Polo 6R ABS CODING
Re: Polo 6R ABS CODING
Sorry to hear. I'm afraid I'm not 100% familiar with the codings of these ABS pumps (6C0) so I won't give it a try. Sorry.
- Drives: 2015 1.4tdi bluemotion comfortline LHD
Ok, I understand
I suppose a possibility would be to go to the VW dealership or someone with an online ODIS connection to get the ABS unit coded online.
- Drives: Vento 1.5TDi DSG
I have a Vento 1.5TDI DSG in India RHD. I have recently changed to 288mm brakes in front and have rear drum 200mm. I tried to do the long coding but it fails always. I tried 44 and 4c for 288+200mm combination but it fails.
Looking for pointers wrt to vcds coding. I can provide information as needed
You could start with posting a vcds scan of your current configuration
Long coding is this in existing setup with 256mm front disc nd 200mm rear drum
62DD2C63422B07C54614346A4256E0820908
Sunday,06,March,2022,12:42:18:00009
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: MEXK16605HT085015 License Plate: 8887
Mileage: 36970km-22972mi Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 04 08 09 15 17 19 25 44 56
VIN: MEXK16605HT085015 Mileage: 36970km-22972miles
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CWXC) Labels: None
Part No SW: 03L 906 023 SA HW: 03L 907 425 B
Component: R4 1.5l TDI H33 9977
Revision: --H33--- Serial number: CVN: 2883BDAD
Coding: 00250116032500080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM15TDI02103L906023SA 001002
ROD: EV_ECM15TDI021_VW25.rod
VCID: 77F7B61ECECD4D3170-8022
VINID: 755A1B046180158900205001142376F36D
Readiness: 0 0 0 0 1
Part No SW: 0AM 300 066 S HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 052 2505
Revision: 00005026 Serial number: CU501608076176
Coding: 0000020
Shop #: WSC 00642 210 45725
VCID: 40851DC21383CA8901-8014
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63422B07C54614346A4256E0820908
VCID: 0B1FFAEEA24559D124-805E
Serial number: 30071613471297
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF9A33AE1F77C7933-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 418318C6D889C3810E-8014
Part No SW: 6RU 937 087 P HW: 6RU 937 087
Component: BCM IM H+4 H41 0444
Revision: BZ041001 Serial number: 8700 282160206
Coding: 3A984BFF08A10000013800006E0B06900080600F608E0100220000000A00
Shop #: WSC 124697 483 00190
VCID: 6FE78E7EBE9D05F1A8-803A
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 210716 04 42 0106
Coding: 036800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2521
Serial number: 13202848160720123626
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2521
Serial number: 13202849160628012455
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2071600534400115AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13202728160721075513
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13202729160725085809
1 Fault Found:
00975 - Heated Rear Window (Z1)
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 32524 km
Time Indication: 0
Date: 2019.01.13
Time: 09:53:20
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW016TP9Z
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499300E6E8B90BC1D6-801C
Part No SW: 6RF 920 862 A HW: 6RF 920 862 A
Component: KOMBI H01 0215
Coding: 1108000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
VCID: 4A913FEAEDBF00D9DF-801E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087
Component: GW-K-CAN TP20 H41 0444
Revision: BZ041001
Coding: 002300
VCID: 193390A61099BB41A6-804C
1 Fault Found:
01304 - Radio
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 253
Mileage: 32524 km
Time Indication: 0
Date: 2019.01.13
Time: 09:54:30
Component: IMMO H01 0215
Serial number:
VCID: 6AD19F6A8D7FE0D9FF-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
VCID: 418318C6D089C3810E-8014
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:52)--------------------------
62DD4463422B07C54614226A4256E0820908
and in case it works, you can change ....08 to ...0C to activate XDS differential.
Many thanks.i see both same or i am I missing something. I will try today and will keep you posted.
And change which 08. I see 2
My bad but try this one first anyway please
Tried it didnt work. Coding rejected 31
As far as I know, your stock SW version of ABS pump will not accept coding for 288mm front disc upgrade.
ROD: EV_Brake1ESP90
You need to flash updated SW version using VCP/ODIS.
Let iichel or other experts of the forum confirm this.
Good luck
ROD: EV_Brake1ESP90
Good luck
Give this a try please:
62DD4C63422B07C54614326A4256E0820908
Thanks will let you in 6-7 hours
I've been checking upon the BN firmware on your device seems to only exist with 256mm fronts and either 232mm front discs or 200mm drum brakes
Checked an the 2nd one also didnt work. Can we do something else to make it work? i.e updating the software etc like @patil mentioned earlier
