Seat Toledo 1.6 TDI - PQ25 BCM Max + Other Mods
patil
Re: Seat Toledo 1.6 TDI - PQ25 BCM Max Upgrade
Post by patil »
til3tsio wrote: Mon Jan 24, 2022 12:03 pm I played with the eeprom today,
7E0 BCM should do the trick for you.
til3tsio
Drives: Seat Toledo KG
Re: Seat Toledo 1.6 TDI - PQ25 BCM Max + Other Mods
Post by til3tsio »
Hi everyone !
Finally I was able to allocate some time to work on the bcm conversion and fix some other things
OMG ! it was a very time consuming process and definitely not for the faint hearted.
Because I am a tall guy the option to remove everything instead of crawling underneath the dash was more viable.
I rerouted most of wires and added some new as needed. it took me 4 evenings after work.
Added some extra things in the process like Front assist radar and High beam assist mirror.
I need to flash the mirror to pq25 and code the radar (maybe remove component protection) - Pending !
I made same coding alterations to bcm but as I am not so familiar with that level of of configuration , I will share it here to get usable info.
I am using a 5GG light switch temporarily because I am unable to find the one that I need , it may raise some issues.
Saturday,06,August,2022,21:33:01:00009
VCDS Version: 22.3.1.4 (x64)
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: VSSZZZNHxxxxxxxxx   License Plate:
Mileage: 82440km-51225mi   Repair Order:
Chassis Type: NH-SK25 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 19 20 25 2E 37 3C 44 56 65 77 0B
VIN: VSSZZZNHxxxxxxxxx   Mileage: 82440km-51225miles
20-High Beam Assist. -- Status: Cannot be reached 1100
3C-Lane Change -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LD    HW: 03L 906 023 Q
   Component: 1,6l R4 CR td H33 9972
   Revision: --H33---    Serial number:                CVN: EAEEC454
   Coding: 00114036002400080000
   Shop #: WSC 73430 031 00113
   ASAM Dataset: EV_ECM16TDI02103L906023LD 003010
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 73E56ACBDAB52117C2-8026
   VINID: 9A38EAAAA798A9604004710014A6C34A86
Readiness: 1110 1000
Address 03: ABS Brakes (J104)       Labels: 1S0-614-517.clb
   Part No SW: 1S0 614 517 L    HW: 1S0 614 517 F
   Component: EBC 460 ESP   H16 0023
   Serial number: A00OXLH
   Coding: 53CC487889AE00F8CAFE12F591AE00402FBC00
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1ESPEBC460TRW 002004
   ROD: EV_Brake1ESPEBC460TRW_002_SK25.rod
   VCID: 387F9DE78353824F37-806C
Address 08: Auto HVAC (J255)       Labels: None
   Part No SW: 6JA 907 044 A    HW: 6JA 907 044 A
   Component: Climatronic   H05 0106
   Revision: A1001000    Serial number:  1409091A-0329
   VCID: 3A7B87EFB55F905FC1-806E
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 174160079
   Coding: 7A980B8000DB1400B3080E306ECB16D80F80600F608E23D0020400014800
   Shop #: WSC 02737 022 336249
   VCID: 2A5BB7AF45FF20DFB1-807E
   Component: RLHS 200618 0  50  0107
   Coding: 0728DD
   Subsystem 2 - Part No: 5J0 951 172
   Component: DWA-Sensor H0  H03 1211
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H03 1301
   Subsystem 4 - Part No: 5J0 951 172
   Subsystem 5 - Part No SW: 6JA 919 719 D    HW: 6JA 919 719 D
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000A0834130814
   Coding: 001000
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 82447 km
                    Time Indication: 0
                    Date: 2016.12.27
                    Time: 00:37:32
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 82447 km
                    Time Indication: 0
                    Date: 2016.12.27
                    Time: 00:37:32
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391501419364
   Coding: 0071196001
   Shop #: WSC 73430 790 00045
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 377D9EDB8E4D8D373E-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 82447 km
                    Date: 2022.08.06
                    Time: 00:37:30
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 34D 959 655 B    HW: 34D 959 655 B
   Component: AirbagVW20    005 0366
   Serial number: 003K7R051XKU
   Coding: 88CCC00000000000540000CA000000000065
   Shop #: WSC 73430 790 00113
   ASAM Dataset: EV_AirbaVW20SMEVW253 001110
   ROD: EV_AirbaVW20SMEVW253.rod
   VCID: 3467A9D79F3B662F1B-8060
   Subsystem 1 - Part No SW: -----------    HW: 480 412 710 14
   Component: SideSensor_Df  003 0148
   Serial number: 349001A011523162BF1W
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 480 410 811 14
   Component: SideSensor_Pf  003 0148
   Serial number: 350001A01202FAA32D1Z
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 480 412 710 14
   Component: SideSensor_Dr  003 0148
   Serial number: 351001A011523C62FE94
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 410 811 14
   Component: SideSensor_Pr  003 0148
   Serial number: 352001A01202FE726C73
   Coding: 2D2D2D
   Part No SW: 6JA 920 840 E    HW: 6JA 920 840 E
   Component: KOMBI         H01 0711
   Coding: 110E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 3D718CF3AC71A767E4-8068
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 322204
   VCID: 68DF0DA79B73D2CF67-803C
1 Fault Found:
03395 - Control Module for High Beam Assistant
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 82447 km
                    Time Indication: 0
                    Date: 2016.12.27
                    Time: 00:37:37
   Part No SW: 57A 857 511     HW: 3G0 857 511 G
   Component: FLA           H10 0010
   Revision: AA001001
   Coding: 000000E200000100000000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_HighBeamAssisAU33X 001019
   ROD: EV_HighBeamAssisAU33X_VW37.rod
   VCID: 68DF0DA79373D2CF67-803C
6 Faults Found:
13238273 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
                    Communication status of data bus 1-ABS Control Module: No communication
                    Communication status of data bus 1-Data Bus On Board Diagnostic Interface: No communication
                    Communication status of data bus 1-Engine Control Module: No communication
                    Communication status of data bus 1-Vehicle Electrical System Control Module: No communication
                    Communication status of data bus 1-Steering column electronic systems control module: No communication
13238274 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
13238275 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
13238276 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
13238277 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 206
15466752 - Control module not coded
          U1013 00 [009] - -
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 206
   Component: IMMO          H01 0711
   Shop #: WSC 00000 000 00000
   VCID: 6ADB77AF8D7FE0DF71-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666859729
   Coding: 030100
   Shop #: WSC 73430 790 00063
   VCID: 2B55B2AB4A0539D74A-807E
Address 37: Navigation (J794)       Labels:* None
   Part No SW: 6JA 035 192 L    HW: 6JA 035 192 L
   Component: RNS315-EU   H85 0501
   Serial number: SEZAZ2P0566811
   Coding: 040004710200000000000001
   Shop #: WSC 73430 790 00137
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 4189F003D089C38780-8014
   Data carrier:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V12  0078
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Part No SW: 5Q0 907 686 C    HW: 5Q0 907 686 B
   Component: HRE_Master    H12 0081
   Serial number: 0423661625
   Coding: 02031102
   ROD: EV_HREntryHella_VW37.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 B
   Component: HRE_Slave  H12 0081
   Serial number: 0417018007
   Coding: 020311
1 Fault Found:
336901 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 151
                    Mileage: 82447 km
                    Date: 2022.08.06
                    Time: 00:37:30
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3111
   Serial number: CEBM0145
   Coding: 0003
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 4683E31FF9A7E4BFB5-8012
Address 56: Radio
Cannot be reached
   Serial number: 30000000238236
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 N    HW: 7P6 035 730 N
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666889683
   Coding: 0210000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
End-------------------------(Elapsed Time: 03:34)--------------------------
Problem 1 .
dipped beam fails , I thing because I have aftermarket HID lamps and ballasts.
main beam works only when you pull the stalk .
Problem 2
front fog lights does not turn on
no static lights
rear fog lights does not turn on
Problem 3.
DRL switches off on the wrong side when you turn on the turn indicators (wiring or coding related )
Hid kit with canbus smart gets rid off the fault on newer cars. Balast like Hylux
til3tsio
Post by til3tsio »
amer6R wrote: Sun Aug 07, 2022 9:13 am Hid kit with canbus smart gets rid off the fault on newer cars. Balast like Hylux
My ballasts are hylux, I have them almost 10 years from my previous car and I do not remember if these are can compatible.
Tested normal halogen lamps and they work ok
Yes, the 5GG light switch is inappropriate.
If it is one of those used on the MQB platform, you will have problems with the fog lights, it use the same pin for both F&R fog lights, and you need a light switch for PQ25 that uses one pin for each fog light.
Don't forget to enable BCM adaptation channels 53 and 54 if you have the 7E0 stalks installed.
According to the installed NON-OEM equipment the BCM coding seems correct for that equipment... it is normal for the diagnostic to complain about the lights. :lol:
til3tsio
Post by til3tsio »
ciclo wrote: Mon Aug 08, 2022 8:00 am Yes, the 5GG light switch is inappropriate.
Thanks for checking out the coding.
dont have 7E0 stalks but 6RA, but I think that I have activated the channels anyway.
Updates:
Problem 1
I tested everything at night , but now I found out that even in daylight headlights turn on in auto position.
Also sometimes I get "Light Assist Failed " message on instruments - Is this HBA related or something else ?.
I installed halogen h7 bulbs , errors turn off and dipped beam turns on ok.
Also high beam turns on now with pushing the stalk and stays on even if i set it to 0 position, to turn it off I have to pull it all the way to flashing.
Is it normal ? I thought that I had to push it again and set it back to 0. Auto HBA does not show on instruments.
Problem 2
Have to get an appropriate switch to test fogs.
still no static lights
problem 3
I mixed the L and R wires , I have to switch them.
Yes, everything you explain about the behavior of lights and warning in the IC on HBA is normal.
"You should install the 7E0 stalks"... and fix the mirror issue (install a proper one or flash the current one).
I was never able to find a flash file for HBA-mirrors, so I would be very grateful if you tell me how to get them (by PM).
For the rest, you already describe what you have to do.
til3tsio
Post by til3tsio »
ciclo wrote: Mon Aug 08, 2022 10:45 am Yes, everything you explain about the behavior of lights and warning in the IC on HBA is normal.
about the 7E0 stalks , I do not thing that they physically fit in my car without changing other parts.
My original 6RA stalks look more like 6C0 stalks on the part that is attached to the steering column.
So do you know if there is a version of 6C0 that will work on pq25 ?
about the mirror, I flashed it with a mqb to pq conversion file that I found on drive2, all the errors about missing communication messages between modules are now gone.
I have not tested it yet though , I will get back when I test that it is functioning correctly.
I have no idea if there are compatible steering combination switch levers for your SETA 🍄 Toledo .
I guess you should dig deeper to find them or make the appropriate modifications so your levers don't catch on the final stroke.
Impressive report for converting HBA mirrors from MQB to PQ and vice versa. I do not know why some of my best Russian FRIENDS did not know of its existence.
https://www.drive2.ru/l/606426293524771900/ 8)
Thank you very much for your diligence in posting the link to facilitate my reading, ... there is no charge for posting links on this forum.
Good luck finding those levers.
til3tsio
Post by til3tsio »
I didn't remember the exact link but you found it anyway, so I call it a win ! Thanks for posting.
But still I wasn't able to see the mirror do it's thing.
I solved all the minor issues with the lights and the switch.
Now I am looking for any kind of label file or info on how to code my 5k7 RLHS correctly because it turns on the lights too soon, and I do not know anything about the humidity part too
Also looking for an instruments cluster software file greater than my 711 for my front assist+ acc experiment
This...
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE1B6D3-807A
or this,
7E0 857 511 F
... they are the only mirrors that will work PERFECTLY on the PQ25 for HBA, any other circumstance is a step backwards in terms of performance.👨‍⚖️
til3tsio
Post by til3tsio »
a few months now mirror works ok,
I had to physically adjust the headlights, they were replaced in the past but never properly adjusted,
also had to do some adaptation changes regarding activation speed and from that point everything seems to work ok.
I could use the addmap of 7E0 mirror to compare everything with my setup if anyone has it stored.
Also I bought a used golf 5K0 hba stalk hoping to convert my 6RA to non-latching with the correct icons but this was not a match.
Stalks themselves (if you disassemble everything) can be interchanged but you cannot interchange the non-latching part because it is physically different.
As a next step I will try 6C6 or 2Q0 newest style variants that acording to etka are combatible with my slipring and mount, posibly with internals intercange.
It would be also helpfull if bcm / cluster could remember the last status if you switch off/on the car like pq35 cars but I do not know how.
and for valentines' day I got my toledo a set of used 17 inch VW Polo 6C GTI Parabolica 6C0601025K rims
you can use 2Q0 if you want, I had those on my Up! and they are a replacement for 1S0/6RA stalks. 6C0 won't return to center like 7E0
