Is the 6C fromt bumper the same as the 6R GTI?
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
The bumpers look pretty similar while the prices are everything but that.
Could one buy a standard 6C front bumper and install 6R GTI grills?
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: Is the 6C fromt bumper the same as the 6R GTI?
Post by ag69 »
do you mean 6C bumper
and put in 6R GTI grills ie bottom left right and center - which are honeycomb?
-- > I have not tried but had seen the grooves and they are different. So they wont fit.
ag69 wrote: Mon Aug 22, 2022 6:55 am do you mean 6C bumper
The lower grilles are very different - hopefully the pictures below illustrate the differences.
6R GTI;
And a standard 6C;
Your first picture is not a GTI but a standard bumper.
This is a GTI bumper, the resemblance is strong:
As far as I can see the 6C has vertical mounting clips for the center grill, while 6R GTI like ( 6R) has diagonal
And the holes for the fog lights look identical
I think you could pull it off if you use a zip tie to hold the center grill. Assemble the center one off the car then put it on.
iichel wrote: Mon Aug 22, 2022 12:14 pm Your first picture is not a GTI but a standard bumper.
Oops! 😳 That’ll teach me to assume that a picture of a Polo with GTI alloys is actually a GTI 🤣.
mirceaculita
They do seem DYI-able. I think I might upgrade to a 6C front bumper and maybe I'll order some cheap fakes of Aliexpress to test. If this was that easy I feel like most enthusiasts that own a polo would do it so I'm not sure about it.
Just find a way to secure the center grill, the rest is easy.
You can use a zip tie, or screws.
