- ag69
- Drives: 1.2TSi 77Kw 7DSG
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
Yes as usual tons of information to brain.
A lot of hard work, iichel !!!
Bottom of the passenger seat...
So I decided to have some more USB charging.
I took the Golf 7 rear armrest assembly like posted here: viewtopic.php?p=589140#p589140
And cut out the USB part
Made a rectangular hole in my armrest
And glued it in...
And glued it in...
- ag69
very nice
not visible and exclusive to front passenger
I think I remember that CNK also did a nice installation for USB charging sockets in the armrest... https://www.drive2.ru/l/537529795416686692/
Yes ik afraid I lost that chair now. The worse part is, there is another cat
Scheme for ventilation:
Hi iicheliichel wrote: ↑Fri Jan 14, 2022 5:39 pm
How I got by the issue of the D/S indicator in the lever head not being illuminated.
to illuminate the D/S in S mode. the dsg selector mechanism has some kind of error detection on the LED.
if I connect both one or wires to the D/S LED (T10/6) it will go out after a few seconds. I don't think there is a DSG bit/byte to disable light diagnostics on the dsg lever
I tried using your scheme with optocoupler relay to install led dsg lever on my 6R. Unfortunately it didn't work perfectly for me. I went into some deep thinking and experimenting after which I came out enlightened with a simple solution.
I tricked the new led dsg lever with a rectifier diode without using optocoupler relay . Works just perfect... super happy.
Will share the details soon in my thread.
Haha great. Does your led stay on with a running engine too?
Earlier infos --> viewtopic.php?p=589020#p589020
Installed the module, CAN, power and GND and the rear two dampers:
(left is J941 Terminal 15 relay for trailer connection T13/10)
In progress, step by step, as it should be...
The last image reminds me that I have to update my Xhorse.
From 2.3.1 to 2.3.2, in case you might be interested.
Info for everyone:
It is moderately good for ICs after 2014 with 0805 SW -->, also logically for those before 2014, 0709, etc. (mainly European and Chinese market).
It avoids having to disassemble the IC to activate some functions in the EEPROM and some other things... read on the official website.
