Channel 44 vcds
Derekw28
Drives: 6r gti
Channel 44 vcds
Post by Derekw28 »
Has anyone got the security login number for channel 44 on vcds for my 2011 gti? Had a look online and cant find it anywhere
Re: Channel 44 vcds
Why do you need it?
Derekw28
Drives: 6r gti
Re: Channel 44 vcds
Post by Derekw28 »
For some reason the steering is set on the lightest setting, i just want to change it to the proper setting as its a bit too light for my liking
Re: Channel 44 vcds
just change the program in the long coding. you don't need security access for that.
Derekw28
Drives: 6r gti
Re: Channel 44 vcds
Post by Derekw28 »
It needs security login to change the coding, there is no long coding available so i need to change it via normal coding
Derekw28
Drives: 6r gti
Re: Channel 44 vcds
Post by Derekw28 »
Re: Channel 44 vcds
thats power steering pump? Ypu dont need security acess pin to change the coding. just add the numbers
Re: Channel 44 vcds
So you can change the coding, right? It's the upper box.
Derekw28
Drives: 6r gti
Re: Channel 44 vcds
Post by Derekw28 »
I can change it but as soon as i press do it it reverts back to these values
Re: Channel 44 vcds
are you sure that you are subtracting and adding the numbers correctly?
Derekw28
Drives: 6r gti
Re: Channel 44 vcds
Post by Derekw28 »
Tried everything, never come across this and ive had vcds for years
mirceaculita
Drives: 6R 1.2TDI 75hp
Re: Channel 44 vcds
Post by mirceaculita »
go in options, test, make sure it says can ok and press apply then go and change the numbers.
