Polo Won't Start (+ No Lights on Dash)
bdasultan
Drives: VW Polo 1.2 Petrol Highline (2014-15)
Post by bdasultan »
Hi there
My car stopped running 2 months ago after going into a pit with dirt and water (it was rainy season). There were lights on dash but nothing else worked.
1. The car didn't start.
2. The power windows, door locks, hazard lights, etc - nothing worked.
I took it to a mechanic who checked for fuses and ECM/BCM and said the BCM is faulty and need to be replaced. I got a new BCM but don't know how to program it?
1. Do I need the old BCM to program the new BCM? Can I do it without the old one?
2. Is there a different problem with the car? (The old BCM didn't have any visible hardware problem).
Thanks a ton!
Car: VW Polo 1.2 Petrol Highline (2014-15 model)
Re: Polo Won't Start (+ No Lights on Dash)
Programming BCM on a polo 6c should be done via online connection via odis. So via dealership or someone with online access + odis.
bdasultan
Post by bdasultan »
iichel wrote: Tue Nov 15, 2022 8:32 pm Programming BCM on a polo 6c should be done via online connection via odis. So via dealership or someone with online access + odis.
I bought it in December 2014 with registration certificate received in January 2015. So it was made in early/mid 2014. Wouldn't it be 6R then?
Post a picture of your car please.
bdasultan
Post by bdasultan »
iichel wrote: Tue Nov 15, 2022 9:03 pm Post a picture of your car please.
Please find attached.
Indian Polo 2015 is probably PQ25, yes, so technically 6R.
From my own experience, it's hardly ever the BCM, but from a distance I cannot doubt the diagnosis of your mechanic with any support.
bdasultan
Post by bdasultan »
iichel wrote: Tue Nov 15, 2022 10:06 pm Indian Polo 2015 is probably PQ25, yes, so technically 6R.
Yes it also says PQ25 on the BCM. I just need to know how to program this thing. Do you know if I can do it with this generic VCDS Cable and VCDS software?
https://www.amazon.in/Diagnostic-Cable- ... 1235&psc=1
old (original)
old (original)
new (used) to be programmed
new (used) to be programmed.jpeg (208.65 KiB) Viewed 20945 times
spacewalker
Drives: Just a VW
Post by spacewalker »
Car should start even you use brand new bcm.
Then focus on coding, errors etc
