GOLF 7.5 FL R-LINE
Re: GOLF 7.5 FL R-LINE
I have a Golf 7, and i Installed a high line camera
Connected the power cable, the video and the Can bus. when I put the reverse gear,
the VW logo opens and the camera is perfectly visible with the yellow lines moving when
I turn the steering wheel and the four different camera views working correctly when
you press the pictures on the screen, those that are in the circle of this picture:
But pressing the Park Pilot button to the right of the gear lever (Automatic) does not activate the camera
or the Park Pilot with a beep sound.
The Park Pilot is not activated on the screen when moving forward,
and only the beeps from the parking sensors sound.
I have tried various configurations with no success. The 6c camera module activates correctly
Any Ideas?
Any Ideas?
What is your current coding of Address 10?
10 Adapt
IDE11215-Automatic Activation,activated ,1
5F Adapt
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
10 Adapt
5F Adapt
dcgumis
- Drives: polo 1.4 85KM CGGB/GOLF 7.5
OKay, done
- 263953688_2877969555841562_5821266137454346922_n.jpg (51.3 KiB) Viewed 21188 times
- 263743143_591526041930299_6945259191847314699_n.jpg (45.82 KiB) Viewed 21188 times
Excellent!
Now you will know how cool it is to drive at night with Matrix LED headlights.
It is very important that the level of headlight height adjustment is done correctly to fully enjoy them. The high beams will be ON most of the time without dazzling oncoming traffic.
dcgumis
Yes, When I put on the lamps they were too high
The next day, I drove my car to diagnostic stations to set the lights I haven't had a chance to see how led DLA works yet
1 day difference between photos
- 263937079_1357665698001075_3853944989839257778_n.jpg (79.36 KiB) Viewed 21130 times
- 263746407_1487268614978304_8885189569042642028_n.jpg (44.41 KiB) Viewed 21139 times
- IMG_20211210_104614.jpg (441.89 KiB) Viewed 21139 times
dcgumis
- 267847161_675158926815042_5699466341824037767_n.jpg (66.95 KiB) Viewed 21030 times
- 266371371_256662523064168_4928873171362296186_n.jpg (105.84 KiB) Viewed 21030 times
Why?
Do you plan to install a DSG Emulator?
Did you install the proper steering ring for the heated steering wheel?
What happens when you press the Travel Assist button? I really ask. Please tell me.
dcgumis
I bought a complete steering wheel for 380 euro
In Poland, it's hard to get steering wheels without DSG.Over time, I will replace it with the normal one, I care about heating the steering wheel.The travel assist button is inactive
Today the courier delivered 5Q0 953 549 D I'm still waiting for
5q0972726
My coding - AF0300
But the view button doesn't work for me And the previous steering wheels did not have it
5q0972726
My coding - AF0300
- 267728650_655510492124982_4225071096086731736_n.jpg (35.35 KiB) Viewed 20964 times
OK, ... some things to fix there ... (GW)
With that amount of money you could have bought a full last generation MFSW "in NEW condition" and suitable for your Golf with manual transmission.
Happiness is a subjective state of well-being
dcgumis
I just finished the heated steering wheels heats up very cool
I coded the block 08:
byte 11 bit 2-3
But the steering wheel icon does not appear in the air conditioning menu when the steering wheel heater is on, only the icon is shown in the top right corner.
byte 11 bit 2-3
I tried many encodings,2C0300 the view works but the heating does not workOK, ... some things to fix there ... (GW)
- 267926838_4947977478567690_287399748773449161_n.jpg (54.22 KiB) Viewed 20852 times
- 266905083_497373861812291_5343215293480406673_n.jpg (74.84 KiB) Viewed 20852 times
- 267306337_937155160563500_3780626157905649523_n.jpg (18.44 KiB) Viewed 20852 times
- 268296800_1084746738990606_2794223413116945352_n.jpg (59.31 KiB) Viewed 20852 times
The following link is my Christmas gift for you, ...although you don't deserve it
https://a.d-cd.net/ukAAAgAJ7-A-960.jpg
from here https://www.drive2.ru/l/572945614703181095/
... (10zt
dcgumis
Hello Thank you for the Christmas gift
This is how I saw this post from 10 PLN earlier, I meant the "View" button ,The view button works on a different coding, but again the heated steering wheel button does not work
I'll try to work on it later
Planned modifications
PLA 2.0 or PLA 3.0 which is better?
TMPS
pACC Will it be able to run on my radar?
Thank you happy new year
TMPS
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2B00600159FFC728949C810560400600000000000000000000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 3E253BD560F54A6B617-806A- Attachments
- IMG_20220107_231640.jpg (190.14 KiB) Viewed 20546 times
Maybe you will find the solution for the heated steering wheel button by reading the following link, or at least some clues as to why the heated button on your steering wheel is not working.
https://www.drive2.ru/l/566248764256288809/
In the evolution of the Golf 7-7.5 , MQB platform, the steering ring went from being an individual control unit with CAN lines - comfort/convenience - Address 16, to being a BCM subsystem with 2 LIN - BCM, Gateway-.
Previous generation heated steering wheels didn't have a physical button on the steering wheel, it was either on the center console buttons (two wires from BCM) or on the HVAC unit.
Note: Slavik have the steering column ring hardware "just like you", address 16, and on his steering wheels, the button to heat the steering wheel does work.
It may be a hardware or software compatibility issue, but since you don't post a full autoscan after your modification, we can't draw any conclusions.
