Composition Touch to ???
giannis20vt
Post by giannis20vt »
my Polo 6c has the composition touch as infotainment system. There aren't speakers at the rear door also.
6C0 035 888B is the code number.
What are the options for upgrade ?
I am a little confused about the options.
giannis20vt
Re: Composition Touch to ???
Those are some photos from the original unit
Image Image Image
There is no seperate unit on the glove compartment.
A popular upgrade is the RC330 with carplay, take care you buy the unit for MQB. Or go OEM with a composition media/discover media. There are many version with carplay/android auto/DAB etc so it's important to be careful.
giannis20vt
I am a little confused. The reason is the platform MQB and the way my RCD is connecting to the main wiring.
So this is the unit:
And these are the connectors.
On the MQB platform there is something like this
There is an extra unit in the glove compartment. In my case there is not.
So is it possible to fit a unit from (lets say Polo 6R) or i have to buy a RCD with the extra unit on the glove compartment and to do a more difficult retrofit ?
CarbonChaos
Post by CarbonChaos »
RCD 330 is the model you want,which looks like this so connections should be similar to your OEM unit, the RCD330 was originally designed for the Chinese and Russian markets
Look here and do your own research www.RCD330.com
giannis20vt
The front side (face) doesn't look suitable for my car. Defently doesn't fit.
