Nithish's Polo 6R(Ameo) 1.5TDI
nithishsabapathi
Drives: Ameo TDI (polo 6r compact sedan!)
Post by nithishsabapathi »
Hai All,
My daily drive is a VW Ameo, A car which is created specially to comply with a weird govt. rule wherein the cars which come under 4 meters in length will enjoy a lower tax slab.
The Ameo is essentially a shortened version Polo 6R Sedan with the wheel base of a polo 6R Hatch.
I have been amazed to see people doing crazy retrofits to their cars and I am delighted to be a part of this community.
I am new to this retrofitting world and have done some retrofits in my car:
1. Installed a MFSW Steering wheel.
2. Upgraded the Stock radio(RCD320) to a OEM Visteon RCD330 Unit and installed the OEM reverse camera.
3. A Maxidot Cluster from a Seat Toledo with SW0607 and HWH16(Installation In progress).
4. Cruise Control System.
Planned Retrofits as of now:
1. Gra-HIGH Activation(If possible)
2. 8k OPS(Parts are on their way)
3. BCM Max and associated retrofits like TPMS,etc.
and finally a DQ200 DSG/ AQ250 Torque converter in the future :D .
Last edited by nithishsabapathi on Thu Jul 07, 2022 11:55 am, edited 1 time in total.
nithishsabapathi
Re: Nithish's Polo 6R(Ameo) 1.5TDI
I Need some assistance in enabling Gra- High in my car,
my car has the following ECU:
Continental 03L 907 425B Diesel SIMOS PCR21.
A Seat Toledo Cluster with SW 0607.
Can the Gra-High be activated on the above ECU and the Cluster combination or do i need any emulator to do this?
Any assistance would be helpful.
WhatsApp Image 2022-07-04 at 11.41.03 PM.jpeg (37.59 KiB) Viewed 2753 times
Last edited by nithishsabapathi on Thu Jul 07, 2022 4:39 pm, edited 1 time in total.
Some pictures would be nice
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
By the time Nithish adds his ameo photo and scans , here is link which has some photos from different angles.
https://www.motorscribes.com/features/a ... t-to-catch
nithishsabapathi
Sorry Guys! Bit caught up with work. Adding photos to the original post.
Here is my current Auto-scan:
VIN:    License Plate:
Mileage: 44310km-27532mi   Repair Order: 1
Chassis Type: 60-VW25 (6RU)
Scan: 01 03 09 15 17 19 25 44 56
VIN:    Mileage: 44310km-27532miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CWXC)       Labels: None
   Part No SW: 03L 906 023 RS    HW: 03L 907 425 B
   Component: R4 1.5l TDI   H33 9977
   Revision: --H33---    Serial number:
   Coding: 00110112030500080000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_ECM15TDI02103L906023RS 001002
   ROD: EV_ECM15TDI02103L906023QT.rod
   VCID: 081F2D27B33332C64A-805C
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CA    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0004
   Serial number: --------------
   Coding: 60DD2763412718C30614E472825518020000
   Shop #: WSC 12345 123 08192
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 7F0DB6FBE6FD757E7B-802A
   Part No SW: 6RU 937 086 P    HW: 6RU 937 086
   Component: BCM IM M+4    H41 0444
   Revision: BY041001    Serial number: 8600 195170306
   Coding: 3AB02BBF08A10400003800002C2814100000400F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 6ED37BBFB9970CF6E0-803A
   Subsystem 1 - Part No SW: 6R0 959 802 DF    HW: 6R0 959 802 DF  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  022 1552
   Serial number: 13202722170405182516
   Subsystem 2 - Part No SW: 6R0 959 801 DD    HW: 6R0 959 801 DD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  022 1552
   Serial number: 13202723170328055455
   Subsystem 3 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Serial number: 2451607460200844AB2B
   Coding: 240000
   Subsystem 4 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13102728170509121731
   Subsystem 5 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729170425235133
   Component: VW10AirbagU0S H10 0020
   Revision: --------    Serial number: 003GW01AK8Z$
   Coding: 003053
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999E823E8B90BCE95-801C
   Part No SW: 6RF 920 862 B    HW: 6RF 920 862 B
   Component: KOMBI         H01 0217
   Coding: 1508000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 4B95D22BE2C519DEA7-801E
   Part No SW: 6RU 909 901     HW: 6RU 937 086
   Component: GW-K-CAN TP20 H41 0444
   Revision: BY041001
   Coding: 002300
   VCID: 193978631099BB4EE5-804C
   Component: IMMO          H01 0217
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADB77AF8D7FE0D6BC-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   Shop #: WSC 12345 123 12345
   ROD: EV_SteerAssisNSK_014_VW25.rod
   VCID: 4189F003D089C38E4D-8014
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         557 5516
   Revision: --------    Serial number: VWZ7Z2S0100594
   Coding: 0E000440000001
   Shop #: WSC 01234 785 00200
   VCID: 4999E823E0B90BCE95-801C
End-------------------------(Elapsed Time: 05:24)--------------------------
patil
Post by patil »
Hello Nitish... Welcome to the forum :)
Have you successfully installed Toledo cluster in your Ameo?
patil
Post by patil »
Regarding GRA high--
Your Simos PCR 2.1 ECU can be read by using tools like Kessv2, FGtech gelatto easily I guess. I am pretty sure there are tools to read and write your ECU without dismantling it. The biggest hurdle is to know if your ECU firmware supports GRA High, if yes then next hurdle is to know the exact address to activate it.
You must find a car having same ecu/engine having GRA preactivated from factory to begin with. You also request for help from Master Ciclo, Slavik, firegrafik... they have done extensive research and work on GRA activation. I think it's a tough job, but you can always give a try.👍
patil
Post by patil »
I can say with absolute certainty that it is indeed possible to activate GRA High in your Simos PCR2.1 ECU without need of any kind of emulator.
Ofcourse with the help of right tools and right people. :wink:
nithishsabapathi
patil wrote: Thu Jul 07, 2022 6:43 pm Hello Nitish... Welcome to the forum :)
Hai Patil,
Thanks for the reply!
Yes, I have Installed the Toledo cluster in my Ameo.
Apparently VW has blocked the Installation of USED clusters, so did some workarounds and installed the cluster sucessfully.
patil wrote: Sun Jul 17, 2022 11:31 pm I can say with absolute certainty that it is indeed possible to activate GRA High in your Simos PCR2.1 ECU without need of any kind of emulator.
That's Amazing patil, As of now I only have VCDS with me and Aliexpress being banned in our country I've been looking for someone who can read my ECU.
patil
Post by patil »
nithishsabapathi wrote: Tue Jul 19, 2022 6:37 pm
Congratulations. I will tell you a secret which only you know... I know exactly who programmed that toledo cluster in your Ameo😁
You may be wondering how I know.. apparently we live in a same small world :mrgreen:
Now go back to him again, your ECU needs to be unlocked before can be read. He will do it on bench and read your ECU file, I've already put a word to him.
Once you get the ECU file, it needs to be edited to enable GRA High and edited file needs to be reflashed again. Honestly I don't know how to do it, I never did on my Polo, Master ciclo did it for me. I think your best bet is Master ciclo.. request him in a humble way he might help you.
Good luck👍
nithishsabapathi
patil wrote: Wed Jul 20, 2022 7:29 pm
I was about to ask you this when I saw the pictures of your cluster in his bench and apparently he told me that you had visited him. :D Actually we were about to take the dump but it was too late and I left in a hurry😬. I'll be visiting him by this weekend and will take the dump.
Will ask Master Ciclo if he can help me. :mrgreen:.
Thanks!
nithishsabapathi
Guys,
I'm getting an oil lamp error in my cluster, Upon scanning with VCDS, its the error for the Oil level thermal sensor signal High time > maximum.
I have attached the autoscan of my instrument cluster below. Is there any way to solve it or will have to live with it?
I have no other error codes elsewhere. also attaching the images of the error.
https://imgur.com/a/modH4xl
Monday,25,July,2022,17:18:10:00009
VCDS Version: 20.4.0.1 (x64)
www.Ross-Tech.com
                Address 17: Instruments       Labels: 5K0-920-xxx-17.clb-SRI1
Control Module Part Number: 6JA 920 940 A    HW: 6JA 920 940 A
  Component and/or Version: KOMBI         H16 0607
           Software Coding: 120A00
            Work Shop Code: WSC 73430 031 00216
              ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716 (SK25)
                       ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
                      VCID: 3A7B87EFBD5F90560C-806E
2 Faults Found:
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 109
                    Mileage: 51180 km
                    Date: 2081.14.02
                    Time: 09:43:29
13639427 - Please Check Fault Codes in Engine Control Module
          U101F 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 122
                    Mileage: 51591 km
                    Date: 2081.14.07
                    Time: 21:45:44
Thanks!
patil
Post by patil »
nithishsabapathi wrote: Mon Jul 25, 2022 5:29 pm Guys,
Easy :wink:
Go to adaptation channels of address 17, in drop down menu search for TOG in the list, click it and then select oil level sensor not connected to cluster, and select do it.
See below:
nithishsabapathi
patil wrote: Mon Jul 25, 2022 7:17 pm Easy :wink:
Thanks Patil, It worked!
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
nice mini sedan , very interesting variation of polo.
if you want to retrofit direct tpms you will need to update your instruments to 07xx or later.
you can use 0729 firmware from amarok 2h0.
just dit it on my toledo, I have an issue with my mfsw but it is SEAT related, otherwise it is ok
Also I have almost the same ecu , I am interested in GRA-High too
