I'm going to add a couple of LED auxilliary lights to my Polo, so I need to tap into the Can Bus system. I got as far as to figure out that the orange cables are Can High and Low, but not which one's what...
The CanM8 is also purchased, so all I need is to figure out this detail before I short circuit the entire system.
Can Bus High and Low
TomGron72
- Drives: 2018 VW Polo 1.0 Beats Energetic Orange
- IMG_5071.jpg (582.02 KiB) Viewed 3394 times
ho8882000
- Drives: 2019 (AW)
Re: Can Bus High and Low
Maybe this will help you:
orange/brown is always low. since brown is always the minus/ground/mass wire, it's easy to remember.
TomGron72
ho8882000 wrote: Thu Sep 30, 2021 6:48 pm Maybe this will help you:
Hey, thanks a lot!! That was awesome of you![]()
Now I just need to wait for the rain to end, because removing the entire front is something I like to do while dry...
Thanks again
TomGron72
Thanks, that's a great way to rememberiichel wrote: Thu Sep 30, 2021 7:31 pm orange/brown is always low. since brown is always the minus/ground/mass wire, it's easy to remember.
