2014 polo 6r 8k PDC malfunction
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
I'm retrofitting an 7N0919475 8k module into my 2014 polo 6r that came stock with an 6R0919475 4k module.
When I activate the 8k with the switxh I get a long beep for about 5 seconds and the the switch just flashes, same if I go into reverse.
I have checked all sensor wiring, switch wiring, and speakers. But the issue still persists.
Any and all help would be greatly appreciated.
-Solerz
Re: 2014 polo 6r 8k PDC malfunction
I don't believe 7N0 is a correct PDC controller for PQ25, you should use the 7E0.
Do you have an autoscan of the car from VCDS or another diagnostic tool? I'm sure it will tell some more.
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
here is the autoscan from today.
Friday,26,August,2022,11:11:57:10494
VCDS Version: 22.3.1.4 (x64)  HEX-NET2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WVWZZZ6RZEU047965   License Plate: ML14OXH
Mileage: 113290km-70395mi   Repair Order: PDC retrofitting
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZEU047965   Mileage: 113290km-70395miles
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 AK    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 5151
   Revision: --H03---    Serial number:                CVN: 1A02BB53
   Coding: 00110016002400080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM12MPI02103E906019AK 001003
   ROD: EV_ECM12MPI021_VW25.rod
   VCID: 6D8CA180BD137183149-8038
   VINID: 9E69EAAAA1A2A9594010724614BE187589
Readiness: 0110 0101
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 23DD2485212700C7C41D246F845600800905
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F70DB08D7DFE393465-805A
   Serial number: 04021404651883
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EAE96CCE075FA1BBD3-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 392445D0B95B1D23C81-806C
   Part No SW: 6R0 937 087 P    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H34 0411
   Revision: BF034001    Serial number: 0581 017140904
   Coding: 39B42FBF08E1240092380E002F6B0CD100C8410F60060000200020000000
   Shop #: WSC 31414 790 31414
   VCID: 4AC60A1CECBD86BB51B-801E
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU010011440104657
   Coding: 1000A0
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU016011440162481
   Coding: 0000A0
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0250352 FLE 20130427
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU013011440134195
   Coding: 0000A0
   Subsystem 8 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8610
   Serial number: KU0KU013011440135449
   Coding: 1000A0
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 7N0 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0010
   Revision: --------    Serial number: 80231028106035
   Coding: 108001
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_EPHVA18VW4280000 001005
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 78A280D4C251C42BF7F-802C
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 254
                    Mileage: 113297 km
                    Date: 2022.08.26
                    Time: 14:10:12
   Component: VW10Airbag01X H10 0020
   Revision: --------    Serial number: 003GX017A07Y
   Coding: 003158
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AC60A1CEC3D86BB51B-801E
   Serial number: 3575HRB40572BJ1E99K4
   Serial number: 3585HRB405T2ATKEE8OK
   Serial number: 3515RRB401G50RVQE1OD
   Serial number: 3525RRB400450REKN1U-
   Part No SW: 6R0 920 960 M    HW: 6R0 920 960 M
   Component: KOMBI         H04 0709
   Coding: 140A01
   VCID: 3FD02BC8A7FF3313F65-806A
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 H34 0411
   Revision: BF034001
   Coding: 003300
   VCID: 70B2B8F4AAA19C6B3FF-8024
   Component: IMMO          H04 0709
   Serial number:
   VCID: 6A86AA9C8CFD66BB71B-803E
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7665754124
   Coding: 010100
   VCID: 2B086F984307BFB34AD-807E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11230
   Shop #: WSC 00788
   VCID: 303278F46361DC6B7FF-8064
Address 56: Radio
Cannot be reached
End----(Elapsed Time: 01:48, VBatt start/end: 11.7V/11.8V. VIgn 11.7V)-----
I'd suggest to get the correct module
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
This is the module I have. Is it possible to flash it with the correct modules firmware?
I don't think a 7N0 HW module will take 7E0 firmware, but you could give it a try.
JB_Solerz
Drives: Polo 6R
Post by JB_Solerz »
flashed it and all working. thanks for the help
