BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
So I have flashed my ecu with caac with 140 hp Instead of my current caaa with 84 hp
I am really happy with this improvement, but unfortunately ACC stopped working on 4th and 5th gear
Basically CaaC is made only for 6 gear only, so I am working on a patch to fix this issue
So coping all gear ratios and parameters from my original file should fix this issue
Wow, please keep us informed of your progress.😎
Shadow109
Post by Shadow109 »
So After a several tries, I have finally succeeded to get ACC woking on caac 8) 8)
Shadow109
Post by Shadow109 »
new mod.: DCC
I have installed kufatec loom and all sensor, still waiting for dampers to arrive :roll:
Friday,18,November,2022,08:51:01:10253
VCDS Version: 22.3.1.4 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 14 15 17 19 20 25 37 3C 55 5F 61 65 77
          0B
VIN: WV1ZZZ7HZDH036544   Mileage: 257830km-160208miles
14-Susp. Elect. -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 8437
   Revision: 26H44---    Serial number: 00000000000000 CVN: C7200230
   Coding: 01114012234400080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003006
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77ABE2F64F4FC463FE5-8022
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486614F78F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40D9492A5A0143DB8FF-8014
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5F7D26075F52BBD3-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 02736 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BA3FEC67367E0039AD-802E
   Revision: B9084001    Serial number: 2502 306190145
   Coding: A8B0393E4E33201201280EC17EEB9FDDF8846600608D79C03204003F0860
   Shop #: WSC 12345 123 12345
   VCID: 2D07009EFD13BEB3549-8078
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155001
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: 372B22F60FCF04633E5-8062
1 Fault Found:
12718592 - Databus
          U1121 00 [009] - Missing Message
          [Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Date: 2022.11.18
                    Time: 01:39:20
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: 36352FF208C5FD6B253-8062
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 12030906320002
   Coding: 020180
   Shop #: WSC 05314 123 12345
   VCID: 6695BFB218654DEB553-8032
4 Faults Found:
01087 - Basic Setting Not Performed
            000 - - - MIL ON
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Time Indication: 0
                    Date: 2022.11.18
                    Time: 01:39:18
03262 - Comfort Restriction
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Time Indication: 0
                    Date: 2022.11.18
                    Time: 01:39:18
                    Error Code: 2
                    Bin. Bits: 00000000
00149 - End of Line Programming not Completed
            000 - - - MIL ON
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Time Indication: 0
                    Date: 2022.11.18
                    Time: 01:39:18
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Time Indication: 0
                    Date: 2022.11.18
                    Time: 01:39:18
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 3B233EC633E72003DAD-806E
   Revision: B9084001
   Coding: 042207
   VCID: 6889B18A12715B9B67F-803C
   Revision: AA001001
   Coding: 010100E200000100000000
   VCID: 2E050792F095C5AB6D3-807A
   Component: IMMO          H04 1109
   Serial number:
   VCID: 6A8DCB820CFD698B71B-803E
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels:| User\5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0466413079
   Coding: 03031102
   Shop #: WSC 09003 957 00200
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D2730DE2DF32E33E49-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0465512829
   Coding: 030311
   Revision: --------    Serial number: --------------
   Coding: 020E000001000000
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303D401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2517F8BEA56386F39C9-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 825 254 AN    HW: -----------
   Component: MRM DL2 22/23  --- 1810
3 Faults Found:
1555 - Check Software Version Management
          B201A 00 [009] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Date: 2022.11.18
                    Time: 01:39:19
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Date: 2022.11.18
                    Time: 01:39:20
0527 - Rear Left Bass Speaker
          B1065 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 257839 km
                    Date: 2022.11.18
                    Time: 01:39:21
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: F0001800
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 77: Telephone
Cannot be reached
End----------(Elapsed Time: 01:38, VBatt start/end: 12.3V/12.3V)-----------
Nice. I recently installed it myself. Very pleased with the result.
Jurelo986
Drives: Vw t5.1
Post by Jurelo986 »
Hello, I am trying to install the HBA system on my T5.1 from 2011, I have already bought the BCM 7E937090D H82 module. At the moment I have only connected it to verify that it is recognized and to do the same configuration as my old BCM 7H937089D but it happens to me that the instrument panel has no lighting and the central locking does not work for me, how have you solved these problems? Thanks in advance.
Jurelo986
Drives: Vw t5.1
Post by Jurelo986 »
Sorry, I haven't introduced myself. (I use google translator) I'm iago from Vigo (spain) and I have a VW T5.1 from 2011. Thank you for accepting me in this forum. I have read a lot and I am really learning new things.
TheKeymeister
Drives: Caravelle T5.1
Post by TheKeymeister »
Jurelo986 wrote: Sun Dec 04, 2022 7:24 pm Hello, I am trying to install the HBA system on my T5.1 from 2011, I have already bought the BCM 7E937090D H82 module. At the moment I have only connected it to verify that it is recognized and to do the same configuration as my old BCM 7H937089D but it happens to me that the instrument panel has no lighting and the central locking does not work for me, how have you solved these problems? Thanks in advance.
From memory, there is a pin that needs moving when going from 7H0 to 7E0 BCM. Also, when changing BCM you will need to re-learn the remote fobs using the adaptation channel
You also need to add wiring. At least two can wires to the instrument cluster. Perhaps even more.
Jurelo986
Drives: Vw t5.1
Post by Jurelo986 »
Thanks for the information, really. So I need to take the cable from Can L and Can H to the board and something else? I have elsawin with everything I need up to the year 2015, but from T6 I have nothing, does anyone by chance have the PINOUT of the BCM of the T6 7e937090D to compare pins? What is the option of recording the commands on channel 10 of adaptation "called"? Tanks
Jurelo986 wrote: Sun Dec 04, 2022 7:26 pm Sorry, I haven't introduced myself. (I use google translator) I'm iago from Vigo (spain) and I have a VW T5.1 from 2011. Thank you for accepting me in this forum. I have read a lot and I am really learning new things.
Hello/Hola Jurelo986, welcome!
- Read this post:
viewtopic.php?p=581417#p581417
- The Limalex thread: (put your attention here, you must read it in its entirety)
You should keep in mind that he went from 7H0 937 087 H BCM (high) to 7E0 937 090 D (Max), and you will go from 7H0 BCM Max to 7E0 BCM Max, so you have to focus your attention on the installation of the wires for the Stalks (T41) --- BCM.
T6 Diagrams: https://drive.google.com/file/d/0B2nv91 ... zd1OBVc1WQ
In the link ask me for permission to view/download the diagrams and I will grant it to you.
Regardless of the above, the first thing you should do is the ross-tech procedure for BCM replacement. http://wiki.ross-tech.com/wiki/index.ph ... rol_Module
When you are done with the wiring, I can code your new BCM 7E0 + HBA so that everything works correctly, free, of course.
Jurelo986
Drives: Vw t5.1
Post by Jurelo986 »
Thank you very much. I have already bought the wired ones to make the connections and I am waiting for them to arrive to install them. But I have some questions that intrigue me... My BCM 7H0937089D pin T73b/54 and T73b/57 are empty, however in the diagram that I have it does appear that it has my model, and that 28/29 are canBus Powertrain. nothing happens if I disconnect pin 28/29 from the cluster?
PIN 54_57 BCM.png (7.82 KiB) Viewed 10972 times
J519 Can L Can H.png (134.42 KiB) Viewed 10972 times
The first thing you should do is install the new CAN lines for the instrument cluster, between the instrument cluster connector and the white (B) BCM connector. These new CAN lines are called "dash panel insert CAN bus" although some people called them "extended CAN bus".
These new CAN lines will make it possible to manage the HBA. (processing speed, etc.)
The second thing you should do is replace your old 7H0 BCM 089 with the new 7E0 BCM 090 according to the ross-tech wiki (it's extraordinarily easy), and once replaced you can forget about your old BCM, sell it or throw it away.
With the new 7E0 BCM 090 the instrument panel can be perfectly managed either by the powertrain CAN lines or by the new CAN lines, although it no longer makes sense to connect the instrument panel to the powertrain CAN lines (it is only useful for compatibilities when BCMs Max replacements are mandatory without subsequent modifications/adaptations -VW dealer level-).
I seem to remember that your old BCM 089 is also capable of managing these new CAN lines (they were used in a 2008 VW model, I think it was in the VW Bora, I'm not totally sure right now), however it won't be able to manage the HBA because it does not have the appropriate pins (T73b/4 , T73b/8 among others).
Nothing happens if you disconnect the instrument panel from powertrain CAN lines and connect it to the new CAN lines.
Jurelo986
Drives: Vw t5.1
Post by Jurelo986 »
Hello everyone, I have already installed the wired from the BCM to the cluster, and I have managed to connect and copy the configuration of my old BCM(7H0) but, it gives me some errors that I could not solve;
On the one hand, the remote control of the key never works for me (I have tried to follow Rosstech's steps but I have not been able to), it also gives a turning angle error, from media player3. I have reinstalled the old one until I have a clear solution. Thank you very much everyone for the help.
I seem to remember that if a second hand BCM 7E0 PQ25 comes from a vehicle - donor car - with keyless entry, you cannot adapt/match the remotes in a vehicle without a keyless entry system using the BCM adaptation channel 01 (the usual method) .
I do not know if this issue was resolved by other methods.
Solution: Buy a 'new' BCM 7E0 PQ25 or from a donor vehicle without a keyless entry system.
- The G85 sensor problem -address 04- may be due to the fact that the T41 connector is not connected correctly, you may have to press the locking mechanism of the T41 connector with a little more force. In any case it won't be useful if you can't match the remotes.
- Check the GW installation list (in address 19), it seems that you have not followed all the instructions from ross-tech wiki.
According to the images from ODIS S that you have posted, there are Control Units that do not belong to your T5 and others that cannot be reached because they are not coded/not active/not ticked in the GW installation list.
In a VCDS autoscan with your old BCM 7H0 you have available all the control units that are installed in your T5, which must be transferred exactly to the new BCM 7E0, unchecking those that do not belong to your T5.
