BCM Max Transporter 2013
samul
Drives: T5
Re: BCM Max Transporter 2013
Post by samul »
I just upgraded 086b to 087m and have similar error like you:
“00329 - Control Circuit for Unlocking Rear Lid
011 - Open Circuit“
Do you have 2 wings door or 1 lid? How you resolve it?
Do you have sliding doors? They are working fine with interior lights? Door are close but instruments and vcds says that they are open, if I open them vcds says that they are closed🙈 maybe you know how to solve it?
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
I have this fault because I retrofitted non oem electric tailgate
Please post an auto scan abd sure ciclo will help you
samul
Drives: T5
Post by samul »
Chassis Type: 7H-VN75 (6N0)
56-Radio -- Status: Not registered 0011
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H32 9126
   Revision: 26H32---    Serial number: 00000000000000
   Coding: 01194012231400080000
   Shop #: WSC 51187 142 82990
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002012
   ROD: EV_ECM20TDI01103L906022CH_002.rod
   VCID: 6DD17CB3BC91F7277E-8038
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0103
   Revision: 00H43001
   Coding: 508724AD89A60A9C24A79171695F10
   Shop #: WSC 02736 790 49152
   VCID: 3467A9D7973B66EF71-8060
1 Fault Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.21
                    Time: 01:46:36
                    Count: 0
                    Count: 2065
                    Count: 128
                    Count: 252
   Part No SW: 7E5 907 047 AA    HW: 7E5 907 047 AA
   Component: Climatic-T5   H10 0101
   Revision: 00004001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01002
   ROD: EV_ClimaT5Basis.rod
   VCID: 6ED37BBFB1970C3F47-803A
1 Fault Found:
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 283661 km
                    Date: 2022.01.29
                    Time: 00:03:53
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 M    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0413
   Revision: BO034001    Serial number: 0573 099140915
   Coding: 2A2038B80A21201300204810380B8C500000430F60040000320000000000
   Shop #: WSC 02759 790 12345
   VCID: 3E738BFFA977BCBF97-806A
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3310
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3310
2 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.21
                    Time: 00:05:38
03302 - Response Closing Status of Passenger's Door
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 91
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.21
                    Time: 00:00:31
   Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
   Component: VW10Airbag00N H05 0011
   Revision: --------    Serial number: 003E5000RVF9
   Coding: 00000000000000000000000000000000304E
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
   ROD: EV_AirbaVW10BPAVN750_VW12.rod
   VCID: 3467A9D79F3B66EF71-8060
   Part No SW: 7E0 920 860 A    HW: 7E0 920 860 A
   Component: KOMBI         H16 0111
   Coding: 160A00
   Shop #: WSC 00000 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
   VCID: 2643439F59E7047FFF-8072
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0413
   Revision: BO034001
   Coding: 042200
   VCID: 70EF65C7A3A31ACF55-8024
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.21
                    Time: 11:02:10
Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H16 0111
   Serial number:
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   ROD: EV_Immo_UDS_VDD_RM09.rod
Address 56: Radio
Cannot be reached
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000122018278
   Coding: 4100000100000000
   Shop #: WSC 02736 790 00000
   VCID: 2F6DA6BB7E1D45370C-807A
End-------------------------(Elapsed Time: 02:24)--------------------------
1. Radio - cannot be reached because i have android from aliexpress, it has some VAG module but VCDS show error, i remove it from CAN gateway installarion list
2. ABS error - i think it's because acu is low (11.8V), it's charging right now
3. 00329 - Control Circuit for Unlocking Rear Lid - this error is permanent
4. Sliding doors, there is no error, when doors are open vsds says closed, when i close them vcds says open (like on the picture)
Hello samul.
Are you absolutely sure that by making the BCM change from 086b to 087m you transferred the BCM and Gateway codings from one BCM to the other?
samul
Drives: T5
Post by samul »
I first tried to copy old coding, paste in new bcm, but it was rejected… so based on my print screens I checked manually all the same options in bcm, similar for can gateway and then it was accepted.
Please post the BCM 086 coding (and Gateway) in text form just before the change (no image or photo, please). Thank you.
... a full autoscan would be better.
samul
Drives: T5
Post by samul »
This auto scan i made before i remove bcm 086 from car.
   Revision: 00H43001
   Revision: 00004001
   Coding: 0000000002
   Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
   Component: BCM T5GP M++4 H46 0207
   Revision: BM046001    Serial number: 0154 341090297
   Coding: B8A0203A0E212023002000003C2B8E500000430F60062040300000000000
   Shop #: WSC 02736 790 12345
   VCID: 326BAFCF6D2F68DF63-8066
7 Faults Found:
00910 - Indicator Lamp for Emergency Flashers (K6)
            007 - Short to Ground - Intermittent
                    Fault Status: 00100111
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 283490 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 03:23:03
00063 - Back-Up Light Switch (F4)
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 173
                    Mileage: 283331 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 00:10:28
03301 - Response Closing Status of Drivers Door
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 283594 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 02:34:35
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 283594 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 02:34:35
03303 - Response Closing Status of Rear Left Door
                    Fault Priority: 2
                    Fault Frequency: 15
                    Reset counter: 175
                    Mileage: 283331 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 00:18:53
03304 - Response Closing Status of Rear Right Door
                    Fault Priority: 2
                    Fault Frequency: 26
                    Reset counter: 175
                    Mileage: 283331 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 00:18:53
03442 - Return Message Closing Status of Rear Lid
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 283594 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 02:34:35
   Coding: 160A00
   Part No SW: 6N0 909 901     HW: 7H0 937 086 B
   Component: GW-K-CAN TP20 0207
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 276384 km
                    Time Indication: 0
                    Date: 2016.06.18
                    Time: 12:11:34
   Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:21)--------------------------
Try to enter this BCM coding:
A8A020380E212023002000103C2B0C500000430F60060000300000000000
If it is accepted, Clear all DTCs, make the appropriate checks and do a new autoscan.
samul
Drives: T5
Post by samul »
thx ciclo error 00329 vanish, new coding was accepted
something also changed with interior lights and sliding doors:
- all door close and unlock, instruments doesn't show that they are open also radio confirm that they are closed, but when i start engine interior lights are still enable :?
- when i open sliding doors radio confirm this fact
- when i stop engine, get off the car and lock by pilot interior lights turn off
- and 2 errors arrived, they are Intermittent but return
   Revision: 00H43001
   Revision: 00004001
   Coding: 0000000002
   Coding: A8A020380E212023002000103C2B0C500000430F60060000300000000000
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.23
                    Time: 01:34:30
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 131
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.23
                    Time: 01:34:30
   Coding: 160A00
   Revision: BO034001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
   Serial number:
Address 56: Radio
Cannot be reached
Disconnect the battery for a few seconds, reconnect, Clear all DTCs, do the relevant checks...
If we do not achieve a good result we will have to investigate a little more...
Do you still have the BCM 086?
samul
Drives: T5
Post by samul »
Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
Readiness: 0 0 0 0 1
   Revision: 00H43001
   Revision: 00004001
   Coding: 0000000002
   Coding: 160A00
   Revision: BO034001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 283661 km
                    Time Indication: 0
                    Date: 2016.06.24
                    Time: 00:04:17
   Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:23)--------------------------
The interior lights continue to work with the ignition on.
Yes i still have bcm 086
Ok, I assume you have repeatedly checked the opening and closing of the rear sliding doors, and then you have done the autoscan, right?
I'm assuming your T5 doesn't have interior lights dimmer switch installed?
Please tell me the exact month and year of manufacture of your T5, it is important to check the diagrams.
samul
Drives: T5
Post by samul »
What exactly I made today:
Unplug acu -> wait a 2-3 minutes -> plug it back -> auto scan -> remove errors -> auto scan -> open and close sliding doors -> read errors -> run engine -> check errors -> enable lights -> disable lights > check errors
Production date: 2010-01-12
I have interior lights on front like this https://bt-cars.pl/223404-large_default ... 105-c-.jpg but i assume this isn’t what you asking for?
This is basic, naked transporter 😕 i changed switch lever, add 3 wires to instruments and active mfd. changed light switch (from AliExpress with internal light sensor) but drl wasn’t started so I left it. Right now I changed bcm to install ccs but I stuck with mentioned earlier problems. No more changes in wiring
Well, it is highly likely (but not 100%) that the problem is in the BCM coding regarding the "model" of lock installed for the central locking of the tailgate.
I think the lock is not sending the correct signal to the central locking and that is why the interior light stays on in the conditions where it should go off.
The Bytes involved are Byte2 (Bit3 and Bit5) and Byte7 (Bit4 and Bit5).
;LC,02,3,Zentralverriegelung/Heckklappe: ZV-Regler in eine Richtung verbaut
;LC,02,5,Zentralverriegelung/Heckklappe: Schloss mit vorheriger Verriegelung verbaut
;;LC,07,4,Heckklappenschloss mit Safe
;;LC,07,5,Motor fur Zentralverriegelung Heckklappe NICHT verbaut
It is impossible for me to know what type of central locking lock your T5 has installed for the tailgate, so you will have to try all possible combinations of said Bytes until the interior light does not stay on under normal conditions.
Start by testing this new BCM coding:
A8A0393A0E212013002008103C2B8C500000430F60060000300000000000
to know what new faults appear...
The fault diagnosed in the Gateway will disappear once the BCM coding is correct.
samul
Drives: T5
Post by samul »
It seems that i have bad coding since i bought this car... I found auto scan from 11 May 2021, there was also Intermittent errors from sliding doors.
   Revision: 00H43001
   Revision: 00004001
   Coding: 0000000002
   Coding: A0A0203A0E212023002000003C2B8C540000430F60062040300000000000
2 Faults Found:
                    Fault Priority: 2
                    Reset counter: 216
                    Mileage: 255207 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 20:04:40
                    Fault Priority: 2
                    Reset counter: 222
                    Mileage: 255207 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 20:04:40
   Coding: 160200
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Reset counter: 255
                    Mileage: 255179 km
                    Time Indication: 0
                    Date: 2015.05.15
                    Time: 16:50:42
   Serial number:
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:20)--------------------------
Is there any chance to get somehow original coding of bcm 086?
this was latest coding from you, earlier i paste you auto scan without errors... after night errors from sliding doors return.
I spent some time testing the encodings today, i tried to disable almost all function... currently waiting for the battery to recharge,
