HID Headlight conversion
zainf7
Drives: Mk5 6R BlueGT
Post by zainf7 »
Hi all,
In great need of help with my HID headlight conversion.
Basically, I have a Polo Mk5 6R 2013 and I recently purchased VLAND headlights which use a D2H HID bulb which has replaced the halogen headlight and bulb.
A few weeks ago I installed the headlights but they started flickering. I've switched the bulbs and ballasts around which made no difference. Ended up asking the seller for a new pair of bulbs and ballasts which I installed yesterday to still have the same issue. Could this be an issue with a fuse?
I've tried asking around garages etc and they don't know what the issue is or they won't look at it. It's a pain seeing as the low beams don't work so I can't drive at night.
They usually work fine with ignition on but as soon as I turn the engine on they flicker then turn off completely. I've also seen people mention adding a resistor but a lot also claim it does nothing.
Link to the lights: https://www.ebay.co.uk/itm/133971336972 ... media=COPY
Thanks in advance for any help. :)
patil
Re: HID Headlight conversion
Post by patil »
Hi Zainf7
Kindly post the pictures of your newly bought headlights. Backside pictures of headlights if you can post would be helpful.
zainf7
Post by zainf7 »
Thanks for your response.
Attached where ballasts are installed and the front headlight where the low/high beam isn't working.
patil
Post by patil »
Thank you for the pictures.
Do you have VCDS cable? Can you post the VCDS autoscan here. One of the reason for flickering is, the present BCM power supply might not be enough, that's why flickering and going off. There might be other reasons also. You will get better help if you can post a autoscan.
Thank you
zainf7
Post by zainf7 »
Hi Patil,
I don't have a VCDS cable but I did plug my Carista in the other day.
I had 2 error codes for both front low beams. I can check soon if an actual scan is needed.
Thanks.
No, just don't. Dont use low quality hid ballast. You will f.p your electronics in the car. Get your self ones like hylux ( canbus smart, canbus fast, they are proven and they work and do not interfere with canbus or eletrics on your car).
patil
Post by patil »
I agree with what is written by Amir. I had good experience with hylux ballasts I used for previous aftermarket bixenons.
It is sometimes possible that these aftermarket ballasts/ bulbs will cause flickering. Try first with good brand bulbs and ballasts and see if flickering disappears.
There are some scenarios where flickering happens and can be fixed with BCM coding.
Better if we have an autoscan.
zainf7
Post by zainf7 »
Hi all,
Thank you for the responses.
Plugged in the Carista and got this in the scan:
DETAILED ECU INFO
ECU info obtained with Carista 660099 for iOS:
CAN network gateway
Part #: 6N0909901
Component: GW-K-CAN TP20
Software version: 0712
ASAM/ODX identifier: [none]
Coding: [none]
Fault codes:
01300 Control Module for Navigation with CD-Rom (J401)
Engine
Part #: 04E906016R
Component: 1,4l R4 TSI
Software version: 5764
ASAM/ODX identifier: EV_ECM14TFS01104E906016R
Coding: [none]
[No fault codes]
Transmission
[ECU not present]
ABS
Part #: 6R0907379AS
Component: ESP9.0i front
Software version: 0002
ASAM/ODX identifier: EV_Brake1ESP90iBOSCH
Coding: [none]
[No fault codes]
Power steering
[ECU not present]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: [none]
[No fault codes]
Airbags
Part #: 6R0959655K
Component: VW10Airbag027
Software version: 0020
ASAM/ODX identifier: EV_AirbaVW10BPAVW250
Coding: [none]
[No fault codes]
Instrument cluster
Part #: 6R0920970E
Component: KOMBI
Software version: 0709
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: [none]
[No fault codes]
Navigation
[ECU not present]
Radio
Part #: 6RD035187B
Component: Radio
Software version: 5522
Coding: [none]
[No fault codes]
Media player
Part #: 5N0035342G
Component: SG EXT.PLAYER
Software version: 0770
Coding: [none]
Fault codes:
00464 Controller with display unit for radio and navigation (J503)
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: [none]
[No fault codes]
Heater & air conditioning
Part #: 6R0820045N
Component: Man AC
Software version: 0202
Coding: [none]
[No fault codes]
Parking/steering assist
Part #: 6R0919475C
Component: PARKHILFE 4K
Software version: 0013
ASAM/ODX identifier: EV_VW250ParkiAssis2
Coding: [none]
[No fault codes]
Central electronics
Part #: 7H0937090B
Component: BCM PQ25 Max4
Coding: [none]
Fault codes:
00978 Lamp for Low Beam; Left (M29)
00979 Lamp for Low Beam; Right (M31)
Battery regulator
Part #: 7H0907534
Component: Batt.regelung
Coding: [none]
[No fault codes]
Obtained with Carista 660099 for iOS.
The central electronics show errors for both lamps.
patil
Post by patil »
zainf7 wrote: Sat Sep 17, 2022 7:11 pm
Central electronics
Part #: 7H0937090B
Coding: [none]
Fault codes:
I got exactly what I was suspecting :mrgreen:
That's why having autoscan is best.
Your BCM Max is not happy with those aftermarket ballasts.. very simple.
A BCM coding change in all probabilities will fix the issue. :)
zainf7
Post by zainf7 »
Is BCM coding something I can do myself or best to take to garage? Sorry bit of a noob with car coding and how to do it.
you can try to do it your self
zainf7
Post by zainf7 »
What equipment do I need to do it?
try with carista. Just make a backup of your current coding before changing anything.
zainf7
Post by zainf7 »
I don’t think you can code with Carista.
It’s mainly basic features which can be applied and checked.
What do you use or recommend?
Maybe try the trial version, i saw on their site that offer some coding ability.
Mose here use Vcds, obd11, Odis....
