:46:20530
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WV2ZZZ7HZEH033380 License Plate: ET177VR
Mileage: 227230km-141194mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 56 0B
VIN: WV2ZZZ7HZEH033380 Mileage: 227230km-141194miles
18-Aux. Heat -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FM HW: 03L 907 309 M
Component: R4 2,0L EDC H45 5584
Revision: 26H45--- Serial number: 00000000000000 CVN: C6B3BE41
Coding: 0119401A232600080000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM20TDI01103L906019FM 003003
ROD: EV_ECM20TDI01103L906019FM_003.rod
VCID: 7BF0727CF2B5525114-802E
VINID: 9E60AAAAA1D8A956000C30C8007318D246
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 208724AD11A7049824A588796A5E10
Shop #: WSC 02756 790 49152
VCID: 3A7EB778B50FAB594F-806E
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E5 907 040 AF HW: 7E5 907 040 AF
Component: ClimatronicT5 H19 0407
Revision: 00001004
Coding: 0004000102
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 6CD2412087DBC5E98D-8038
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 B HW: 7E5 907 049 B
Component: Heckbedienung H10 0202
Serial number: BHB-0012108130015106
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Date: 2022.02.18
Time: 00:07:37
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 316160497
Coding: F8DB79BA0A21200201200F607EEB9ED50084432F60844040320000010800
Shop #: WSC 02737 534 423142
VCID: 2A5E873845AF1BD93F-807E
Subsystem 1 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSen 11 1110
Coding: 07504D
Subsystem 2 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 3 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
2 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Time Indication: 0
Date: 2016.07.11
Time: 00:07:39
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Time Indication: 0
Date: 2016.07.11
Time: 00:07:39
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231319001650
Coding: 108004
VCID: 3B70B27CB235925154-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H07 0013
Revision: -------- Serial number: 003HL00JSFV5
Coding: 000000000000000000000000000000003033
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3564A44494114421A2-8060
Part No SW: 7E0 920 870 J HW: 7E0 920 870 J
Component: KOMBI H04 0710
Coding: 160E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 306A95506B736109F1-8064
Address 18: Aux. Heat Labels: 7E0-815-071.clb
Part No: 7E0 815 071 C
Component: J737__Standheizung 0605
Revision: 00087000 Serial number: 09024900A00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 25447404ECB134A112-8070
3 Faults Found:
00664 - Fuel gauge
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 226267 km
Time Indication: 0
Date: 2016.04.25
Time: 21:06:10
OFF
Temperature: 38.0∞C
Voltage: 14.35 V
Temperature: 4.0∞C
01414 - Combustion-Air Blower (V6)
007 - Short to Ground
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 8
Reset counter: 255
Mileage: 225757 km
Time Indication: 0
Date: 2016.04.22
Time: 08:30:55
Start
Temperature: 22.0∞C
Voltage: 13.94 V
Temperature: 3.0∞C
02251 - Heater Unit Locked
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 226546 km
Time Indication: 0
Date: 2016.05.18
Time: 21:27:50
Malfunction
Temperature: 40.0∞C
Voltage: 14.42 V
Temperature: 1.5∞C
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042207
VCID: 68DA3D309B23E9C9E9-803C
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 B HW: 09N 907 554 B
Component: Haldex 4Motion 6008
Coding: 0000009
Shop #: WSC 02756 790 00000
VCID: 3778AE4C461DB631B0-8062
Component: IMMO H04 0710
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADE47388D2FDBD9FF-803E
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:24)--------------------------
![Image]()
www.Ross-Tech.com
Revision: 00H43001
Revision: 00001004
Coding: 0004000102
Slave 1:
1 Fault Found:
U1113 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Date: 2022.02.18
Time: 00:07:37
Coding: 07504D
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Time Indication: 0
Date: 2016.07.11
Time: 00:07:39
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 227233 km
Time Indication: 0
Date: 2016.07.11
Time: 00:07:39
Coding: 108004
Coding: 160E01
Coding: 0000031
3 Faults Found:
00664 - Fuel gauge
Fault Priority: 7
Fault Frequency: 5
Reset counter: 255
Mileage: 226267 km
Time Indication: 0
Date: 2016.04.25
Time: 21:06:10
OFF
Temperature: 38.0∞C
Voltage: 14.35 V
Temperature: 4.0∞C
Fault Priority: 3
Fault Frequency: 8
Reset counter: 255
Mileage: 225757 km
Time Indication: 0
Date: 2016.04.22
Time: 08:30:55
Start
Temperature: 22.0∞C
Voltage: 13.94 V
Temperature: 3.0∞C
000 - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 226546 km
Time Indication: 0
Date: 2016.05.18
Time: 21:27:50
Malfunction
Temperature: 40.0∞C
Voltage: 14.42 V
Temperature: 1.5∞C
Revision: B9081001
Coding: 042207
Coding: 0000009
Serial number:
Address 56: Radio
Cannot be reached
- IMG_1917.JPG (2.4 MiB) Viewed 3346 times
- IMG_1916.JPG (2.4 MiB) Viewed 3346 times
Hí.
It seems that you have not done this procedure correctly. Replacement
http://wiki.ross-tech.com/wiki/index.ph ... eplacement
Please post an old Autoscan with BCM 7H0...087 installed.
edit: Please link me to the guide you have followed for your electrical installation.
Hi Ciclo,ciclo wrote: Fri Feb 18, 2022 5:08 am Thanks for sharing the pictures.
They help when we take a look at the autoscan.![]()
This is Craig (ViperSlider)
The site is refusing to allow me to post under my other username and also refusing to allow me to post my autoscan stating it contains contacts and is classing it as spam.
I also can’t contact any admin as I am “forbidden”.
Not sure what to do. If the admin are reading, could they advise?!
